Well pick yourself up some bottles of Two-Buck Chuck! :)Haha, thanks. Yeah I'm more of a wine person myself.
I migrated from .7 to .8 and was having issues moving my old files until I chmod 777 all the files I copied over. Just a tip.
08-30 02:58:31 ERROR [chpotato.core.plugins.log] API log: {'line': u'43', 'type': u'error', 'message': u"chrome 21: \nUncaught TypeError: Cannot read property 'id' of undefined", 'file': u'http://HOST/api/API_KEY/static/file_manager/file.js', 'page': u'http://HOST/wanted/'} 08-30 02:58:34 ERROR [chpotato.core.plugins.log] API log: {'line': u'43', 'type': u'error', 'message': u"chrome 21: \nUncaught TypeError: Cannot read property 'id' of undefined", 'file': u'http://HOST/api/API_KEY/static/file_manager/file.js', 'page': u'http://HOST/wanted/'} 08-30 02:58:35 ERROR [chpotato.core.plugins.log] API log: {'line': u'43', 'type': u'error', 'message': u"chrome 21: \nUncaught TypeError: Cannot read property 'id' of undefined", 'file': u'http://HOST/api/API_KEY/static/file_manager/file.js', 'page': u'http://HOST/wanted/'}
Attica# PID file /usr/pbi/sickbeard-amd64/data/sickbeard.pid already exists. Exiting.
Everything was working great and then I restarted Sickbeard. Now I'm getting this:
Code:Attica# PID file /usr/pbi/sickbeard-amd64/data/sickbeard.pid already exists. Exiting.
Ok that worked. I don't think the PID files like the restart command from within Sickbeard.Make sure Sickbeard isn't actually running ("service sickbeard stop" from the jail shell), and then delete the pid file. I haven't run into issues with pid files sticking around yet on 0.8, but did have that issue occasionally (especially with SAB) on 0.7.
I do it even simpler.
In SAB:
- Don't set up any scripts folder
- Set up categories for TV, Movies, and Music, with Priority and Processing as Default, folder as the folder where you want these to go under your SAB download directory, and groups/indexer tags as TV, Movies, and Music respectively.
- Create the folders in the download directory, or don't and let SAB do it automatically
- If you're going to use the blackhole (which you shouldn't with SB/CP/HP -- let them use the API), go ahead and create subfolders in the blackhole for your categories. NZBs dropped into the subfolders will pick up the subfolder name as their category.
In Sickbeard:
- In Search Settings, when setting up Sickbeard to talk to SAB using your API key, set the category to TV
- Under Post-Processing, set the "TV Download Dir" to the download/TV path SAB writes to.
- Check the "Scan and Process" checkbox
Sickbeard will now watch that folder and process anything that lands there into the appropriate path for the TV show it identifies.
In CouchPotato:
- In the Downloaders section, set the category for SAB to Movies
- In the Renamer section, turn on the Renamer
- Set the From folder to the download/Movies folder from SAB, and the To folder for the root of your Movies storage
CouchPotato will now watch the Movies download folder and process movies out of it into their correct locations.
For HeadPhones:
- In Download Settings, set the SAB category to Music and set the Music Download Directory to the download/Music path from above
- In Quality & Post-Processing, tick the "Move downloads to Destination Folder" checkbox and the "Rename files" checkbox
- Set the destination folder to the root of your music storage, and set any other options you like
Headphones will now watch the Music download folder and process downloads out of that into your music storage under the correct artist/album path.
I get that a long time ago sickbeard and others didn't have their own post-processors, or what they did have wasn't all that good. But that's no longer the case, and they all work flawlessly for me. Let the app that knows about the content do the moving, not SAB. SAB should just download into a deterministic location.
I've re-installed everything so far from scratch (hey, I'm learning, I'm where I was after only an hour!) and it appears to be working except for one thing. With your post processing "system" above, when SB sends an nzb to SAB, it gets downloaded properly, but it gets put into its own subdirectory under /completed/tv/ShowABC and SB then doesn't process it unless I drag it into the directory /completed/tv/. Is there a switch or a setting that tells SAB not to create directories?
Thanks for all your help!
