GoneTomorrow
- Nov 22, 2013
So I got a UPS for my in-progress FreeNAS server, since, although the mains is very stable here with perhaps one outage per year, they are cheap enough and provide surge protection as well.
So I went out and got a low-end Eaton E NV 600VA UPS, which will provide more than enough power for my server to shutdown safely. I chose this UPS because of it's 'supposed' excellent support with NUT (5 stars apparently).
However the issue I have is that after a random amount of time, the driver just stops communicating with the UPS, and requires a restart of NUT to fix. After searching around, this seems to maybe be a known problem as I've seen a couple of instances of this happening to other people.
My current workaround is a cron job that restarts NUT every 6 hours, but still sometimes the driver will screw up shortly after, leaving 6 hours where the server has no contact with the UPS. I have also reduced the polling interval to 20 seconds, which made it slightly less frequent. I have also replaced the USB cable.
Log messages showing the problem, the first line shows the UPS coming online after a NUT restart at midnight, at which point it works fine until 2:40 later, when it just dies for no reason. Theres another NUT restart at 6am:
Any help please, I can't really start using the server until I have a solution.
Setup:
HP MicroServer G7 2.2GHz dual core
FreeNAS-9.2.0-RELEASE-x64
8GB ECC RAM
3x Seagate NAS drives in RAIDZ
Eaton E series NV 600VA UPS
Dec 29 00:00:09 freenas upsmon[74906]: Communications with UPS ups established Dec 29 02:41:52 freenas blazer_usb[98556]: Permissions problem: Input/output error Dec 29 02:41:52 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 02:41:56 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 02:41:56 freenas upsmon[74906]: Communications with UPS ups lost Dec 29 02:42:01 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 02:42:31 freenas last message repeated 6 times Dec 29 02:44:31 freenas last message repeated 24 times Dec 29 02:46:51 freenas last message repeated 28 times Dec 29 02:46:51 freenas upsmon[74906]: UPS ups is unavailable Dec 29 02:46:53 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 02:46:56 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 02:47:31 freenas last message repeated 7 times Dec 29 02:49:31 freenas last message repeated 24 times Dec 29 02:51:51 freenas last message repeated 28 times Dec 29 02:51:53 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 02:51:56 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 02:51:56 freenas upsmon[74906]: UPS ups is unavailable Dec 29 02:52:01 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 02:52:31 freenas last message repeated 6 times Dec 29 02:54:31 freenas last message repeated 24 times Dec 29 02:56:52 freenas last message repeated 28 times Dec 29 02:56:54 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 02:56:57 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 02:56:57 freenas upsmon[74906]: UPS ups is unavailable Dec 29 02:57:02 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 02:57:32 freenas last message repeated 6 times Dec 29 02:59:27 freenas last message repeated 23 times Dec 29 03:01:52 freenas last message repeated 29 times Dec 29 03:01:54 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 03:01:57 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:02:02 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:02:02 freenas upsmon[74906]: UPS ups is unavailable Dec 29 03:02:07 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:02:42 freenas last message repeated 7 times Dec 29 03:04:47 freenas last message repeated 25 times Dec 29 03:06:52 freenas last message repeated 25 times Dec 29 03:06:54 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 03:06:57 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:07:07 freenas last message repeated 2 times Dec 29 03:07:07 freenas upsmon[74906]: UPS ups is unavailable Dec 29 03:07:12 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:07:47 freenas last message repeated 7 times Dec 29 03:09:52 freenas last message repeated 25 times Dec 29 03:11:52 freenas last message repeated 24 times Dec 29 03:11:54 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 03:11:57 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:12:12 freenas last message repeated 3 times Dec 29 03:12:12 freenas upsmon[74906]: UPS ups is unavailable Dec 29 03:12:17 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:12:52 freenas last message repeated 7 times Dec 29 03:14:57 freenas last message repeated 25 times Dec 29 03:16:53 freenas last message repeated 23 times Dec 29 03:16:55 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 03:16:58 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:17:13 freenas last message repeated 3 times Dec 29 03:17:13 freenas upsmon[74906]: UPS ups is unavailable Dec 29 03:17:18 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:17:53 freenas last message repeated 7 times Dec 29 03:19:58 freenas last message repeated 25 times Dec 29 03:21:53 freenas last message repeated 23 times Dec 29 03:21:55 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 03:21:58 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:22:18 freenas last message repeated 4 times Dec 29 03:22:18 freenas upsmon[74906]: UPS ups is unavailable Dec 29 03:22:23 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:22:58 