As far as I remember, at the time of building the system, there were no supported 64Gb RDIMM modules, so the choice fell on LRDIMM.You can get 64 GB RDIMMs, why would you go out and buy LR-DIMMs?
Pull one of the PSU's and see if the part number is PWS-920P-SQ ("Super Quiet"). eBay sells lots of them, usually at a bit of a premium price.
And they're not "very noisy", but they aren't as quiet as the SQ's.
PWS-920P-R
or something along those lines. How big of a difference does the SQ make over the R?Considering it's ZFS yes...and because it is also a virtualization host I would increase the base 25% and go up from thereDoes this apply to SCALE?
Indeed there is not much new, but that's why it would be useful to add the Core i3-9x00(F) alongside the i8-8300 and, most significantly, point out that Core i3 of the newer 10th and 11th generation no longer support ECC (except for unobtainium "embedded" variants). Otherwise readers will think that this guide is obsolete and either disregard it or assume they can just substitute last generation CPU.I'm not sure there's anything newer for which there is a platform available (higher-end stuff like Xeon-D aside). I haven't heard of any Ice Lake server boards yet.
Let me put it this way: you can't go wrong sticking to the same recommendations. That's not to say that a Linux base OS won't be more forgiving about hardware choices, but doing it right makes still makes things smoother. All the recommended hardware is well supported on both FreeBSD and Linux.Does this apply to SCALE?
Not sure what "they" stands for… Xeon E have been updated, but the "Core+ECC" line is now labelled as W-1200 rather than E-2300 (and skipping W-1100, maybe in an attempt to match with the still current W-2200 and W-3200 lines).They don't work in X11SCx motherboards, though, do they? If I'm not mistaken, they need whatever the new generation of boards will be, and that's only going to be released when the Xeon Es get updated.
Nothing if they really wanted to, but the form factor may be less optimal. I don't know if the IPMI models are the widely-available version, when it comes to those, either.But would that prevent anyone from using the current "workstation" W-1200 CPUs in a NAS or a homelab server?
Good find, it even has conspicuously unpopulated footprints for two Ethernet ports and a large-ish NIC which would definitely be 10 GbE.Supermicro may go strictly by the Intel playbook, and have only "workstation" boards at this stage (X12SCA, S12SAE, and even X12SAE-5 with W580), but at least AsRockRack has not noticed that the chips are "for workstations" (or just ignored Intel marketing…) and has a genuine W480 server board, the W480D4U. 2*PCIe x8 from CPU, 8 SATA, 2*M.2, 2*i210 LAN, Aspeed 2500 BMC, no sound… This sounds like the spec sheet for a yet-unreleased X12SCH-F.
