upsc ups@localhost battery.charge: 100 battery.charge.low: 10 battery.charge.warning: 50 battery.date: not set battery.mfr.date: 2010/10/08 battery.runtime: 1545 battery.runtime.low: 120 battery.type: PbAc battery.voltage: 13.6 battery.voltage.nominal: 12.0 driver.name: usbhid-ups driver.parameter.pollfreq: 30 driver.parameter.pollinterval: 2 driver.parameter.port: /dev/ugen0.2 driver.version: 2.4.1 driver.version.data: APC HID 0.93 driver.version.internal: 0.34 input.transfer.high: 256 input.transfer.low: 196 input.voltage: 240.0 input.voltage.nominal: 230 ups.beeper.status: enabled ups.delay.shutdown: 20 ups.firmware: 871.O2 .I ups.firmware.aux: O2 ups.load: 18 ups.mfr: APC ups.mfr.date: 2010/10/08 ups.model: Back-UPS ES 700G ups.productid: 0002 ups.serial: 5B1041T28630 ups.status: OL ups.timer.reboot: 0 ups.timer.shutdown: -1 ups.vendorid: 051d
Network UPS Tools upsmon 2.4.1 UPS: ups (master) (power value 1) Invalid notify flag: [EXECNOTIFYFLAG] Warning: no shutdown command defined!
shrek# upsd -c reload
Network UPS Tools upsd 2.4.1
Broadcast Message from antoni@shrek.local
        (no tty) at 9:00 BST...
Communications with UPS ups lost
Communications with UPS ups established
The UPS code has been changed twice by the Devs and I cannot get upsc ups@localhost to work anymore. I think we are working backwards. I also get connection refused. Using build 8r7246. Can someone try a new build (must be 7245 or greater) to see what they get. I doubt it's my machine but hey, you never know. I think I'll tinker some more.
-Mark
EDIT: I reverted back to an older version before the "Fixes" were put in and have been able to restore my connection to my UPS. So the UPS is not fix as of this posting. I tossed an email to William to let him know.
Our Freenas 801RC1 box is working fine - but it is in a cabinet with a large networked APC SmartUPS protecting the whole cabinet - is there anyway to get network connections working rather than just USB/Serial?
Thanks
Andrew
