Hazimil
- May 26, 2014
Hi All,
My NAS has finally finished the 1st set of burn-in tests using the lovely script by @Spearfoot . I have 8 log files all showing similar results to below, and it reads all OK to me, just wanted feedback from the experts in case I missed something. I also have 8 empty .bb (badblocks log files)!
Yours
Jonathan
+----------------------------------------------------------------------------- + Started burn-in of /dev/ada0 : Wed Jul 12 15:01:35 BST 2017 +----------------------------------------------------------------------------- Host: freenas.local Drive Model: WDC_WD80EFZX-68UW8N0 Serial Number: VJGGZMSX Short test duration: 2 minutes Short test sleep duration: 120 seconds Extended test duration: 1083 minutes Extended test sleep duration: 64980 seconds Log file: ./burnin-WDC_WD80EFZX-68UW8N0_VJGGZMSX.log Bad blocks file: ./burnin-WDC_WD80EFZX-68UW8N0_VJGGZMSX.bb +----------------------------------------------------------------------------- + Run SMART short test on drive /dev/ada0: Wed Jul 12 15:01:35 BST 2017 +----------------------------------------------------------------------------- Short test started, sleeping 120 seconds until it finishes SMART self-test complete smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build) SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 49 - # 2 Extended offline Completed without error 00% 29 - # 3 Short offline Completed without error 00% 10 - Finished SMART short test on drive /dev/ada0: Wed Jul 12 15:03:35 BST 2017 +----------------------------------------------------------------------------- + Run SMART extended test on drive /dev/ada0: Wed Jul 12 15:03:35 BST 2017 +----------------------------------------------------------------------------- Extended test started, sleeping 64980 seconds until it finishes SMART self-test complete smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build) SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 66 - # 2 Short offline Completed without error 00% 49 - # 3 Extended offline Completed without error 00% 29 - # 4 Short offline Completed without error 00% 10 - Finished SMART extended test on drive /dev/ada0: Thu Jul 13 09:06:35 BST 2017 +----------------------------------------------------------------------------- + Run badblocks test on drive /dev/ada0: Thu Jul 13 09:06:35 BST 2017 +----------------------------------------------------------------------------- Finished badblocks test on drive /dev/ada0: Tue Jul 18 13:35:35 BST 2017 +----------------------------------------------------------------------------- + Run SMART short test on drive /dev/ada0: Tue Jul 18 13:35:35 BST 2017 +----------------------------------------------------------------------------- Short test started, sleeping 120 seconds until it finishes SMART self-test complete smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build) SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 192 - # 2 Extended offline Completed without error 00% 66 - # 3 Short offline Completed without error 00% 49 - # 4 Extended offline Completed without error 00% 29 - # 5 Short offline Completed without error 00% 10 - Finished SMART short test on drive /dev/ada0: Tue Jul 18 13:37:35 BST 2017 +----------------------------------------------------------------------------- + Run SMART extended test on drive /dev/ada0: Tue Jul 18 13:37:35 BST 2017 +----------------------------------------------------------------------------- Extended test started, sleeping 64980 seconds until it finishes SMART self-test complete smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build) SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 209 - # 2 Short offline Completed without error 00% 192 - # 3 Extended