Pydio using NGINX, PHP-FPM, and MySQL
Joshua Parker Ruehlig
Wizened Sage
doesn't fix the situation :(
can perfectly uninstall/install it, but on restarting the jail, nginx is down again with the same error.
that is so strange to me. can you try this.
1) install a new jail
2) pkg upgrade
3) pkg install nginx
4) restart the jail
5) service nginx onestart
Scareh
Member
root@pydio2:/ # service nginx onestart
Performing sanity check on nginx configuration:
nginx: the configuration file /usr/local/etc/nginx/nginx.conf syntax is ok
nginx: configuration file /usr/local/etc/nginx/nginx.conf test is successful
Starting nginx.
root@pydio2:/ # service nginx status
Cannot 'status' nginx. Set nginx_enable to YES in /etc/rc.conf or use 'onestatus' instead of 'status'.
root@pydio2:/ #
Wizened Sage
Starting nginx.
root@pydio2:/ #
so that jail seems fine. not sure why adding mysql/php/pydio would break it.
Scareh
Member
well its not the "normal" way i do it:
root@pydio2:/ # sysrc nginx_enable="YES"
nginx_enable: -> YES
root@pydio2:/ #
root@pydio2:/ # service status nginx
status does not exist in /etc/rc.d or the local startup
directories (/usr/local/etc/rc.d)
root@pydio2:/ # service nginx start
nginx already running? (pid=94527).
root@pydio2:/ # service nginx restart
Stopping nginx.
Waiting for PIDS: 94527.
Starting nginx.
nginx is running as pid 94924.
after I rebooted jail:
nginx is running as pid 96732.
result is the same though, the nginx stays operational after i reboot the jail :/
Wizened Sage
root@pydio2:/ #
Stopping nginx.
Starting nginx.
why don't you just setup pydio in the second, working jail then. sounds like the first one is haunted, lol.
Scareh
Member
*is confused now*
I installed it like you told me to, in a 2nd jail, reboot that jail after i successfully log in to pydio and, it works.... So the problem isn't there anymore
Wizened Sage
*is confused now*
glad it's working. as for the 1st jail issues, I'd blame Canada, lol.
Tyler_2015
Newbie
I was finally able to get the system almost completely all up and running after playing around with various guides on this platform... The info is al little outdated.
I have it installed on FreeNas 9.3.1 and no errors finally... Only issue I am having is that the desktop sync will not connect to the server, it keeps saying ;
  • Server not found (404), is it up and has it Pydio installed ?
Clearly the server is installed as it is running on the web interface... Anyone have any idea what I would be missing out on here?
All I have done so far is setup all of the steps in the above guide plus some additional ones from another guide as the server had errors in the initial run check, slowly but surely I was able to get rid of all the errors.
Still cannot see why I cannot get the desktop sync to work I'm sure it's something too easy!
Wizened Sage
What's out of date?
Delivereath
Member
Installed pydio on a jail following your guide, but when reaching the point where I have to open the pydio web page, I get the following error popup on my web browser : "error loading pydio.min.js?v=##VERSION_NUMBER##:Pydio is not defined"
I guess I should receive 6.0.8 instead of "VERSION_NUMBER" in the error message.
Any idea ?
Wizened Sage
Installed pydio on a jail following your guide, but when reaching the point where I have to open the pydio web page, I get the following error popup on my web browser : "error loading pydio.min.js?v=##VERSION_NUMBER##:pydio is not defined"
Any idea ?
strange, this is when you browse to /pydio? you might want to ask on the pydio forum as well, but I have a feeling you might just have done a step wrong as it had worked for others before.
mrhanman
Neophyte
I'm getting the same error. The only deviation I made from your instructions was to use version 6.2.0. I searched on the pydio forums, but saw no reference to the issue.
Wizened Sage
as pydio 6.2.0 is so new you should actually post something in their forum. you might be the first person hitting this issue.I haven't updated my pydio install yet but will look into the changelog before I do.
mrhanman
Neophyte
I went ahead and started over with 6.0.8, and I still got the error when first passing the system test, but after reloading the page it went on through normally. I haven't tested everything yet, but it seems to be working so far.
Delivereath
Member
I asked on the pydio forum and here is the reply I got :
This guide will not be working as is when deploying from source (here getting tar.gz directly from github).
Instead of grabbing the source and moving into core/src/ , get the prepared package from the main COMMUNITY page here (link to sourceforge).
In 6.2.0, we added a js grunt compilation step that must be run on the source."
After replacing the source with the package from sourceforge, it worked.
Wizened Sage
great, I'll edit the guide!
jayH
Neophyte
I can't seem to figure out what I'm doing wrong. I created a jail called pydio. I created a dataset /mnt/******/pydio. I assigned the storage for the jail to the dataset pointing to destination /mnt/pydio in the jail. I followed the steps and when I get here:
service nginx start && service php-fpm start && service mysql-server start
I get this error:
root@pydio:/ # service nginx start && service php-fpm start && service mysql-ser
ver start
nginx: [emerg] location "^/pydio/(?:\.|conf|data/(?:cache|files|logs|personal|pl
ugins|tmp)|plugins/editor.zoho/agent/files)" is outside location "/pydio" in /us
r/local/etc/nginx/nginx.conf:22
nginx: configuration file /usr/local/etc/nginx/nginx.conf test failed
Starting nginx.
/usr/local/etc/rc.d/nginx: WARNING: failed to start nginx
I even deleted the jail and created another thinking I may have missed something. I got the exact same result.
Any help to see what I'm missing would be appreciated.
Jay
Wizened Sage
I get this error:
ver start
Starting nginx.
Jay
Redoing your jail is a waste of time, you should read the error and try fixing it.
In this case you didn't edit your nginx.conf exactly as specified so I would check there for errors.
Lessbones
Junior Member
Hi all--
I've been running pydio gonna freenas system for the last year, and I've been (mostly) loving it. However, I've consistently had problems with upload file sizes, and ive never been able to get the power.fs Zip creation to work-- two things that are essential for having a really useful system in my case--
I set everything up according to the guide at pydio.com, but it's getting pretty outdated, and it required a LOT of tweaking to get it to a usable state--
I recently came across this thread, and everything in this instruction set seems much simpler, plus it's using updated PHP etc. over the pydio guides--
however I'm getting caught up with 403 Forbidden errors at the end of the guide. I've followed everything to a T when I've been able, although a couple steps have not worked properly:
--linking the cert file at the end of the first step gives a "file already exists" error, which I have ignored and moved forward...
--the php-fpm.conf file, taken from the "production" version, contains no instances of "listen" as it's installed... I've tried tacking on
the lines listed at the bottom since there doesn't seem to be anything relevant to replave, but that didn't work. So next I tried grabbing the php-fpm.conf file I've been using for my partly-working system, and while I was able to now connect to the jail IP, I'm getting a 503 Bad Gateway...
I feel like I'm missing something fairly obvious here, but any help would be much appreciated... thanks
edit: running freenas 9.10 and using the newest pydio 6.5.5 source
Wizened Sage
linking the file is probably no longer needed with more recent versions of the freebsd jail template. so you are fine ignoring it.
there is no "production" version of php-fpm.conf
the listen line should be in there
cat /usr/local/etc/php-fpm.conf.default | grep listen
I assume the error you are hitting is because php isn't listening where nginx expects it.
