New HW, same zvol [solved]
graylion
I find myself in the situation that I need to put a new mobo into my TrueNAS Scale. Given that I am (perforce) moving from AMD to Intel this presumably means a new installation. Is it as simple as doing a backup of the config, swapping out HW, installing Truenas, and restoring config to have everything back, including zvol?
Davvo
graylion
further question: do zvol disks have opinions on which SATA port they need to be on?
NugentS
HoneyBadger
actually does care
Administrator
I have had this issue with Linux.
Generally speaking, this problem has been mostly abstracted away by the appliance-like nature of TrueNAS - there's no install-time options to configure/compile for Intel vs AMD, it will just load what's needed on boot. What may be necessary is reconfiguring your network settings (or maybe just changing cables) depending on how the network cards map to the slot/port topology in Linux.
Provided that all disks are present, and the storage controller is supported, ZFS doesn't tend to care which port they're connected to. With that said, zvols are usually created as a sub-element of a pool - if you've created one that's actually mapping the extent to a single physical disk (can you even do that any more?) as a legacy export, it might experience "undefined behavior."