offline Completed without error 00% 66 - # 4 Short offline Completed without error 00% 49 - # 5 Extended offline Completed without error 00% 29 - # 6 Short offline Completed without error 00% 10 - Finished SMART extended test on drive /dev/ada0: Wed Jul 19 07:40:36 BST 2017 +----------------------------------------------------------------------------- + SMART information for drive /dev/ada0: Wed Jul 19 07:40:36 BST 2017 smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build) === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD80EFZX-68UW8N0 Serial Number: VJGGZMSX LU WWN Device Id: 5 000cca 261c6d034 Firmware Version: 83.H0A83 User Capacity: 8,001,563,222,016 bytes [8.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Wed Jul 19 07:40:36 2017 BST SMART support is: Available - device has SMART capability. SMART support is: Enabled AAM feature is: Unavailable APM feature is: Disabled Rd look-ahead is: Enabled Write cache is: Enabled ATA Security is: Disabled, frozen [SEC2] Wt Cache Reorder: Enabled SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 101) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: (1083) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE 1 Raw_Read_Error_Rate PO-R-- 100 100 016 - 0 2 Throughput_Performance P-S--- 130 130 054 - 118 3 Spin_Up_Time POS--- 146 146 024 - 433 (Average 465) 4 Start_Stop_Count -O--C- 100 100 000 - 26 5 Reallocated_Sector_Ct PO--CK 100 100 005 - 0 7 Seek_Error_Rate PO-R-- 100 100 067 - 0 8 Seek_Time_Performance P-S--- 128 128 020 - 18 9 Power_On_Hours -O--C- 100 100 000 - 210 10 Spin_Retry_Count PO--C- 100 100 060 - 0 12 Power_Cycle_Count -O--CK 100 100 000 - 26 22 Helium_Level PO---K 100 100 025 - 100 192 Power-Off_Retract_Count -O--CK 100 100 000 - 32 193 Load_Cycle_Count -O--C- 100 100 000 - 32 194 Temperature_Celsius -O---- 200 200 000 - 30 (Min/Max 22/38) 196 Reallocated_Event_Count -O--CK 100 100 000 - 0 197 Current_Pending_Sector -O---K 100 100 000 - 0 198 Offline_Uncorrectable ---R-- 100 100 000 - 0 199 UDMA_CRC_Error_Count -O-R-- 200 200 000 - 0 ||||||_ K auto-keep |||||__ C event count ||||___ R error rate |||____ S speed/performance ||_____ O updated online |______ P prefailure warning General Purpose Log Directory Version 1 SMART Log Directory Version 1 [multi-sector log support] Address Access R/W Size Description 0x00 GPL,SL R/O 1 Log Directory 0x01 SL R/O 1 Summary SMART error log 0x02 SL R/O 1 Comprehensive SMART error log 0x03 GPL R/O 1 Ext. Comprehensive SMART error log 0x04 GPL,SL R/O 8 Device Statistics log 0x06 SL R/O 1 SMART self-test log 0x07 GPL R/O 1 Extended self-test log 0x08 GPL R/O 2 Power Conditions log 0x09 SL R/W 1 Selective self-test log 0x10 GPL R/O 1 SATA NCQ Queued Error log 0x11 GPL R/O 1 SATA Phy Event Counters log 0x12 GPL R/O 1 SATA NCQ NON-DATA log 0x15 GPL,SL R/W 1 SATA Rebuild Assist log 0x21 GPL R/O 1 Write stream error log 0x22 GPL R/O 1 Read stream error log 0x24 GPL R/O 256 Current Device Internal Status Data log 0x25 GPL R/O 256 Saved Device Internal Status Data log 0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log 0x80-0x9f GPL,SL R/W 16 Host vendor specific log 0xe0 GPL,SL R/W 1 SCT Command/Status 0xe1 GPL,SL R/W 1 SCT Data Transfer SMART Extended Comprehensive Error Log Version: 1 (1 sectors) No Errors Logged SMART Extended Self-test Log Version: 1 (1 sectors) Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 209 - # 2 Short offline Completed without error 00% 192 - # 3 Extended offline Completed without error 00% 66 - # 4 Short offline Completed without error 00% 49 - # 5 Extended offline Completed without error 00% 29 - # 6 Short offline Completed without error 00% 10 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. SCT