How to configure the UPS port?
andrew0401
Tried latest nightly build - 8R7570 on AMD 64 - no luck connecting to our APC UPS via SNMP - any clues/recommendations on parameters?
Andrew
UPDATE - its seems that you need to change/correct all parameters and then restart service to have any impact - the IP address of the SNMP card gets overridden by "/dev/cuau0" on any correction so you need to re-enter all parameters every time otherwise NUT fails
UPDATE 2 - Problem in the MIB???
Sep 6 09:51:21 freenas801rc1 freenas: listening on 127.0.0.1 port 3493
Sep 6 09:51:21 freenas801rc1 freenas: Connected to UPS [UPS]: snmp-ups-UPS
Sep 6 09:51:21 freenas801rc1 freenas[2257]: Executing: /usr/sbin/service nut_upsmon restart
Sep 6 09:51:21 freenas801rc1 freenas: nut_upsmon not running? (check /var/db/nut/upsmon.pid).
Sep 6 09:51:21 freenas801rc1 freenas: Starting nut_upsmon.
Sep 6 09:51:21 freenas801rc1 freenas: UPS: UPS (master) (power value 1)
Sep 6 09:51:21 freenas801rc1 freenas[2257]: Executing: /usr/sbin/service nut_upslog restart
Sep 6 09:51:22 freenas801rc1 freenas: nut_upslog not running? (check /var/db/nut/upslog.pid).
Sep 6 09:51:22 freenas801rc1 freenas: Starting nut_upslog.
Sep 6 09:51:22 freenas801rc1 freenas[2257]: Executing: /bin/pgrep -F /var/db/nut/upsd.pid upsd
Sep 6 09:54:24 freenas801rc1 freenas[2257]: Executing: /usr/sbin/service ix-ups quietstart
Sep 6 09:54:25 freenas801rc1 freenas[2257]: Executing: /usr/sbin/service nut restart
Sep 6 09:54:25 freenas801rc1 freenas: Stopping nut.
Sep 6 09:54:25 freenas801rc1 upsd[5876]: mainloop: Interrupted system call
Sep 6 09:54:26 freenas801rc1 upsmon[5905]: Poll UPS [UPS] failed - Write error: Broken pipe
Sep 6 09:54:26 freenas801rc1 upsmon[5905]: Communications with UPS UPS lost
Sep 6 09:54:27 freenas801rc1 freenas: Network UPS Tools - UPS driver controller 2.4.1
Sep 6 09:54:27 freenas801rc1 freenas: Detected SMART-UPS 3000 RM on host 192.168.80.219 (mib: apcc 1.1)
Sep 6 09:54:27 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.2.2.1.2.1: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:27 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.2.3.1.3.1.1.1: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:27 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.2.3.1.3.1.1.2: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:27 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.2.3.1.3.1.1.3: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:27 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.2.3.1.4.1.1.1: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:27 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.2.3.1.4.1.1.2: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:27 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.2.3.1.4.1.1.3: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:27 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.2.3.1.5.1.1.1: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:27 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.2.3.1.5.1.1.2: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:27 freenas801rc1 freenas: [UPS] Warning: excessive poll failures, limiting error reporting
Sep 6 09:54:28 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.3.2.1.2.1: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:28 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.3.2.1.4.1: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:28 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.3.3.1.3.1.1.1: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:28 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.3.3.1.3.1.1.2: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:28 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.3.3.1.3.1.1.3: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:28 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.3.3.1.4.1.1.1: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:28 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.3.3.1.4.1.1.2: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:28 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.3.3.1.4.1.1.3: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:28 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.3.3.1.5.1.1.1: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:28 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.3.3.1.5.1.1.2: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:28 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.1.9.3.3.1.5.1.1.3: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:29 freenas801rc1 freenas: [UPS] Warning: excessive poll failures, limiting error reporting
Sep 6 09:54:29 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.2.1.1.0: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:29 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.2.1.2.0: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:29 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.10.2.3.2.1.4.1: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:29 freenas801rc1 freenas: [UPS] nut_snmp_get: .1.3.6.1.4.1.318.1.1.10.2.3.2.1.6.1: Error in packet: (noSuchName) There is no such variable name in this MIB.
Sep 6 09:54:30 freenas801rc1 freenas: Network UPS Tools - UPS driver controller 2.4.1
Sep 6 09:54:30 freenas801rc1 freenas: Starting nut.
Sep 6 09:54:30 freenas801rc1 freenas: listening on 127.0.0.1 port 3493
Sep 6 09:54:30 freenas801rc1 freenas: Connected to UPS [UPS]: snmp-ups-UPS
Sep 6 09:54:30 freenas801rc1 freenas[2257]: Executing: /usr/sbin/service nut_upsmon restart
Sep 6 09:54:30 freenas801rc1 freenas: Stopping nut_upsmon.
Sep 6 09:54:30 freenas801rc1 upsmon[5896]: upsmon parent: read
Sep 6 09:54:30 freenas801rc1 freenas: Starting nut_upsmon.
Sep 6 09:54:30 freenas801rc1 freenas: UPS: UPS (master) (power value 1)
Sep 6 09:54:30 freenas801rc1 freenas[2257]: Executing: /usr/sbin/service nut_upslog restart
Sep 6 09:54:30 freenas801rc1 freenas: Stopping nut_upslog.
Sep 6 09:54:30 freenas801rc1 freenas: Starting nut_upslog.
Sep 6 09:54:31 freenas801rc1 freenas[2257]: Executing: /bin/pgrep -F /var/db/nut/upsd.pid upsd
joeschmuck
Old Man
I recommend you submit a ticket addressing your specific configuration.
cbray
Has this thread moved?
The UPS discussions are spread out a bit...
oh and Joe... da mouse :eek: ....wassit it for ?
"I found out which port my UPS was on by plugging in an old USB mouse." :p
CB
ps - I posted elsewhere that under 8.0.2 the ups IDENTIFIER field only works as 'ups'
joeschmuck
Old Man
Hey CB, haven't seen you posting in a while. Guess Hell's waiting room is cooling down a little. The ant? It's because you already took the cool shark.
cbray
Mice have other uses in BSD...
lol not your ant... that's still the coolest.... I was finally rebutting your comment about the fact I had listed an MS-mouse on my machine spec.... and then while catching up on posts I remembered why the damn mouse was plugged in in the first place : To id which USB port my UPS was on way back at the beginning days of this thread(or one of the UPS not working threads).
I had accident and was in hospital for a while... surgery... been learning to walk again past few weeks now.
If I could just get the damn docs to remove my head then I wouldn't have to suffer this f!@#%ng neck pain....
But, I am back... say hello to my son snatchcrash (lives in tampa)... have been trying to play catch up since right when 8.0.1 released...
How have you been? Did you visit us here in 'god's waiting room' ?
good to talk to / hear from you man.
CB
Raymond Matos
So was this resolved? Just ordered an APC smart UPS SC1000, i'm hoping this is going to work. Running FN 8.0.2
joeschmuck
Old Man
I believe all the UPS issues have been resolved, well that I have seen.
