mariosk9gr
- Nov 13, 2022
Hello everyone,
So glad that I pull the plug to build my 1st NAS system and I would like your help to guide me regarding hardware.
So, first of all I have 2x hackintoshes which I use for my work as a video editor and colorist. I work with huge files most of the times like braw, canon CRL, r3d raw etc.
My main issue the last couple of years is that I'm out of space very often and mainly my HDDs are not fast enough to handle the work I'm doing. So workflow goes from doing my editing/coloring stuff in NVMEs and then offload the projects to HDDs. It's a pain process and many times I need to copy again a project from my backup HDDs to NVME to make changes/corrections. So, finally I took the decision that I need a NAS system which can connect through 10Gbit on both of my systems so they can work simultaneously (for example 5Gbit per system). Im searching for the last couple of weeks for a ready to go NAS like from Qnap or Synology but I haven't found anything that can provide true 10Gbit speeds sub 1000€. For example Qnap TVS-672xt is plus 2000€ and this price w/o disks ofc. I have a small company and I cannot pay that amount of money so I decided to build it myself. I have experience building systems for many years but not very good experience with networks. 1st step was to visit truenas and check hardware requirements. After that the hardware parts I chose are these:
Intel i3-10320
Asus Prime B560K-M
Corsair 16Gb DDR4 2400 C14 (1 module for start and if needed I can upgrade to 32Gb)
Be Quiet! Pure Power 11 400w Gold+ Certified
Fractal Design Node 804
Chelsio T520 CR T520-CR 10GbE 2-Port PCIe Unified Wire Adapter Card 110-1160-50 (which I found on eBay for 105€)
On my hacks I will use 2x Gigabyte GC-AQC113C or 2x Asus XG-C100C which are 10Gbit ofc and are compatible under macOS.
So, the critical question for start is If I'm going to have any hardware incompatibility issues? Mainly I'm asking about Chelsio T520 CR and if it's compatible with latest truenas OS.
Second, what do you think about the parts I chose.. are them enough to give straight raw power of 10Gbit on both of my systems. Is i3-10320 strong enough to handle it?
I forgot to mention that I will use 5x Ironwolf 8Tb/12Tb (7200rpm/256mb cache) HDDs in RAID5 mode (motherboard has 6x sata ports which I can use them all in the future). Also I won't use a switch for start and my goal is to connect ny NAS directly to my hacks and work it as offline file server for start... maybe later I will experiment with apps and virtualisation but for now all I need is a fast file server with 10Gbit raw performance to handle my files for my editing work.
P.S. I hope I didn't make you bored with all of my noob questions! Please do not hesitate for any suggestions except that I don't have the luxury to go far away from my budget!
Best Regards,
Marios
Intel i3-10320
Asus Prime B560K-M
Best Regards,
Marios
