Pydio using NGINX, PHP-FPM, and MySQL
Joshua Parker Ruehlig
Wizened Sage
INTRODUCTION
This guide's purpose is to show my recommended method to install Pydio in a jail on FreeNAS. This method does not use the FreeBSD port www/pydio and instead runs the Pydio source on NGINX, PHP-FPM, and MySQL.
INSTALLATION
NOTES
  • I use a subdirectory '/pydio' for my Pydio instance; this is because I have other applications running in other sub-directories. I don't use sub-domains because I want everything on a single domain. I pay for a domain name and get a free SSL Certificate from StartSSL. The free SSL Certificate only works for the domain and a single sub-domain (usually www). You can alternatively choose to host Pydio at the '/' of your server.
  • I have my SSL terminated by HAProxy running on my pfSense router. If you don't have this option, I recommend setting up SSL in NGINX.
Wizened Sage
INSTALLATION
FreeNAS WebUI
Jails > Add Jails
Console in jail's userland
pkg upgrade && pkg install nginx mariadb101-server php70-extensions php70-exif php70-gd php70-mcrypt php70-mysqli php70-openssl php70-zlib php70-APCu
sysrc nginx_enable="YES" php_fpm_enable="YES" mysql_enable="YES"
cp /usr/local/etc/php.ini-production /usr/local/etc/php.ini
ln -s /usr/local/share/certs/ca-root-nss.crt /etc/ssl/cert.pem
  • Set 'worker_processes' to your FreeNAS server's number of threads
  • Set 'client_max_body_size' to your desired maximum upload filesize
worker_processes 2;
events {
  worker_connections  1024;
http {
	include  mime.types;
	default_type  application/octet-stream;
	sendfile  off;
	keepalive_timeout  65;
	gzip off;
	server {
		root /usr/local/www;
		location ^~ /pydio {
			index index.php;
			try_files $uri $uri/ /pydio/index.php$is_args$args;
			client_max_body_size 512M;
			location ~ ^/pydio/(?:\.|conf|data/(?:cache|files|logs|personal|plugins|tmp)|plugins/editor.zoho/agent/files) {
				deny all;
			location ~ \.php$ {
				try_files $uri =404;
				fastcgi_pass unix:/var/run/php-fpm.sock;
				fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
				include fastcgi_params;
			location ~* \.(?:jpg|jpeg|png|gif|ico|css|js)$ {
				expires 30d; add_header Cache-Control public;
date.timezone = America/Los_Angeles
cgi.fix_pathinfo=0
output_buffering = Off
upload_max_filesize = 512M
post_max_size = 512M
listen = /var/run/php-fpm.sock
listen.owner = www
listen.group = www
env[PATH] = /usr/local/bin:/usr/bin:/bin
[server]
skip-networking
skip-name-resolve
expire_logs_days = 1
innodb_flush_method = O_DIRECT
skip-innodb_doublewrite
innodb_flush_log_at_trx_commit = 2
innodb_file_per_table
service nginx start && service php-fpm start && service mysql-server start
mysql -e "CREATE DATABASE pydio;"
mysql -e "GRANT ALL PRIVILEGES ON pydio.* TO 'pydiouser'@'localhost' IDENTIFIED BY 'pydiopass';"
mysql -e "FLUSH PRIVILEGES;"
mysql_secure_installation
fetch "https://download.pydio.com/pub/core/archives/pydio-core-7.0.1.tar.gz"
tar zxf pydio-core-*.tar.gz
rm -r pydio-core-*.tar.gz
mv pydio-core-* /usr/local/www/pydio
chown -R www:www /usr/local/www/pydio
Pydio WebUI
(http://Jail_IP/pydio/?ignore_tests=true)
Database Connexion
  • Host = localhost:/tmp/mysql.sock
  • User = pydiouser
  • Password = pydiopass
Advanced Options
Settings > Application Core > Pydio Main Options
  • Command-Line Active = Yes
crontab -u www -e
  • Replace ADMIN_LOGIN and ADMIN_PASSWORD with your Pydio username and password
*/5 * * * * /usr/local/bin/php /usr/local/www/pydio/cmd.php -r=ajxp_conf -u=ADMIN_LOGIN -p=ADMIN_PASSWORD -a=scheduler_runAll >> /usr/local/www/pydio/data/cache/cmd_outputs/cron_commands.log
Wizened Sage
reserved
Jailer
Not strong, but bad
Any idea on how to get this to use a mounted dataset as the storage for synced files?