freenas last message repeated 7 times Dec 29 03:24:58 freenas last message repeated 24 times Dec 29 03:26:53 freenas last message repeated 23 times Dec 29 03:26:55 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 03:26:58 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:27:23 freenas last message repeated 5 times Dec 29 03:27:23 freenas upsmon[74906]: UPS ups is unavailable Dec 29 03:27:28 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:27:58 freenas last message repeated 6 times Dec 29 03:29:58 freenas last message repeated 24 times Dec 29 03:31:53 freenas last message repeated 23 times Dec 29 03:31:55 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 03:31:58 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:32:24 freenas last message repeated 5 times Dec 29 03:32:24 freenas upsmon[74906]: UPS ups is unavailable Dec 29 03:32:29 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:32:59 freenas last message repeated 6 times Dec 29 03:34:59 freenas last message repeated 24 times Dec 29 03:36:54 freenas last message repeated 23 times Dec 29 03:36:56 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 03:36:59 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:37:29 freenas last message repeated 6 times Dec 29 03:37:29 freenas upsmon[74906]: UPS ups is unavailable Dec 29 03:37:34 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:38:09 freenas last message repeated 7 times Dec 29 03:40:14 freenas last message repeated 25 times Dec 29 03:41:54 freenas last message repeated 20 times Dec 29 03:41:56 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 03:41:59 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:42:29 freenas last message repeated 6 times Dec 29 03:42:34 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:42:34 freenas upsmon[74906]: UPS ups is unavailable Dec 29 03:42:39 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:43:14 freenas last message repeated 7 times Dec 29 03:45:19 freenas last message repeated 25 times Dec 29 03:46:54 freenas last message repeated 19 times Dec 29 03:46:56 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 03:46:59 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:47:29 freenas last message repeated 6 times Dec 29 03:47:39 freenas last message repeated 2 times Dec 29 03:47:39 freenas upsmon[74906]: UPS ups is unavailable Dec 29 03:47:44 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:48:19 freenas last message repeated 7 times Dec 29 03:50:24 freenas last message repeated 25 times Dec 29 03:51:54 freenas last message repeated 18 times Dec 29 03:51:56 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 03:51:59 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:52:29 freenas last message repeated 6 times Dec 29 03:52:44 freenas last message repeated 3 times Dec 29 03:52:44 freenas upsmon[74906]: UPS ups is unavailable Dec 29 03:52:49 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:53:24 freenas last message repeated 7 times Dec 29 03:55:25 freenas last message repeated 24 times Dec 29 03:56:55 freenas last message repeated 18 times Dec 29 03:56:57 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 03:57:00 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:57:30 freenas last message repeated 6 times Dec 29 03:57:45 freenas last message repeated 3 times Dec 29 03:57:45 freenas upsmon[74906]: UPS ups is unavailable Dec 29 03:57:50 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 03:58:25 freenas last message repeated 7 times Dec 29 04:00:30 freenas last message repeated 25 times Dec 29 04:01:55 freenas last message repeated 17 times Dec 29 04:01:57 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 04:02:00 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:02:30 freenas last message repeated 6 times Dec 29 04:02:50 freenas last message repeated 4 times Dec 29 04:02:50 freenas upsmon[74906]: UPS ups is unavailable Dec 29 04:02:55 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:03:30 freenas last message repeated 7 times Dec 29 04:05:30 freenas last message repeated 24 times Dec 29 04:06:55 freenas last message repeated 17 times Dec 29 04:06:57 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 04:07:00 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:07:30 freenas last message repeated 6 times Dec 29 04:07:55 freenas last message repeated 5 times Dec 29 04:07:55 freenas upsmon[74906]: UPS ups is unavailable Dec 29 04:08:00 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:08:31 freenas last message repeated 6 times Dec 29 04:10:31 freenas last message repeated 24 times Dec 29 04:11:56 freenas last message repeated 17 times Dec 29 04:11:58 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 04:12:01 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:12:31 freenas last message repeated 6 times Dec 29 04:12:56 freenas last message repeated 5 times Dec 29 04:12:56 freenas upsmon[74906]: UPS ups is unavailable Dec 29 04:13:01 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:13:31 freenas last message repeated 6 times Dec 29 04:15:31 freenas last message repeated 24 times Dec 29 04:16:56 freenas last message repeated 17 times Dec 29 04:16:58 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 04:17:01 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:17:31 freenas last message repeated 6 times Dec 29 04:18:01 freenas last message repeated 6 times Dec 29 04:18:01 freenas