Chris Moore
- May 2, 2015
I hope this can be a learning experience for everyone.
I got home from work last night to find this waiting for me:
The drive in question is a 6TB WD Gold. Here is the output of the SMART report:
It should still be in warranty, so I will send it in. The problem... I failed to follow my own advice. I don't have a spare on hand for this drive.
TrueNAS @ Emily-NAS.home New alerts: * Device: /dev/da8 [SAT], Self-Test Log error count increased from 0 to 1. Current alerts: * Device: /dev/da8 [SAT], 872 Currently unreadable (pending) sectors. * Device: /dev/da8 [SAT], 92 Offline uncorrectable sectors. * Device: /dev/da8 [SAT], Self-Test Log error count increased from 0 to 1.
root@Emily-NAS:~/scripts # smartctl -x /dev/da8 smartctl 7.1 2019-12-30 r5022 [FreeBSD 12.2-RELEASE-p2 amd64] (local build) Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Gold Device Model: WDC WD6002FRYZ-01WD5B0 Serial Number: xxxxxxxx LU WWN Device Id: 5 000cca 255e8ef91 Firmware Version: 01.01M02 User Capacity: 6,001,175,126,016 bytes [6.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Thu Dec 24 02:02:46 2020 CST SMART support is: Available - device has SMART capability. SMART support is: Enabled AAM feature is: Unavailable APM feature is: Disabled Rd look-ahead is: Enabled Write cache is: Enabled DSN feature is: Unavailable ATA Security is: Disabled, NOT FROZEN [SEC1] Wt Cache Reorder: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 121) The previous self-test completed having the read element of the test failed. Total time to complete Offline data collection: ( 113) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 813) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE 1 Raw_Read_Error_Rate PO-R-- 100 100 016 - 0 2 Throughput_Performance P-S--- 137 137 054 - 104 3 Spin_Up_Time POS--- 132 132 024 - 501 (Average 498) 4 Start_Stop_Count -O--C- 100 100 000 - 18 5 Reallocated_Sector_Ct PO--CK 100 100 005 - 0 7 Seek_Error_Rate PO-R-- 100 100 067 - 0 8 Seek_Time_Performance P-S--- 128 128 020 - 18 9 Power_On_Hours -O--C- 097 097 000 - 21258 10 Spin_Retry_Count PO--C- 100 100 060 - 0 12 Power_Cycle_Count -O--CK 100 100 000 - 18 192 Power-Off_Retract_Count -O--CK 089 089 000 - 13724 193 Load_Cycle_Count -O--C- 089 089 000 - 13724 194 Temperature_Celsius -O---- 157 157 000 - 38 (Min/Max 23/50) 196 Reallocated_Event_Count -O--CK 100 100 000 - 0 197 Current_Pending_Sector -O---K 100 100 000 - 872 198 Offline_Uncorrectable ---R-- 100 100 000 - 92 199 UDMA_CRC_Error_Count -O-R-- 200 200 000 - 0 ||||||_ K auto-keep |||||__ C event count ||||___ R error rate |||____ S speed/performance ||_____ O updated online |______ P prefailure warning General Purpose Log Directory Version 1 SMART Log Directory Version 1 [multi-sector log support] Address Access R/W Size Description 0x00 GPL,SL R/O 1 Log Directory 0x01 SL R/O 1 Summary SMART error log 0x02 SL R/O 1 Comprehensive SMART error log 0x03 GPL R/O 1 Ext. Comprehensive SMART error log 0x04 GPL,SL R/O 8 Device Statistics log 0x06 SL R/O 1 SMART self-test log 0x07 GPL R/O 1 Extended self-test log 0x08 GPL R/O 2 Power Conditions log 0x09 SL R/W 1 Selective self-test log 0x10 GPL R/O 1 NCQ Command Error log 0x11 GPL R/O 1 SATA Phy Event Counters log 0x12 GPL R/O 1 SATA NCQ Non-Data log 0x15 GPL,SL R/W 1 Rebuild Assist log 0x21 GPL R/O 1 Write stream error log 0x22 GPL R/O 1 Read stream error log 0x24 GPL R/O 256 Current Device Internal Status