andymemo
 - Jun 2, 2011
HP T1500 XR, Serial UPS
Just to share my experience with getting my HP T1500XR UPS to work - connected through serial. In FreeNAS 0.7, I used the bcmxcp driver, so in the UPS setup for v8.0-Beat4 I selected one of the HP UPS's with this driver. In the port field, I have entered '/dev/cuau0' as my mobo only has 1 serial port header. When I start the service, I get:
Running 'upsc upshh@localhost' on the CLI gives:
Next to see if my UPS is actually working as suggested by Milhouse.
Cheers,
Andy
Jul 20 21:10:06 NAS freenas[1820]: Executing: /usr/sbin/service ix-ups quietstart Jul 20 21:10:06 NAS freenas[1820]: Executing: /usr/sbin/service nut restart Jul 20 21:10:06 NAS freenas: nut not running? (check /var/db/nut/upsd.pid). Jul 20 21:10:06 NAS freenas: Attempting to autodect baudrate Jul 20 21:10:19 NAS freenas: Connected to UPS on /dev/cuau0 with baudrate 9600 Jul 20 21:10:20 NAS freenas: Network UPS Tools - UPS driver controller 2.4.1 Jul 20 21:10:20 NAS freenas: Starting nut. Jul 20 21:10:21 NAS freenas: listening on 0.0.0.0 port 3493 Jul 20 21:10:21 NAS freenas: Connected to UPS [upshh]: bcmxcp-upshh Jul 20 21:10:21 NAS freenas[1820]: Executing: /bin/pgrep -F /var/db/nut/upsd.pid upsd
NAS# upsc upshh@localhost ambient.temperature: 42 ambient.temperature.high: 70 battery.charge: 95 battery.runtime: 3155 battery.voltage: 52.26 driver.name: bcmxcp driver.parameter.pollinterval: 2 driver.parameter.port: /dev/cuau0 driver.version: 2.4.1 driver.version.internal: 0.21 input.frequency: 49.65 input.frequency.high: 54 input.frequency.low: 46 input.frequency.nominal: 50 input.transfer.boost.high: 207 input.transfer.high: 266 input.transfer.low: 171 input.transfer.trim.low: 243 input.voltage: 224 input.voltage.nominal: 230 outlet.1.delay.shutdown: -1 outlet.1.delay.start: 1 outlet.1.id: 1 outlet.1.status: On outlet.2.delay.shutdown: -1 outlet.2.delay.start: 2 outlet.2.id: 2 outlet.2.status: On output.current: 1.0 output.current.nominal: 6.8 output.frequency: 49.65 output.phases: 1 output.voltage: 224 output.voltage.nominal: 230 ups.beeper.status: enabled ups.firmware: Cont:02.03 Inve:02.03 ups.load: 14.8 ups.model: T1500 XR 1500VA ups.power: 222 ups.power.nominal: 1500 ups.serial: CN96060 ups.status: OL
Cheers,
Andy
