andrew0401
 - Aug 19, 2011
Tried latest nightly build - 8R7570 on AMD 64 - no luck connecting to our APC UPS via SNMP - any clues/recommendations on parameters?
Andrew
UPDATE - its seems that you need to change/correct all parameters and then restart service to have any impact - the IP address of the SNMP card gets overridden by "/dev/cuau0" on any correction so you need to re-enter all parameters every time otherwise NUT fails
UPDATE 2 - Problem in the MIB???
Sep 6 09:51:21 freenas801rc1 freenas: listening on 127.0.0.1 port 3493
Sep 6 09:51:21 freenas801rc1 freenas: Connected to UPS [UPS]: snmp-ups-UPS
Sep 6 09:51:21 freenas801rc1 freenas[2257]: Executing: /usr/sbin/service nut_upsmon restart
Sep 6 09:51:21 freenas801rc1 freenas: nut_upsmon not running? (check /var/db/nut/upsmon.pid).
Sep 6 09:51:21 freenas801rc1 freenas: Starting nut_upsmon.
Sep 6 09:51:21 freenas801rc1 freenas: UPS: UPS (master) (power value 1)
Sep 6 09:51:21 freenas801rc1 freenas[2257]: Executing: /usr/sbin/service nut_upslog restart
Sep 6 09:51:22 freenas801rc1 freenas: nut_upslog not running? (check /var/db/nut/upslog.pid).
Sep 6 09:51:22 freenas801rc1 freenas: Starting nut_upslog.
Sep 6 09:51:22 freenas801rc1 freenas[2257]: Executing: /bin/pgrep -F /var/db/nut/upsd.pid upsd
Sep 6 09:54:24 freenas801rc1 freenas[2257]: Executing: /usr/sbin/service ix-ups quietstart
Sep 6 09:54:25 freenas801rc1 freenas[2257]: Executing: /usr/sbin/service nut restart
Sep 6 09:54:25 freenas801rc1 freenas: Stopping nut.
Sep 6 09:54:25 freenas801rc1 upsd[5876]: mainloop: Interrupted system call
Sep 6 09:54:26 freenas801rc1 upsmon[5905]: Poll UPS [UPS] failed - Write error: Broken pipe
Sep 6 09:54:26 freenas801rc1 upsmon[5905]: Communications with UPS UPS lost
Sep 6 09:54:27 freenas801rc1 freenas: Network UPS Tools - UPS driver controller 2.4.1
Sep 6 09:54:27 freenas801rc1 freenas: Detected SMART-UPS 3000 RM on host 192.168.80.219 (mib: apcc 1.1)
Sep 6 09:54:27 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.2.2.1.2.1: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:27 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.2.3.1.3.1.1.1: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:27 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.2.3.1.3.1.1.2: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:27 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.2.3.1.3.1.1.3: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:27 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.2.3.1.4.1.1.1: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:27 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.2.3.1.4.1.1.2: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:27 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.2.3.1.4.1.1.3: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:27 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.2.3.1.5.1.1.1: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:27 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.2.3.1.5.1.1.2: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:27 freenas801rc1 freenas: [UPS] Warning: excessive poll failures, limiting error reporting
Sep 6 09:54:28 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.3.2.1.2.1: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:28 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.3.2.1.4.1: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:28 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.3.3.1.3.1.1.1: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:28 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.3.3.1.3.1.1.2: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:28 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.3.3.1.3.1.1.3: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:28 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.3.3.1.4.1.1.1: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:28 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.3.3.1.4.1.1.2: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:28 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.3.3.1.4.1.1.3: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:28 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.3.3.1.5.1.1.1: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:28 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.3.3.1.5.1.1.2: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:28 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.3.3.1.5.1.1.3: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:29 freenas801rc1 freenas: [UPS] Warning: excessive poll failures, limiting error reporting
Sep 6 09:54:29 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.2.1.1.0: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:29 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.2.1.2.0: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:29 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.10.2.3.2.1.4.1: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:29 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.10.2.3.2.1.6.1: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:30 freenas801rc1 freenas: Network UPS Tools - UPS driver controller 2.4.1
Sep 6 09:54:30 freenas801rc1 freenas: Starting nut.
Sep 6 09:54:30 freenas801rc1 freenas: listening on 127.0.0.1 port 3493
Sep 6 09:54:30 freenas801rc1 freenas: Connected to UPS [UPS]: snmp-ups-UPS
Sep 6 09:54:30 freenas801rc1 freenas[2257]: Executing: /usr/sbin/service nut_upsmon restart
Sep 6 09:54:30 freenas801rc1 freenas: Stopping nut_upsmon.
Sep 6 09:54:30 freenas801rc1 upsmon[5896]: upsmon parent: read
Sep 6 09:54:30 freenas801rc1 freenas: Starting nut_upsmon.
Sep 6 09:54:30 freenas801rc1 freenas: UPS: UPS (master) (power value 1)
Sep 6 09:54:30 freenas801rc1 freenas[2257]: Executing: /usr/sbin/service nut_upslog restart
Sep 6 09:54:30 freenas801rc1 freenas: Stopping nut_upslog.
Sep 6 09:54:30 freenas801rc1 freenas: Starting nut_upslog.
Sep 6 09:54:31 freenas801rc1 freenas[2257]: Executing: /bin/pgrep -F /var/db/nut/upsd.pid upsd
			Andrew
