drinking12many
- Apr 8, 2012
Im posting this to help someone else mostly in case you run into similar issues with the Plex 11.0 Jail without hunting through bug reports etc.
I installed the Plex jail, it wasn't working. If you just get page cannot be displayed do the following this will verify plex is at least installed and set it up ot run.
1. Open a console to the Jail
2. Try "service plexmediaserver start" to see if it is even installed, in my case it wasn't there.
3. "pkg install plexmediaserver" if it's not there
4. "sysrc plexmediaserver_enable=YES" to set it to start automatically, now for some reason on my first Freenas reboot this setting reverted to No.... so I had to run this again.
5. then "service plexmediaserver start"
I know its simple, but not being familiar with the jail it took me a little bit to find this and get mine back up and running. Hope it helps someone.