Wizened Sage
When I was browsing settings I saw something about setting this location. I'd mount a dataset to /mnt/data and change the setting to that location.
Jailer
Not strong, but bad
Are you talking about the settings in the web UI? I can't seem to find it.
Wizened Sage
maybe you need to do it before installing =[
https://pyd.io/f/topic/assigning-ajxp_data_path/
I would set that path from the link.
delete /usr/local/www/pydio and the pydio database you created.
then redo the steps from the 'mysql -u root -p' command
then St
marian78
Member
Jailer
Not strong, but bad
No you're not doing anything wrong. The version 6 sync client is still in beta and still has some very serious bugs. I used the old Java version and it works fine.
marian78
Member
thx, i try.
Wizened Sage
and you only need the ignore_tests header when your setting it up. I'd personally set it up in a browser, then setup your clients
WhiteEagle112
Neophyte
hello
@Joshua Parker Ruehlig
i have a problem XD
ehmm.. i did a new jail, named PYDIO
i opened the therminal from the jail and write those:
  • pkg upgrade && pkg install nginx mariadb100-server mariadb100-client php56-extensions php56-exif php56-gd php56-mcrypt php56-openssl php56-pdo_mysql php56-zlib
  • sysrc nginx_enable="YES" php_fpm_enable="YES" mysql_enable="YES"
  • cp /usr/local/etc/php.ini-production /usr/local/etc/php.ini
  • ln -s /usr/local/share/certs/ca-root-nss.crt /etc/ssl/cert.pem
seperatly in and enter after the first line there are coming some install i need to aceppt (with that "y")
after second there are coming some yes :smile:
the last 2 did nothing i can see.
so then i dont know, do i need to past taht inside
Show /usr/local/etc/nginx/nginx.conf
? becouse i becoming error command not found.
you can see it there : http://pastebin.com/ej1RK8ae
thx for help, maybe i am doing somthing nooby **** :-D sorry for that ;-)
and thank you for your guide!! =)
Wizened Sage
hello
i have a problem XD
so then i dont know, do i need to past taht inside ? becouse i becoming error command not found.
yeah, anything hidden by Show button should be pasted into the referenced file. as make sure I don't just say replace relevant lines, which means don't overwrite the whole file.
WhiteEagle112
Neophyte
thx for that fast replay! :smile: but like you see in the pastebin, there is no reference file coming up.
you see what i did. insert "Show /usr/local/etc/nginx/nginx.conf" so i can edit it, right? or shouldn't i write that in the terminal?
that in the postebin is a copie from the last lines of terminal
Wizened Sage
"Show" isn't a command. that's just what this forum has when I hid some instructions. you need to use an editor to paste the stuff into a file. 'ee' is an easy one to use.
ee /usr/local/etc/nginx/nginx.conf
Jailer
Not strong, but bad
then St
Well I figured out how to add the mounted storage but I can't seem get permissions right on the dataset so pydio can write to it.
I'll play with this a little more in the morning, it's getting late for us old folks.
Wizened Sage
assumming it's mounted at /mnt/files you can run
chown -R www:www /mnt/files
Jailer
Not strong, but bad
It's working now. It helps if you check the box to actually mount the storage location...... :oops:
Wizened Sage
I think it should be on by default but stuff happens
WhiteEagle112
Neophyte
ohh haha i thougt i nbeed to open it. but i didnt know not with show haha
so no i have opened like you said and ehmm.. check that out XD : http://pastebin.com/k0vnP7qi
seems i am doing somthing wrong. have some errors
so maybe i do a full fresh install of the freenas on my virtualbox so i can do it from begining new?