Data log 0x25 GPL R/O 256 Saved Device Internal Status Data log 0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log 0x80-0x9f GPL,SL R/W 16 Host vendor specific log 0xe0 GPL,SL R/W 1 SCT Command/Status 0xe1 GPL,SL R/W 1 SCT Data Transfer SMART Extended Comprehensive Error Log Version: 1 (1 sectors) No Errors Logged SMART Extended Self-test Log Version: 1 (1 sectors) Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed: read failure 90% 21257 201727992 # 2 Short offline Completed: read failure 90% 21256 201727992 # 3 Short offline Completed: read failure 90% 21255 201727992 # 4 Extended offline Completed without error 00% 21201 - # 5 Short offline Completed without error 00% 21040 - # 6 Short offline Completed without error 00% 21016 - # 7 Extended offline Interrupted (host reset) 10% 21000 - # 8 Short offline Completed without error 00% 20920 - # 9 Extended offline Completed without error 00% 20893 - #10 Short offline Completed without error 00% 20872 - #11 Short offline Completed without error 00% 20848 - #12 Short offline Completed without error 00% 20825 - #13 Short offline Completed without error 00% 20800 - #14 Extended offline Completed without error 00% 20773 - #15 Short offline Completed without error 00% 20752 - #16 Extended offline Completed without error 00% 20725 - #17 Short offline Completed without error 00% 20704 - #18 Short offline Completed without error 00% 20680 - #19 Short offline Completed without error 00% 20656 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. SCT Status Version: 3 SCT Version (vendor specific): 256 (0x0100) Device State: Active (0) Current Temperature: 38 Celsius Power Cycle Min/Max Temperature: 33/42 Celsius Lifetime Min/Max Temperature: 23/50 Celsius Under/Over Temperature Limit Count: 0/0 SCT Temperature History Version: 2 Temperature Sampling Period: 1 minute Temperature Logging Interval: 1 minute Min/Max recommended Temperature: 0/60 Celsius Min/Max Temperature Limit: -40/70 Celsius Temperature History Size (Index): 128 (72) Index Estimated Time Temperature Celsius 73 2020-12-23 23:55 39 ******************** ... ..( 10 skipped). .. ******************** 84 2020-12-24 00:06 39 ******************** 85 2020-12-24 00:07 38 ******************* ... ..( 2 skipped). .. ******************* 88 2020-12-24 00:10 38 ******************* 89 2020-12-24 00:11 39 ******************** ... ..( 10 skipped). .. ******************** 100 2020-12-24 00:22 39 ******************** 101 2020-12-24 00:23 38 ******************* ... ..( 2 skipped). .. ******************* 104 2020-12-24 00:26 38 ******************* 105 2020-12-24 00:27 39 ******************** ... ..( 10 skipped). .. ******************** 116 2020-12-24 00:38 39 ******************** 117 2020-12-24 00:39 38 ******************* ... ..( 2 skipped). .. ******************* 120 2020-12-24 00:42 38 ******************* 121 2020-12-24 00:43 39 ******************** ... ..( 9 skipped). .. ******************** 3 2020-12-24 00:53 39 ******************** 4 2020-12-24 00:54 38 ******************* ... ..( 4 skipped). .. ******************* 9 2020-12-24 00:59 38 ******************* 10 2020-12-24 01:00 39 ******************** ... ..( 8 skipped). .. ******************** 19 2020-12-24 01:09 39 ******************** 20 2020-12-24 01:10 38 ******************* ... ..( 4 skipped). .. ******************* 25 2020-12-24 01:15 38 ******************* 26 2020-12-24 01:16 39 ******************** ... ..