Hello everyone,
I've been on TrueNAS 12 for a while now and have never moved to 13. I know I can just update, but I have seen posts here where things have broken for some people after updating. I was thinking about doing a clean install and I have a few questions.
1. Currently I'm using two USB drives to boot my NAS as I do not have spare room for an SSD drive let alone two. Well, not really space, but rather SATA connections. If I do a clean install onto two new USB drives will the data on my four 4TB drives remain and be able to be used, or will it get erased?
2. If I do this clean install, would I be able to use a 12.0 Config file to get everything set up the way it was on 12?
3. If after setting up the two USB drives to boot into 13, would I be able to shutdown my NAS and replace the two 13 USB drives with the two 12 USB drives and boot back into TrueNAS 12 and have everything working properly? Meaning will I still be able to access my data on my drives and use my Emby server? I ask this because if when setting up 13, I can't use the 12 Config file or I run into issues setting things up, I'd still like to be able to boot back into my 12 and use my Emby server.
Thanks in advance,
Chris
Thanks in advance,
Chris