Cheers,
Chris
Aug-27 19:20:00 DEBUG POSTPROCESSER :: Processing folder /mnt/public/downloads/TV Aug-27 19:20:00 DEBUG POSTPROCESSER :: sickbeard.db: SELECT * FROM tv_shows Aug-27 19:20:00 DEBUG POSTPROCESSER :: Recursively processing a folder: Alphas.S02E06.720p.HDTV.x264-IMMERSE Aug-27 19:20:00 DEBUG POSTPROCESSER :: Processing folder /mnt/public/downloads/TV/Alphas.S02E06.720p.HDTV.x264-IMMERSE Aug-27 19:20:00 DEBUG POSTPROCESSER :: sickbeard.db: SELECT * FROM tv_shows Aug-27 19:20:00 INFO POSTPROCESSER :: Processing /mnt/public/downloads/TV/Alphas.S02E06.720p.HDTV.x264-IMMERSE/Alphas.S02E06.720p.HDTV.x264-IMMERSE.mkv (None) Aug-27 19:20:00 DEBUG POSTPROCESSER :: sickbeard.db: SELECT * FROM history WHERE resource LIKE ? with args [u'Alphas_S02E06_720p_HDTV_x264_IMMERSE'] Aug-27 19:20:00 DEBUG POSTPROCESSER :: Found result in history: (210841, 2, []) Aug-27 19:20:00 INFO POSTPROCESSER :: Analyzing name u'/mnt/public/downloads/TV/Alphas.S02E06.720p.HDTV.x264-IMMERSE/Alphas.S02E06.720p.HDTV.x264-IMMERSE.mkv' Aug-27 19:20:00 DEBUG POSTPROCESSER :: Parsed /mnt/public/downloads/TV/Alphas.S02E06.720p.HDTV.x264-IMMERSE/Alphas.S02E06.720p.HDTV.x264-IMMERSE.mkv into Alphas - S2E6 - 720p.HDTV.x264 (IMMERSE) [ABD: False] Aug-27 19:20:00 DEBUG POSTPROCESSER :: Checking scene exceptions for a match on Alphas Aug-27 19:20:00 DEBUG POSTPROCESSER :: cache.db: SELECT tvdb_id FROM scene_exceptions WHERE LOWER(show_name) = ? with args [u'alphas'] Aug-27 19:20:00 DEBUG POSTPROCESSER :: cache.db: SELECT show_name, tvdb_id FROM scene_exceptions Aug-27 19:20:00 DEBUG POSTPROCESSER :: Looking up Alphas in the DB Aug-27 19:20:00 DEBUG POSTPROCESSER :: sickbeard.db: SELECT * FROM tv_shows WHERE show_name LIKE ? OR tvr_name LIKE ? with args [u'Alphas', u'Alphas'] Aug-27 19:20:00 DEBUG POSTPROCESSER :: Lookup successful, using tvdb id 210841 Aug-27 19:20:00 DEBUG POSTPROCESSER :: Loading show object for tvdb_id 210841 Aug-27 19:20:00 DEBUG POSTPROCESSER :: Retrieving episode object for 2x6 Aug-27 19:20:00 DEBUG POSTPROCESSER :: The old status had a quality in it, using that: HD TV Aug-27 19:20:00 DEBUG POSTPROCESSER :: Quality of the episode we're processing: 4 Aug-27 19:20:00 DEBUG POSTPROCESSER :: SB snatched this episode so I'm marking it as priority Aug-27 19:20:00 DEBUG POSTPROCESSER :: Is ep a priority download: True Aug-27 19:20:00 DEBUG POSTPROCESSER :: There is no existing file so there's no worries about replacing it Aug-27 19:20:00 DEBUG POSTPROCESSER :: This download is marked a priority download so I'm going to replace an existing file if I find one Aug-27 19:20:00 DEBUG POSTPROCESSER :: Destination folder for this episode: /mnt/tank/videos/TV/Alphas/Season 2 Aug-27 19:20:00 DEBUG POSTPROCESSER :: 210841: Saving episode details to database
Hi Joshua. Firstly may I say many thanks for producing these pbi's, excellent work.
Just wanted to let you know about some minor bugs that I found in the i386 distro v0.7. You may have already discovered these and fixed them for 0.8 in which case ignore this.
When installing the i386 pbi it creates the folder /usr/pbi/sabnzbd_amd64 however the install scripts point to the correctly named folder of /usr/pbi/sabnzbd_i386. Obviously this means that it simply doesn't work out of the box.
I moved sabnzbd_amd64 to sabnzbd_i386 then chown root:sabnzbd followed by chmod 777. I then ran the scripts in the .sbin again and everything works fine after that.
This is the same for all the pbi's not just sabnzbd. Nice simple error of a mis-named folder and a simple fix hopefully.
Thanks again,
James
Very cool for the new version !
But it seems that there is a missing lib in sabnzbd. par2verify complain about a missing library libtbb.so.
I tried to install it with pkg_add, but I think it's a too different version to work.
As workaround, I installed par2cmdline-tbb with pkg_add, and it's work
I have tried couchpotato and Sickbeard.
Both of them seem to work properly, except for the treemenu in the Freenas UI.
I can see the following messages:
May 29 12:36:32 localhost Couldn't retrieve http://192.168.50.118/plugins/couchpotato/_s/status: HTTP Error 500: INTERNAL SERVER ERROR
May 29 13:08:18 localhost Couldn't retrieve http://192.168.50.118/plugins/sickbeard/_s/treemenu: HTTP Error 502: Bad Gateway
May 29 13:08:18 localhost Couldn't retrieve http://192.168.50.118/plugins/couchpotato/_s/status: HTTP Error 502: Bad Gateway
The nginx error logs show the following messages:
2012/05/29 13:08:18 [error] 4824#0: *35602 kevent() reported about an closed connection (61: Connection refused) while reading response header from upstream, client: 192.168.50.118, server: localhost, request: "GET /plugins/couchpotato/_s/status HTTP/1.1", upstream: "fastcgi://192.168.50.195:12348", host: "192.168.50.118"
2012/05/29 13:08:18 [error] 4824#0: *35604 kevent() reported about an closed connection (61: Connection refused) while reading response header from upstream, client: 192.168.50.118, server: localhost, request: "GET /plugins/sickbeard/_s/status HTTP/1.1", upstream: "fastcgi://192.168.50.195:12349", host: "192.168.50.118
I'm running the amd64 versions of the plugins. Let me know if you need any more information
yup missed tbb package.
So 'pkg_add -r tbb' should fix it. Your method also should work. I'll patch this and make a working version soon.
No just ttb doesn't work, there is an error "thread_monitor Invalid argument". After a search it seems to be a version mismatch between compilation and the installed lib.