Status Version: 3 SCT Version (vendor specific): 256 (0x0100) SCT Support Level: 1 Device State: Active (0) Current Temperature: 30 Celsius Power Cycle Min/Max Temperature: 28/38 Celsius Lifetime Min/Max Temperature: 22/38 Celsius Under/Over Temperature Limit Count: 0/0 SCT Temperature History Version: 2 Temperature Sampling Period: 1 minute Temperature Logging Interval: 1 minute Min/Max recommended Temperature: 0/60 Celsius Min/Max Temperature Limit: -40/70 Celsius Temperature History Size (Index): 128 (49) Index Estimated Time Temperature Celsius 50 2017-07-19 05:33 29 ********** ... ..( 76 skipped). .. ********** 127 2017-07-19 06:50 29 ********** 0 2017-07-19 06:51 30 *********** ... ..( 47 skipped). .. *********** 48 2017-07-19 07:39 30 *********** 49 2017-07-19 07:40 29 ********** SCT Error Recovery Control: Read: 70 (7.0 seconds) Write: 70 (7.0 seconds) Device Statistics (GP Log 0x04) Page Offset Size Value Flags Description 0x01 ===== = = === == General Statistics (rev 2) == 0x01 0x008 4 26 --- Lifetime Power-On Resets 0x01 0x018 6 62675887561 --- Logical Sectors Written 0x01 0x020 6 245599864 --- Number of Write Commands 0x01 0x028 6 62654157924 --- Logical Sectors Read 0x01 0x030 6 245128799 --- Number of Read Commands 0x01 0x038 6 756664600 --- Date and Time TimeStamp 0x03 ===== = = === == Rotating Media Statistics (rev 1) == 0x03 0x008 4 121 --- Spindle Motor Power-on Hours 0x03 0x010 4 121 --- Head Flying Hours 0x03 0x018 4 32 --- Head Load Events 0x03 0x020 4 0 --- Number of Reallocated Logical Sectors 0x03 0x028 4 819 --- Read Recovery Attempts 0x03 0x030 4 0 --- Number of Mechanical Start Failures 0x04 ===== = = === == General Errors Statistics (rev 1) == 0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors 0x04 0x010 4 0 --- Resets Between Cmd Acceptance and Completion 0x05 ===== = = === == Temperature Statistics (rev 1) == 0x05 0x008 1 30 --- Current Temperature 0x05 0x010 1 30 N-- Average Short Term Temperature 0x05 0x018 1 - N-- Average Long Term Temperature 0x05 0x020 1 38 --- Highest Temperature 0x05 0x028 1 22 --- Lowest Temperature 0x05 0x030 1 34 N-- Highest Average Short Term Temperature 0x05 0x038 1 25 N-- Lowest Average Short Term Temperature 0x05 0x040 1 - N-- Highest Average Long Term Temperature 0x05 0x048 1 - N-- Lowest Average Long Term Temperature 0x05 0x050 4 0 --- Time in Over-Temperature 0x05 0x058 1 60 --- Specified Maximum Operating Temperature 0x05 0x060 4 0 --- Time in Under-Temperature 0x05 0x068 1 0 --- Specified Minimum Operating Temperature 0x06 ===== = = === == Transport Statistics (rev 1) == 0x06 0x008 4 9 --- Number of Hardware Resets 0x06 0x010 4 19 --- Number of ASR Events 0x06 0x018 4 0 --- Number of Interface CRC Errors |||_ C monitored condition met ||__ D supports DSN |___ N normalized value SATA Phy Event Counters (GP Log 0x11) ID Size Value Description 0x0001 2 0 Command failed due to ICRC error 0x0002 2 0 R_ERR response for data FIS 0x0003 2 0 R_ERR response for device-to-host data FIS 0x0004 2 0 R_ERR response for host-to-device data FIS 0x0005 2 0 R_ERR response for non-data FIS 0x0006 2 0 R_ERR response for device-to-host non-data FIS 0x0007 2 0 R_ERR response for host-to-device non-data FIS 0x0008 2 0 Device-to-host non-data FIS retries 0x0009 2 9 Transition from drive PhyRdy to drive PhyNRdy 0x000a 2 9 Device-to-host register FISes sent due to a COMRESET 0x000b 2 0 CRC errors within host-to-device FIS 0x000d 2 0 Non-CRC errors within host-to-device FIS +----------------------------------------------------------------------------- + Finished burn-in of /dev/ada0 : Wed Jul 19 07:40:36 BST 2017 +-----------------------------------------------------------------------------
Yours
Jonathan
