clifford64
- Aug 18, 2019
Has anyone had issues getting smartctl tests and information since upgrading to TrueNAS 13?
I have been in the process of upgrading my drives. I have been buying elements and easy stores and schucking them. Before I Schuck, I run a smart short and long test. Then I run a bad blocks test.
I have never had any problems running this from the USB drives and even putting red drives in the USB enclosure and running the tests before swapping them into my system. The issues started as soon as I upgraded to TrueNAS 13. Specifically 13 U1 is when I really noticed it.
I bought an elements and I thought it was a bad drive because the short test would run without problems, but the long test would hang after 15 minutes and I wouldn't be able to pull smart info via smartctl until I unplugged and plugged the drive back in. I returned the drive and got a red plus. Same issue with the smart tests. Running a bad blocks would keep the drive more active and I would be able to run a long test, but it would never finish. Could very well be another drive as this one I did put into my system and started getting ata errors.
I then purchased a few other red drives on Amazon prime day and these are same model drives I have used before with no issues at all. Same story though. Long tests don't complete when plugged in via USB.
Any ideas?
TLDR; testing drives via USB no longer works on TrueNAS 13.
Any ideas?