upsmon[74906]: UPS ups is unavailable Dec 29 04:18:06 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:18:41 freenas last message repeated 7 times Dec 29 04:20:42 freenas last message repeated 24 times Dec 29 04:21:57 freenas last message repeated 15 times Dec 29 04:21:59 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 04:22:02 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:22:32 freenas last message repeated 6 times Dec 29 04:23:02 freenas last message repeated 6 times Dec 29 04:23:02 freenas upsmon[74906]: UPS ups is unavailable Dec 29 04:23:07 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:23:42 freenas last message repeated 7 times Dec 29 04:25:47 freenas last message repeated 25 times Dec 29 04:26:57 freenas last message repeated 14 times Dec 29 04:26:59 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 04:27:02 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:27:27 freenas last message repeated 5 times Dec 29 04:28:07 freenas last message repeated 8 times Dec 29 04:28:07 freenas upsmon[74906]: UPS ups is unavailable Dec 29 04:28:12 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:28:47 freenas last message repeated 7 times Dec 29 04:30:52 freenas last message repeated 25 times Dec 29 04:31:57 freenas last message repeated 13 times Dec 29 04:31:59 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 04:32:02 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:32:27 freenas last message repeated 5 times Dec 29 04:33:12 freenas last message repeated 9 times Dec 29 04:33:12 freenas upsmon[74906]: UPS ups is unavailable Dec 29 04:33:17 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:33:52 freenas last message repeated 7 times Dec 29 04:35:57 freenas last message repeated 25 times Dec 29 04:36:58 freenas last message repeated 12 times Dec 29 04:37:00 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 04:37:03 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:37:38 freenas last message repeated 7 times Dec 29 04:38:13 freenas last message repeated 7 times Dec 29 04:38:13 freenas upsmon[74906]: UPS ups is unavailable Dec 29 04:38:18 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:38:53 freenas last message repeated 7 times Dec 29 04:40:58 freenas last message repeated 25 times Dec 29 04:41:58 freenas last message repeated 12 times Dec 29 04:42:00 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 04:42:03 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:42:38 freenas last message repeated 7 times Dec 29 04:43:18 freenas last message repeated 8 times Dec 29 04:43:18 freenas upsmon[74906]: UPS ups is unavailable Dec 29 04:43:23 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:43:58 freenas last message repeated 7 times Dec 29 04:45:58 freenas last message repeated 24 times Dec 29 04:46:58 freenas last message repeated 12 times Dec 29 04:47:00 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 04:47:03 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:47:38 freenas last message repeated 7 times Dec 29 04:48:23 freenas last message repeated 9 times Dec 29 04:48:23 freenas upsmon[74906]: UPS ups is unavailable Dec 29 04:48:28 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:48:58 freenas last message repeated 6 times Dec 29 04:50:58 freenas last message repeated 24 times Dec 29 04:51:58 freenas last message repeated 12 times Dec 29 04:52:00 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 04:52:03 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:52:38 freenas last message repeated 7 times Dec 29 04:53:28 freenas last message repeated 10 times Dec 29 04:53:28 freenas upsmon[74906]: UPS ups is unavailable Dec 29 04:53:33 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:54:08 freenas last message repeated 7 times Dec 29 04:56:09 freenas last message repeated 24 times Dec 29 04:56:59 freenas last message repeated 10 times Dec 29 04:57:01 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 04:57:04 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:57:39 freenas last message repeated 7 times Dec 29 04:58:29 freenas last message repeated 10 times Dec 29 04:58:29 freenas upsmon[74906]: UPS ups is unavailable Dec 29 04:58:34 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 04:59:09 freenas last message repeated 7 times Dec 29 05:01:14 freenas last message repeated 25 times Dec 29 05:01:59 freenas last message repeated 9 times Dec 29 05:02:01 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 05:02:04 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:02:39 freenas last message repeated 7 times Dec 29 05:03:34 freenas last message repeated 11 times Dec 29 05:03:34 freenas upsmon[74906]: UPS ups is unavailable Dec 29 05:03:39 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:04:14 freenas last message repeated 7 times Dec 29 05:06:19 freenas last message repeated 25 times Dec 29 05:06:59 freenas last message repeated 8 times Dec 29 05:07:01 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 05:07:04 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:07:39 freenas last message repeated 7 times Dec 29 05:08:39 freenas last message repeated 12 times Dec 29 05:08:39 freenas upsmon[74906]: UPS ups is unavailable Dec 29 05:08:44 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:09:19 freenas last message repeated 7 times Dec 29 05:11:20 freenas last message repeated 24 times Dec 29 05:12:00 freenas last message