[FreeNAS 9 Plugins] - SAB / SB / CP / HP / Maraschino / HTPC / Mylar / LL / Gamez
Joshua Parker Ruehlig
I've unchecked that too but it still didnt work. And the search is just from the newznab putting in the nzb providers.
Not sure what is wrong then, possibly the category isn't created on sabnzbd's end or the IP is unreachable, but I doubt it. I would think your setup would give you a different error message because it looks like sabnzbd is enabled. Is there a reason your couchpotato settings looks different than mine?
http://solitaire.jruehlig.com/owncloud/public.php?service=files&t=51c76942925f8672bc445f5ca15e851b
I'm eagerly awaiting the Installation & Setup guide for these plugins on Freenas 9.1.1, I'm not confident enough to start installing on my own (ever since I destroyed a Freenas 7 setup by trying this thing :()
I may start this soon, but I've explained before I am waiting for nzbToMedia to release a stable version that has complete Sickbeard+Transmission integration.
tanik1
Yea i dont know why it looks different. What version are you on? I'm on couchpotato 1.o. And i see you have also installed the ownCloud. thats cool. I was going to do that next but didn't really need for it yet.
tanik1
omg! I dont know what happened. I searched for a different movie to download and guess what it is now working. weird i wish i knew the cause of it. And then i deleted the movie from my wanted listed and added that movie again and now it is working. the movie was monsters university. Well, now its working I dont know what to say because i dont know what was causing the problem in the first place.
Glad you got it working. v1.0 isn't the one I made, and it looks like your on an old version of CouchPotato somehow?
Maybe v1.0 has CouchPotato and not CouchPotatoServer (the actual branch receiving updates)?
tanik1
oh, it seems like its the one that is on freenas. you made a different one? its just couchpotato. thank you.
First post has the link to the PBIs.
tanik1
bbddpp
Josh,
Just wanted to thank you for all the personal help here. It was a bit tough to get rid of all traces of the old plugins, but once I did, I'm happy to now have all yours running in the same jail/user and all that.
I'm still trying to get SickBeard and SAB talking correctly to postprocess a TV show, and I was hoping you might be able to give one last bit of help here.
I set the scripts folder ( /mnt/tv2/plugins/usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard/autoProcessTV) to media:media and 775 permissions on everything in it.
At first I was seeing errors like this when running sabToSickbeard.py:
  File "/usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard/autoProcessTV/sabToSickBeard.py", line 23, in <module>
    import autoProcessTV
  File "/usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard/autoProcessTV/autoProcessTV.py", line 30, in <module>
    from nzbToMediaUtil import *
  File "/usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard/autoProcessTV/nzbToMediaUtil.py", line 12, in <module>
    import linktastic.linktastic as linktastic
ImportError: No module named linktastic.linktastic
I never saw the linktastic error before so I searched it out, and grabbed the latest nzbtomedia code (not sure I ever needed that before, but hey, whatever it takes, right).
After installing nzbtomedia into the scripts folder (which also had a linktastic subfolder) I now get only this when it tries to postprocess:
 No handlers could be found for logger "root"
Any ideas? I realize this isn't your plugin's fault, but something weird with these scripts, any suggestions?
Oh, autoprocessTV.cfg looks like:
[SickBeard]
host=192.168.1.201
port=8081
user=
pass=
web_root=
ssl=
Thanks for anything you might be able to offer up!
Josh,
[SickBeard]
host=192.168.1.201
port=8081
user=
pass=
web_root=
ssl=
I'm confused what you're doing. Either use Sickbeard's implementation of post processing or use nzbToMedia (in a different folder). They're not supposed to me mixed. And there should never really be a need to change permissions on anything... as long as ownership is right, permissions should be correct.
bbddpp
I totally agree. Is there a place I can get just the contents of the autoProcessTV folder and drop it so I can have sab try using it? I'll isolate it from this other stuff. I must have corrupted something when I dropped all those other scripts in there trying to fix it.
bbddpp
Okay Josh, here's what I did. I copied just the 4 files that come with the build into their own folder, and I'm attaching those to this post to see if I somehow am using the wrong files. Can you see if I borked these files up somehow? This should be so easy. I don't get it.
Here's the result now:
  File "/usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard/scripts/sabToSickBeard.py", line 23, in <module>
  File "/usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard/scripts/autoProcessTV.py", line 28, in <module>
    import Transcoder
ImportError: No module named Transcoder
  • autoprocess.zip
    import Transcoder
Is there a reason you can't just reinstall my SickBeard plugin? this will restore the autoProcessTV directory.
bbddpp
Fair point. I assume installing it on top of itself won't work, so I should back up config, uninstall it all, reinstall, and then put my config files back?
By the way I forgot to mention extraction is working great, I have extracted video files sitting there in the completed folder, it's just the process to pass them back to SickBeard that's failing.
Then again maybe that's the whole thing.
Oh, and btw this is where your autoProcessTV folder is supposed to be in your plugin right?
Yeah, I'd backup the entire /usr/pbi/sickbeard-amd64/etc/sickbeard/ directory.
Yeah, that's the spot.
Savell Martin
Hey Josh,
I know you are busy, but I also know there are a fair few people waiting on this Installation guide.
Would it not be too much trouble to ask if you could at least do a basic one for now.
As in how to get it up and running as it is currently, and then at a later stage when nzbToMedia gets released update the PBI's and then installation guide?
At least some of the stuff should be the same, so you shouldn't have to re-do ALL your work.
Just a thought, and I totally understand if you choose to wait.
Hey Josh,
I might do this. I expected nzbToMedia to update sooner. if I break up the guide into parts I can do this. I'll probably start on this next week, out of town this weekend.
michiganblue82
Hey Josh,
We've been emailing a little bit back and forth this morning, but I found this thread and bookmarked it as I will be waiting for your tutorial on installing SB+Sabnzdb on Freenas 9.1. I've damn near read every tutorial out there but they are all for older versions and I get tied up or lost on a step that doesn't pertain to the new 9.1 version.
This "nzbToMedia" plug in you speak of, does it essentially do all the steps for you required to have SB and Sab to work together? I have SB and Sab working flawless on my gaming computer but in the end would like in all installed on my newly built NAS server I built so it handles all these duties.
I will definitely be donating for all the help and greatly look forward to your tutorial. Now as I wait, I'm going to get busy on some other house chores instead of smashing my head on my desk trying to get this to work.
-Al
Hey Josh,
-Al
nzbToMedia does facilitate the programs talking to one another (but it isn't needed); if you already have it working somewhere else there shouldn't be anything different about running it on FreeNAS (unless you're run them in different jails).
