Cannot connect to Powercom UPS
zerg
Build: FreeNAS-8.1-r7885-amd64
Platform AMD A4-3300 APU with Radeon(tm) HD Graphics
UPS: Powercom Black Knight Pro
Sep 29 01:54:25 freenas kernel: ugen2.2: <POWERCOM Co.,LTD> at usbus2 (disconnected)
Sep 29 01:54:25 freenas kernel: uhid0: at uhub2, port 2, addr 2 (disconnected)
Sep 29 01:54:29 freenas kernel: ugen2.2: <POWERCOM Co.,LTD> at usbus2
Sep 29 01:54:29 freenas root: Unknown USB device: vendor 0x0d9f product 0x00a6 bus uhub2
Sep 29 01:54:30 freenas kernel: uhid0: <POWERCOM Co.,LTD product 0x00a6, class 0/0, rev 1.10/0.01, addr 2> on usbus2
So it seems that I have to set Port to /dev/ugen2.2
Done
Sep 29 01:54:51 freenas freenas[1928]: Executing: /bin/pgrep -F /var/db/nut/upsd.pid upsd
Sep 29 01:54:56 freenas freenas[1928]: Executing: /usr/sbin/service ix-ups quietstart
Sep 29 01:54:56 freenas freenas[1928]: Executing: /usr/sbin/service nut restart
Sep 29 01:54:56 freenas freenas: nut not running? (check /var/db/nut/upsd.pid).
Sep 29 01:54:56 freenas freenas: tcgetattr(/dev/ugen2.2): Inappropriate ioctl for device
Sep 29 01:54:56 freenas freenas: Network UPS Tools - PowerCom protocol UPS driver 0.12 (2.4.1)
Sep 29 01:54:56 freenas freenas: Driver failed to start (exit status=1)
Sep 29 01:54:56 freenas freenas: Network UPS Tools - UPS driver controller 2.4.1
Port : /dev/uhid0 - the same.
P.S. On the NUT page i found that there is 2 kind of Black Knight : serial and USB. I Have the USB one.
So I should use "usbhid-ups (experimental)" driver. Nonexperimental does not work for me
Sep 29 19:07:34 freenas freenas: Network UPS Tools - Generic HID driver 0.34 (2.4.1)
Sep 29 19:07:34 freenas freenas: USB communication driver 0.31
Sep 29 19:07:34 freenas freenas: No matching HID UPS found
Sep 29 19:07:34 freenas freenas: Driver failed to start (exit status=1)
Sep 29 19:07:34 freenas freenas: Network UPS Tools - UPS driver controller 2.4.1
danruehle
Ever get connected
I have a similar, if not the same UPS. Did you ever get it connected? I cannot. I'm using 8.2.0 RC1, same port as you have, none of the drivers work. Actually, selecting the powercom driver prevents nut_upsmon from starting.
zerg
8.0.4 works fine now
Jul 25 13:04:51 freenas freenas[2123]: Executing: /bin/pgrep -F /var/db/nut/upsd.pid upsd
Jul 25 13:04:54 freenas freenas[2123]: Executing: /usr/sbin/service ix-ups quietstart
Jul 25 13:04:54 freenas freenas[2123]: Executing: /usr/sbin/service nut restart
Jul 25 13:04:54 freenas freenas: nut not running? (check /var/db/nut/upsd.pid).
Jul 25 13:04:54 freenas freenas: Using subdriver: PowerCOM HID 0.2
Jul 25 13:04:54 freenas freenas: Network UPS Tools - Generic HID driver 0.35 (2.6.2)
Jul 25 13:04:54 freenas freenas: USB communication driver 0.31
Jul 25 13:04:55 freenas freenas: Network UPS Tools - UPS driver controller 2.6.2
Jul 25 13:04:55 freenas freenas: Starting nut.
Jul 25 13:04:55 freenas freenas: listening on 127.0.0.1 port 3493
Jul 25 13:04:55 freenas freenas: Connected to UPS [ups]: usbhid-ups-ups
Jul 25 13:04:55 freenas freenas[2123]: Executing: /usr/sbin/service nut_upsmon restart
Jul 25 13:04:55 freenas freenas: nut_upsmon not running? (check /var/db/nut/upsmon.pid).
Jul 25 13:04:55 freenas freenas: Starting nut_upsmon.
Jul 25 13:04:55 freenas freenas: UPS: ups (master) (power value 1)
Jul 25 13:04:55 freenas freenas[2123]: Executing: /usr/sbin/service nut_upslog restart
Jul 25 13:04:55 freenas freenas: nut_upslog not running? (check /var/db/nut/upslog.pid).
Jul 25 13:04:55 freenas freenas: Starting nut_upslog.
Jul 25 13:04:55 freenas freenas[2123]: Executing: /bin/pgrep -F /var/db/nut/upsd.pid upsd
external power off/on test:
Jul 25 13:10:25 freenas upsmon[34646]: UPS ups on battery
Jul 25 13:10:40 freenas upsmon[34646]: UPS ups on line power