repeated 8 times Dec 29 05:12:02 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 05:12:05 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:12:40 freenas last message repeated 7 times Dec 29 05:13:40 freenas last message repeated 12 times Dec 29 05:13:40 freenas upsmon[74906]: UPS ups is unavailable Dec 29 05:13:45 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:14:20 freenas last message repeated 7 times Dec 29 05:16:25 freenas last message repeated 25 times Dec 29 05:17:00 freenas last message repeated 7 times Dec 29 05:17:02 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 05:17:05 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:17:40 freenas last message repeated 7 times Dec 29 05:18:45 freenas last message repeated 13 times Dec 29 05:18:45 freenas upsmon[74906]: UPS ups is unavailable Dec 29 05:18:50 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:19:25 freenas last message repeated 7 times Dec 29 05:21:30 freenas last message repeated 25 times Dec 29 05:22:00 freenas last message repeated 6 times Dec 29 05:22:02 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 05:22:05 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:22:40 freenas last message repeated 7 times Dec 29 05:23:50 freenas last message repeated 14 times Dec 29 05:23:50 freenas upsmon[74906]: UPS ups is unavailable Dec 29 05:23:55 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:24:30 freenas last message repeated 7 times Dec 29 05:26:30 freenas last message repeated 24 times Dec 29 05:27:00 freenas last message repeated 6 times Dec 29 05:27:02 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 05:27:05 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:27:40 freenas last message repeated 7 times Dec 29 05:28:55 freenas last message repeated 15 times Dec 29 05:28:55 freenas upsmon[74906]: UPS ups is unavailable Dec 29 05:29:01 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:29:31 freenas last message repeated 6 times Dec 29 05:31:31 freenas last message repeated 24 times Dec 29 05:32:01 freenas last message repeated 6 times Dec 29 05:32:03 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 05:32:06 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:32:41 freenas last message repeated 7 times Dec 29 05:33:56 freenas last message repeated 15 times Dec 29 05:33:56 freenas upsmon[74906]: UPS ups is unavailable Dec 29 05:34:01 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:34:31 freenas last message repeated 6 times Dec 29 05:36:31 freenas last message repeated 24 times Dec 29 05:37:01 freenas last message repeated 6 times Dec 29 05:37:03 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 05:37:06 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:37:41 freenas last message repeated 7 times Dec 29 05:39:01 freenas last message repeated 16 times Dec 29 05:39:01 freenas upsmon[74906]: UPS ups is unavailable Dec 29 05:39:06 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:39:41 freenas last message repeated 7 times Dec 29 05:41:46 freenas last message repeated 25 times Dec 29 05:42:01 freenas last message repeated 3 times Dec 29 05:42:03 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 05:42:06 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:42:41 freenas last message repeated 7 times Dec 29 05:44:06 freenas last message repeated 17 times Dec 29 05:44:06 freenas upsmon[74906]: UPS ups is unavailable Dec 29 05:44:11 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:44:46 freenas last message repeated 7 times Dec 29 05:46:51 freenas last message repeated 25 times Dec 29 05:47:01 freenas last message repeated 2 times Dec 29 05:47:03 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 05:47:06 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:47:41 freenas last message repeated 7 times Dec 29 05:49:12 freenas last message repeated 18 times Dec 29 05:49:12 freenas upsmon[74906]: UPS ups is unavailable Dec 29 05:49:17 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:49:52 freenas last message repeated 7 times Dec 29 05:51:57 freenas last message repeated 25 times Dec 29 05:52:02 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:52:04 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 05:52:07 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:52:42 freenas last message repeated 7 times Dec 29 05:54:17 freenas last message repeated 19 times Dec 29 05:54:17 freenas upsmon[74906]: UPS ups is unavailable Dec 29 05:54:22 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:54:57 freenas last message repeated 7 times Dec 29 05:57:02 freenas last message repeated 25 times Dec 29 05:57:04 freenas upsd[98558]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory Dec 29 05:57:07 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:57:42 freenas last message repeated 7 times Dec 29 05:59:22 freenas last message repeated 20 times Dec 29 05:59:22 freenas upsmon[74906]: UPS ups is unavailable Dec 29 05:59:27 freenas upsmon[74906]: Poll UPS [ups] failed - Driver not connected Dec 29 05:59:57 freenas last message repeated 6 times Dec 29 06:00:01 freenas upsd[98558]: mainloop: Interrupted system call Dec 29 06:00:02 freenas root: Unknown USB device: vendor 0x0665 product 0x5161 bus uhub2 Dec 29 06:00:02 freenas upsmon[74906]: Poll UPS [ups] failed - Write error: Broken pipe Dec 29 06:00:07 freenas upsmon[74906]: Communications with UPS ups established
Setup:
8GB ECC RAM
