Anything(*) you may find by searching for "sff-8643 sata breakout" on Amazon/Newegg/eBay/your favourite reseller:If there's any SATA Cable like above, it would be much great.
Looking for SFF8643 to SATA like the following design:Likely any cable you can find on Amazon is guaranteed to work better than a detective one.
I am not clear which suggestion you are asking about. SATA to SATA? For how many drives?
Umm, is there any difference between the two?(*) If specified, go for "forward breadkout", NOT "reverse breakout".
Thanks for the info!"Forward" does what you want: From a motherboard/HBA to four individual drives.
"Reverse" goes from four individual SATA ports on a motherboard to a SFF-8643 backplane connector. (Normally, one cannot end up with a reverse cable without really looking for it.)
SATA drives can safely be plugged into SAS connectors, but SAS drives cannot be plugged into SATA connectors.Looking for SFF8643 to SATA like the following design:
I prefer this design as there is very nominal chance that the whole connector will be disturbed when i clean or something and my drives will not have CRC errors. The other systems i have, they have all GIGABYTE SATA to SATA Cables and even if its connected well, the CRC shit happens. I don't trust those cables anymore. Of course, its not the drives cause the one my friend gave, the error count did not increase.
If you are using HDDs there is no way you can saturate the HBA's bandwith with 16 drives if you are using a x16 slot.Just wanted to ask something about the HBA Card. Pretty much everything has a relation with the lanes in a computer but is there any concern when utilizing 16 Drives on a LSI HBA (9400-16i)? Like will it run at full speed without any restrictions, each drive at 6Gb/s connection or is there any kind of limitation or something i shall be concerned about?
For the onboard SAS Port or the another same HBA Card, i would need to connect at least 8xU.2 NVMe Drives for fast storage. Any limitations on that side?
Thanks to this forum, i'm aware of that ;)SATA drives can safely be plugged into SAS connectors, but SAS drives cannot be plugged into SATA connectors.
Drive Replacement
SAS drives generally cost more than their SATA counterparts, have poor SATA reporting and require a SAS HBA. SAS backplanes and expanders are certainly useful, but I struggle to see any benefit of SAS for the hard drives themselves.www.truenas.com
Can you please rephrase it for me? I just want to know whether all my drives connected to the HBA Card will perform as expected or not. I mean all 16 drives connected into 4x SFF8643 SAS port on a single HBA Card which will be installed in an X16 Slot will be able to perform 6Gb/s each? As that's the one SATA Port Bandwidth for the onboard i guess. I'm not sure if 6Gb/s bandwidth is for one single SATA (onboard) port or combined together (for all the SATA ports present on the board).If you are using HDDs there is no way you can saturate the HBA's bandwith with 16 drives if you are using a x16 slot.
Then I am not understanding why you are asking for another recommendation xDThanks to this forum, i'm aware of that ;)
If we are talking about HDDs, and you are plugging the HBA into a full size PCIe slot (thus using all the HBA's available bandwith) yes; otherwise you need to do the math with the lanes.Can you please rephrase it for me? I just want to know whether all my drives connected to the HBA Card will perform as expected or not.
Cause i need one. Will explain tomorrow :)I am not understanding why you are asking for another recommendation xD
Can you tell me more about this please?otherwise you need to do the math with the lanes.
What's wrong with the one I originally suggested?Cause i need one.
If you use the HBA into a smaller than required PCIe slot (such a x6 open slot) the available bandwith decreases.Can you tell me more about this please?
No, no nothing wrong with that. Those were bought already. That was SFF8643 to SAS. I'm looking for SFF8643 to SATA. As already explained, till now i was using onboard SATA to SATA (Gigabyte). Over the period of time, i see a lot of CRC errors even when it had a SATA lock and when i replaced the cables which my friend gave, the CRC error count did not increase. So, I'm looking for SFF8643 to SATA cables like the following design. I find it more safe and not prone to CRC shit as during the maintenance it has a very nominal chance for loose connection. Even when i ensured that it has no loose connection after maintenance, it had CRC errors. Those were brand new original cables which came with the Motherboard.What's wrong with the one I originally suggested?
Makes sense. So, if i install the HBA into a PCIe Slot which is not only X16 slot but also has X16 bandwidth, will my all 16 drives run at 6Gb/s each? LSI 9400-16i says its a 12Gb/s. Is the 12Gb/s bandwidth for the all SAS ports combined or is it 12Gb/s each SAS port? Sorry, just trying to figure out things here.If you use the HBA into a smaller than required PCIe slot (such a x6 open slot) the available bandwith decreases.
You can use SFF8643 to SAS cables with SATA drives, so there is no SFF8643 to SATA with such design.No, no nothing wrong with that. Those were bought already. That was SFF8643 to SAS. I'm looking for SFF8643 to SATA.
OMG. How could i forget this? You saved me dude. A BIG THANK YOU. You're the man!You can use SFF8643 to SAS cables with SATA drives, so there is no SFF8643 to SATA with such design.
Yes, correct.The LSI 9400-16i uses a PCIe 3 x8 connector and has 12Gb/s
Umm, that way it becomes 16x2Gb/s=32Gb/s and the HBA has only 12Gb/sI would say that each drive has around 2 and something Gb/s, which is way more than any HDD speed.
I forgot to ask, what do you mean by cascaded HBAs? Is this something new kind of HBA or HBA configuration?Since SSDs are much faster than HDDs, they can easily saturate the available bandwidth; this can also happen with very big configurations that use cascaded HBAs.
I'm not sure about this, which is the reason I almost immediately edited it out in the previous post.Is the 12Gb/s bandwidth for the all SAS ports combined or is it 12Gb/s each SAS port?
Connect an HBA to a SAS expander.I forgot to ask, what do you mean by cascaded HBAs? Is this something new kind of HBA or HBA configuration?
Hmm. Seems like we need some experts here for the clarifications.I'm not sure about this, which is the reason I almost immediately edited it out in the previous post.
OMG. How does that work though? I mean if i connect an HBA to HBA, where do i connect the drives?You connect an HBA to an HBA.
Sorry, I meant to a SAS expander. You basically gain more ports for a single port.OMG. How does that work though? I mean if i connect an HBA to HBA, where do i connect the drives?
Ah ok. Got it.Sorry, I meant to a SAS expander.
My impression, which can be totally wrong, is the following:Can you please check the post #55 above? Just trying to understand the bandwidth thingy. Let me know if my calculations are up to the mark.
