Sorry to dust this up but trying to find a relevant thread. I have an X10SL7 passing through the LSI onboard controller to make Truenas stable in a virtual environment. Looking at the X12SAE-5 right now and don't want to just assume that I can pass along the 6 Sata ports using the Intel W580 chipset because it seems to run a great many different things on the board. Anyone have an experience with this board or passing through intel chipsets to handle Truenas on ESXI?Oh, you're right! Intel may not have yet officially (re)launched W-1200 CPUs "for servers".
But would that prevent anyone from using the current "workstation" W-1200 CPUs in a NAS or a homelab server?
Supermicro may go strictly by the Intel playbook, and have only "workstation" boards at this stage (X12SCA, S12SAE, and even X12SAE-5 with W580), but at least AsRockRack has not noticed that the chips are "for workstations" (or just ignored Intel marketing…) and has a genuine W480 server board, the W480D4U. 2*PCIe x8 from CPU, 8 SATA, 2*M.2, 2*i210 LAN, Aspeed 2500 BMC, no sound… This sounds like the spec sheet for a yet-unreleased X12SCH-F.
Any possibility of using a chassis with a SAS backplane instead of multiplying controllers?Looking for a X11SSH-CTF, as it already has the 8 drive SAS controller. Combined with another SAS controller, that gives me the 16 drives I need for my new system, plus the on board SATA drives for the OS etc.
Maybe. Or not.Is this going to be updated for the X12 boards?
Unless something changed in the last month or so since I checked, short supply and exorbitant prices apply doubly to X12.Is this going to be updated for the X12 boards? Seems the X11 boards are in really short supply, at exorbitant prices, or just out of stock.
Pretty much this. The platform is very limited in terms of PCIe connectivity and switches are not cost-effective. However, even a single HBA is plenty for 99%of users.Any possibility of using a chassis with a SAS backplane instead of multiplying controllers?
Or a 16i LBA?
I just lucked out on an X11SPI-TF + Xeon 4210 combo for $600 (used). RDIMM prices suck though. Especially since I'm looking to put at least 128 GB on this with under 4 slots (ideally just 2 slots) for future expansion.Is this going to be updated for the X12 boards? Seems the X11 boards are in really short supply, at exorbitant prices, or just out of stock. Looking for a X11SSH-CTF, as it already has the 8 drive SAS controller. Combined with another SAS controller, that gives me the 16 drives I need for my new system, plus the on board SATA drives for the OS etc.
Most of the other SuperMicro boards only have a single 8X PCI slot, or have a 16x PCI slot and then 1 or more 4x slots...If there is one that has two 8X or two 16x slots it might work. Oh yea, Single CPU only.
Just wondering.
And what would be the go-to board if this does not suit my needs ?In any case, the go-to board is the X12STH-F.
X11SCH-F already had 2 M.2… if you can still find this C246 board, or an equivalent, for a not-totally-out-of-this-world price.So, do you have any recommendation on a server board that would carry the same features ? (I'm looking for dual M2, and possibly one of 2 LAN at 2.5Gb/s)
Agh, the lower slot is a closed type. Bummer.The X11SCH-F you propose would be good, but the mini-ITX format implies the PCI slot being really close
The platform is going to be a cut above - in both capabilities and price. It's fine, but keep that in mind.X11SRL-F
Why is that a problem? If you have a card in the lower slot, both get cut down to x8, but there's no avoiding it on low-end platforms.
Wouldn't it be a bottleneck for tanscoding to have the GPU at x8 ?Why is that a problem? If you have a card in the lower slot, both get cut down to x8, but there's no avoiding it on low-end platforms.
I think that creating a topic dedicated to your system in the most appropriate section would benefit you a lot.Ok, so x8/x8 would be good for GPU + SAS card given this speed then. And I read some articles with the same conclusion.
That's what I was wondering for the RAM needs.
Thanks for your inputs to all of you, I will work a bit on my own to set up a good rig and come back with my findings.
Here. Please be as detailed as possible and do tell your use case.Well I hesitated because the sub-forum is already flooded with "my new setup" topics, and then I found this very thread, so I did not really know where to post![]()
