I highly doubt this would be the cause. You are apt to induce a bent pin if your remove it and reinstall it.I'm also thinking possibly bent CPU pin but it feels like that wouldn't affect just 13 so consistently.
Already got the latest version.Check the BIOS revision on your motherboard.
I know, I accept that, can't really motivate ECC for a home build until DDR5 starts to trickle down from my main machineThis is not a supported motherboard for TrueNAS, it does not meet the system specs, No ECC RAM. But that is fine if you accept it.
Yeah I have found this as well, in this case I'm using Kryonaut Extreme though which is a bit special when it comes to the application. I don't really see how temps would be the issue when it works fine with 12 and prime95 doesn't go over 65c.As for thermal paste... I found out that placing a dab of it in the center of the CPU vice spreading it is actually a better way, it causes no air pockets and might solve the few hotter cores you have.
I wasn't trying to imply that the error was the thermal paste application. Just some good to know stuff is all.Yeah I have found this as well, in this case I'm using Kryonaut Extreme though which is a bit special when it comes to the application. I don't really see how temps would be the issue when it works fine with 12 and prime95 doesn't go over 65c.
Correct.guess you are suspecting the motherboard has a bent pin
Good idea, I will try that.One thing you could do is try to run FreeBSD 13.1 and see what happens.
Never even got to the install part since the installer itself exits with the error.And you did say you tried a clean install I think.
