sabnzbd / sickbeard / couchpotato pbi's
Joshua Parker Ruehlig
Thanks to protosd I was able to get gui start/stop/status working in my subsonic plugin. I will get this working on the 4 usenet plugins and will have version 0.8 up within a day or two.
tmacka88
ok so i just made a video for all the noobs like my self that need a video for everything.
For plugin initialisation
http://youtu.be/UpJT5ehqhKI
and for setting up SAB/couch/sick etc
uploading now I will put link in shortly.
cheers
Thanks for this! Just to clarify the jail / archive datasets don't need to be on a dedicated usb/drive but that is one way to do it.
Also sab / sick / couch / ect.. will all be startable from the gui very soon so your video for setting them up may not be needed.
Also I noticed I never set my nameserver / gateway in my current freenas build and pinging hostnames works just fine in the jail. Maybe it has to do with people's dhcp server (router) giving out default gateways or not, or possibly the ip subnet you put the jail on..
tmacka88
yeh I know about the USB drive, I prob will use a normal drive when I can get one so I dont have to use Mounts.
as for th nameserver im not too sure i was just messing around with it until it worked hahah.
yeh I realised that this would be temp video but thought i would spread the knowledge.
ProtoSD
You'll still need to use mountpoints. I wouldn't have even hinted about using a USB drive, they fail unpredictably and with the heavy writing going on, it's just a disaster waiting to happen.
It's funny how the "Two dumb guys" even made a video about installing plugins. The problem with their videos is you have to listen to all their BS remarks and video effects, and then there's the stuff they're not sure about. Come on, if you're gonna make a video get your facts in order before you make the video and make things more confusing for the people you're supposed to be helping! It shouldn't be a competition to see if you can post your video first, or how many you can post.
Anyway, sorry, got off topic there!
tmacka88
sorry i wasnt very clear I meant use the mount points for changing a download location (yeh I would do it unless using an SSD, but i lil pricey just for downloads.) e.g let the downloads folder stay within the jail.
dont worry I gave you credit in my description and linked towards ur mount points video.
tmacka88
anyone know why in SABnzbd > Settings > Categories there is no option for scripts?
Disregard, made the mistake of not pointing to the script folder
sorry
Craysh
Yup, I'm a dumb ass. Apparently I have a rogue device on my network and my connectivity issue is because that rogue device has that IP address.
I'm going to run ping for a couple of hours but I'm fairly sure that was the problem. I'll wait for V8 :)
EDIT: I've since changed my WiFi password :P
tmacka88
anyone having issues with sickbeard post processing scripts? im getting a
"500 Internal Server Error"
is there something brocken within these pbi's at the moment or is me only?
thanks
tmacka88
Did a bit of tinkering turns out the permissions weren't correct therefore sickbeard couldnt process.
Figured that was the problem
Yeah each plugins runs as a different user which can cause some issues. I might make them all run as a single user, just not sure the implications of this, I could also make them all part of a group so that as long as the have group permissions things would work.
BTW 0.8 is 3/5 of the way done (couchpotato,headphones,maraschino), just gotta deal with some pidfile issues with sabnzbd and sickbeard then it should be good to go
tmacka88
Yeh I think maybe a group would be best.
yeh nice, good work
thanks
Craysh
Hey Joshua,
I look forward to the new version.
Would you be willing to edit your first post so that new people can get the latest one when you release it? :)
Hey Joshua,
Yup, I'll start editing my first post instead of making people dig =P
Craysh
Well up until now it was probably a good idea to make them dig since it was a heck of a lot more involved than just installing the pid. :)
Keep up the good work! Any way to buy you a beer? :D
You could always send beer money to my paypal account joshruehlig@gmail.com
Eventually I'll add a link to the first post, just trying to get too much done right now =]
tmacka88
Hey guys,
I have seam to run into another problem. I can't access couchpatato through the jail ip and port which I used to be able. When I run
service couchpotato restart
it says
pluginjail# service couchpotato restart ****************************************
fetch: http://127.0.0.1:5050//api/c484097803f24ef09c18f6c35bbe8fee/app.shutdown/
?p=02d183f14cdc143ee1ea489d0b24275c&u=Trent: Connection refused ****************
Starting couchpotato.
did the ip for this somehow change to 127.0.0.1? Cause my jail ip is 192.168.2.142
Reading on the sabnzbd wiki http://wiki.sabnzbd.org/configure-general-0-7 it says that 127.0.0.1 is the ip that can only be accessed from that computer. Therefore if this is the problem what file should I "vi" edit to the correct ip?
Thanks.
PS. How's the PBI's coming along.
K, well I am almost done. Got sickbeard done, now just to finish the last issue with the way sabnzbd creates pidfiles. Also I consolidated subsonic into the repo and renamed the git repo from 'freenas_usenet' to 'freenas'. If you have cloned the 'freenas_usenet' repo before your'e gonna have to reclone the new repo =[
git clone ssh://git@fawnhill.no-ip.info:2222/freenas
sorry if pulling is slow, my server hosting it is an old P4 with a slow upload speed, and the repo is like 300MB now..
Going on a trip this weekend, but everything should be done next Tuesday. It'll definitely be a good release =]
