[FreeNAS 9 Plugins] - SAB / SB / CP / HP / Maraschino / HTPC / Mylar / LL / Gamez
rawkus
pauper,
I tried editing through a mapped drive because i am super new to freenas/linux/all things not windows and that is what came to mind. I will look into doing it via nano or vi thanks for the help.
Pouper
pauper,
Gotta learn some Unix man. Very worth it and it'll save you loads of trouble :)
rawkus
Yeah that is the goal. That is why i decided to go this route instead of windows server.
Wolfeman0101
Start by SSHing into FreeNAS and then run 'jls'. You'll see your jail ID and then run 'jexec # tcsh' and now you are inside your jail and can edit files. I use ee or nano, vi is harder to learn to use.
rawkus
So when i run the jexec # tcsh under my user account i get operation not permitted
i am accessing through ssh under a user account i created with full WRX and added to the groups of both the jails storage and media storage. Any idea?
rawkus
is it as easy as giving the user sudo privilege or do i need to enter a command while in ssh?
sorry never mind i figured it out. jsut use sudo jexec # tcsh
Joshua Parker Ruehlig
UPDATE (2/14/2014)
  • SickBeard v2.1p1
    • Fixed lxml dependency needed for TPB branch
rawkus
when i navigate to the directory where sabtosickbeard.py is and type nano sabtosickbeard.py i get command not found when i use ee sabtosickbeard.py it opens the txt editor but doesn't appear to be the file because it is blank.
  • nano isn't installed on the base system.
  • everything in unix is case sensitive.
  • I don't recommend people edit that file.
'pkg install python' fixing the issue. If you can't use 'pkg install', fix the bug with 'pkg' that was mentioned earlier.
http://forums.freenas.org/index.php...-plugin-jail-freenas-9-2-1.18319/#post-100155
rawkus
is this issue with sab not being able to run the sabtosickbeard script exist in 9.2.0?
antkappa
As Josh said 'pkg install python' works and it fixed my issue. However it wasn't that simple as I'm on 9.2.1 and had to use a workaround to get pkg install working first.
rawkus: yes, I'm pretty sure Python is not included.
Very happy with my setup now. Thanks for your work on the PBI files Josh.
rawkus
I was able to get it working after installing python. Thanks for all your help
Andy22
for me the btsync plugin just stalls/stop working at the "Creating jail" (2/3) process (33%), without any error or info? I suppose this should not take longer than 10 minutes after upload?
Can i somehow copy this version over to the official btsync plugin/jail, since its a updated version 1.2.82 vs 1.2.72 (for FreeNAS 9.2.1)
Thx Andy
PS: Was able to install the plugin, by manually creating a plugins jail from the official template and "upload" the .pbi file to this jail, via the jails interface.
I bit the bullet and upgraded my nice stable Freenas 8.3.1 to 9.2.1.
I could not get my old jail back and set up a new one and it's mostly all set except for one thing.
I can not, for the life of me, figure out how to get the postprocessing working in SB.
Sab downloads and moves it to the complete folder.
If I remember correctly, Sab is supposed to launch either autoprocessTV or sabtosickbeard.
I can not remember how I had it working before, it had been a while since I had set it up.
I currently have it set up like in the attached file.
It seems to be working. Is this the correct way?
Sab used to show this:
Processing succeeded for /TVShows/House...
But now it doesn't show that.
Any help please?
I tried looking for the autoprocesstv config in the SB folder to no avail.
thank you!
Any help please?
thank you!
Either you use the directory method where SB periodically scans a directory, or you use the script method where sabnzbd runs a script (I think Settings > Categories). My complete setup guide is nearly complete, notes should be posted tonight or tomorrow.
I hadn't found the script folder, but I found it!
/usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard/autoProcessTV
Thanks for the quick reply, looking forward to your guide, thank you!