( 9 skipped). .. ******************** 36 2020-12-24 01:26 39 ******************** 37 2020-12-24 01:27 38 ******************* ... ..( 2 skipped). .. ******************* 40 2020-12-24 01:30 38 ******************* 41 2020-12-24 01:31 39 ******************** ... ..( 10 skipped). .. ******************** 52 2020-12-24 01:42 39 ******************** 53 2020-12-24 01:43 38 ******************* ... ..( 3 skipped). .. ******************* 57 2020-12-24 01:47 38 ******************* 58 2020-12-24 01:48 39 ******************** ... ..( 9 skipped). .. ******************** 68 2020-12-24 01:58 39 ******************** 69 2020-12-24 01:59 38 ******************* ... ..( 2 skipped). .. ******************* 72 2020-12-24 02:02 38 ******************* SCT Error Recovery Control: Read: Disabled Write: Disabled Device Statistics (GP Log 0x04) Page Offset Size Value Flags Description 0x01 ===== = = === == General Statistics (rev 2) == 0x01 0x008 4 18 --- Lifetime Power-On Resets 0x01 0x018 6 95709559001 --- Logical Sectors Written 0x01 0x020 6 576804347 --- Number of Write Commands 0x01 0x028 6 170622385595 --- Logical Sectors Read 0x01 0x030 6 756275089 --- Number of Read Commands 0x01 0x038 6 76529512400 --- Date and Time TimeStamp 0x03 ===== = = === == Rotating Media Statistics (rev 1) == 0x03 0x008 4 17358 --- Spindle Motor Power-on Hours 0x03 0x010 4 17358 --- Head Flying Hours 0x03 0x018 4 13724 --- Head Load Events 0x03 0x020 4 0 --- Number of Reallocated Logical Sectors 0x03 0x028 4 210428 --- Read Recovery Attempts 0x03 0x030 4 0 --- Number of Mechanical Start Failures 0x04 ===== = = === == General Errors Statistics (rev 1) == 0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors 0x04 0x010 4 0 --- Resets Between Cmd Acceptance and Completion 0x05 ===== = = === == Temperature Statistics (rev 1) == 0x05 0x008 1 38 --- Current Temperature 0x05 0x010 1 38 N-- Average Short Term Temperature 0x05 0x018 1 37 N-- Average Long Term Temperature 0x05 0x020 1 50 --- Highest Temperature 0x05 0x028 1 23 --- Lowest Temperature 0x05 0x030 1 48 N-- Highest Average Short Term Temperature 0x05 0x038 1 25 N-- Lowest Average Short Term Temperature 0x05 0x040 1 47 N-- Highest Average Long Term Temperature 0x05 0x048 1 25 N-- Lowest Average Long Term Temperature 0x05 0x050 4 0 --- Time in Over-Temperature 0x05 0x058 1 60 --- Specified Maximum Operating Temperature 0x05 0x060 4 0 --- Time in Under-Temperature 0x05 0x068 1 0 --- Specified Minimum Operating Temperature 0x06 ===== = = === == Transport Statistics (rev 1) == 0x06 0x008 4 4 --- Number of Hardware Resets 0x06 0x010 4 0 --- Number of ASR Events 0x06 0x018 4 0 --- Number of Interface CRC Errors |||_ C monitored condition met ||__ D supports DSN |___ N normalized value Pending Defects log (GP Log 0x0c) not supported SATA Phy Event Counters (GP Log 0x11) ID Size Value Description 0x0001 2 0 Command failed due to ICRC error 0x0002 2 0 R_ERR response for data FIS 0x0003 2 0 R_ERR response for device-to-host data FIS 0x0004 2 0 R_ERR response for host-to-device data FIS 0x0005 2 0 R_ERR response for non-data FIS 0x0006 2 0 R_ERR response for device-to-host non-data FIS 0x0007 2 0 R_ERR response for host-to-device non-data FIS 0x0008 2 0 Device-to-host non-data FIS retries 0x0009 2 4 Transition from drive PhyRdy to drive PhyNRdy 0x000a 2 5 Device-to-host register FISes sent due to a COMRESET 0x000b 2 0 CRC errors within host-to-device FIS 0x000d 2 0 Non-CRC errors within host-to-device FIS
