glauco
- Jan 30, 2017
Hey everybody!
I'm pretty confident that this drive qualifies for an RMA, but I'd rather ask you guys first!
I've boldfaced strings that appear relevant to me.
As for alerts in the FreeNAS web UI, I got this: "Device: /dev/ada1, Self-Test Log error count increased from 4 to 5".
Thank you!
Output of
Thank you!
Output of
smartctl -x /dev/ada1
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD30EFRX-68EUZN0 Serial Number: WD-WCC4N0RY8T3U LU WWN Device Id: 5 0014ee 263bad54f Firmware Version: 82.00A82 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sun Sep 22 14:27:29 2019 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled AAM feature is: Unavailable APM feature is: Unavailable Rd look-ahead is: Enabled Write cache is: Enabled DSN feature is: Unavailable ATA Security is: Disabled, NOT FROZEN [SEC1] Wt Cache Reorder: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 121) The previous self-test completed having the read element of the test failed. Total time to complete Offline data collection: (41460) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 416) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x703d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE 1 Raw_Read_Error_Rate POSR-K 200 200 051 - 4 3 Spin_Up_Time POS--K 181 177 021 - 5941 4 Start_Stop_Count -O--CK 100 100 000 - 582 5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0 7 Seek_Error_Rate -OSR-K 200 200 000 - 0 9 Power_On_Hours -O--CK 079 079 000 - 15500 10 Spin_Retry_Count -O--CK 100 100 000 - 0 11 Calibration_Retry_Count -O--CK 100 100 000 - 0 12 Power_Cycle_Count -O--CK 100 100 000 - 540 192 Power-Off_Retract_Count -O--CK 200 200 000 - 142 193 Load_Cycle_Count -O--CK 200 200 000 - 616 194 Temperature_Celsius -O---K 112 105 000 - 38 196 Reallocated_Event_Count -O--CK 200 200 000 - 0 197 Current_Pending_Sector -O--CK 200 200 000 - 0 198 Offline_Uncorrectable ----CK 200 200 000 - 0 199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0 200 Multi_Zone_Error_Rate ---R-- 200 200 000 - 5 ||||||_ K auto-keep |||||__ C event count ||||___ R error rate |||____ S speed/performance ||_____ O updated online |______ P prefailure warning General Purpose Log Directory Version 1 SMART Log Directory Version 1 [multi-sector log support] Address Access R/W Size Description 0x00 GPL,SL R/O 1 Log Directory 0x01 SL R/O 1 Summary SMART error log 0x02 SL R/O 5 Comprehensive SMART error log 0x03 GPL R/O 6 Ext. Comprehensive SMART error log 0x04 GPL,SL R/O 8 Device Statistics log 0x06 SL R/O 1 SMART self-test log 0x07 GPL R/O 1 Extended self-test log 0x09 SL R/W 1 Selective self-test log 0x0c GPL R/O 2048 Pending Defects log 0x10 GPL R/O 1 NCQ Command Error log 0x11 GPL R/O 1 SATA Phy Event Counters log 0x21 GPL R/O 1 Write stream error log 0x22 GPL R/O 1 Read stream error log 0x80-0x9f GPL,SL R/W 16 Host vendor specific log 0xa0-0xa7 GPL,SL VS 16 Device vendor specific log 0xa8-0xb7 GPL,SL VS 1 Device vendor specific log 0xbd GPL,SL VS 1 Device vendor specific log 0xc0 GPL,SL VS 1 Device vendor specific log 0xc1 GPL VS 93 Device vendor specific log 0xe0 GPL,SL R/W 1 SCT Command/Status 0xe1 GPL,SL R/W 1 SCT Data Transfer SMART Extended Comprehensive Error Log Version: 1 (6 sectors) No Errors Logged SMART Extended Self-test Log Version: 1 (1 sectors) Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed: read failure 90% 15494 20926296 # 2 Conveyance offline Completed without error 00% 15494 - # 3 Extended offline Completed: read failure 90% 15480 20926296 # 4 Short offline Completed without error 00% 15322 - # 5 Extended offline Completed: read failure 90% 14983 19610584 # 6 Short offline Completed: read failure 10% 14817 20932976 # 7 Extended offline Completed: read failure 90% 14443 35980480 # 8 Short offline Completed without error 00% 14287 - # 9 Extended offline Completed without error 00% 13997 - #10 Short offline Completed without error 00% 13839 - #11 Extended offline Completed without error 00% 13499 - #12 Short offline Completed without error 00% 13330 - #13 Extended offline Completed without error 00% 12982 - #14 Short offline Completed without error 00% 12801 - #15 Extended offline Completed without error 00% 12472 - #16 Short offline Completed without error 00% 12305 - #17 Extended offline Interrupted (host reset) 70% 12007 - #18 Short offline Completed without error 00% 11847 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. SCT Status Version: 3 SCT Version (vendor specific): 258 (0x0102) SCT Support Level: 1 Device State: Active (0) Current Temperature: 38 Celsius Power Cycle Min/Max Temperature: 28/38 Celsius Lifetime Min/Max Temperature: 2/45 Celsius Under/Over Temperature Limit Count: 0/0 Vendor specific: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 SCT Temperature History Version: 2 Temperature Sampling Period: 1 minute Temperature Logging Interval: 1 minute Min/Max recommended Temperature: 0/60 Celsius Min/Max Temperature Limit: -41/85 Celsius Temperature History Size (Index): 478 (11) Index Estimated Time Temperature Celsius 12 2019-09-22 06:30 38 ******************* ... ..(100 skipped). .. ******************* 113 2019-09-22 08:11 38 ******************* 114 2019-09-22 08:12 37 ****************** ... ..( 85 skipped). .. ****************** 200 2019-09-22 09:38 37 ****************** 201 2019-09-22 09:39 38 ******************* ... ..( 67 skipped). .. ******************* 269 2019-09-22 10:47 38 ******************* 270 2019-09-22 10:48 ? - 271 2019-09-22 10:49 33 ************** ... ..( 2 skipped). .. ************** 274 2019-09-22 10:52 33 ************** 275 2019-09-22 10:53 34 *************** 276 2019-09-22 10:54 34 *************** 277 2019-09-22 10:55 34 *************** 278 2019-09-22 10:56 35 **************** ... ..( 4 skipped). .. **************** 283 2019-09-22 11:01 35 **************** 284 2019-09-22 11:02 36 ***************** ... ..( 8 skipped). .. ***************** 293 2019-09-22 11:11 36 ***************** 294 2019-09-22 11:12 ? - 295 2019-09-22 11:13 28 ********* 296 2019-09-22 11:14 28 ********* 297 2019-09-22 11:15 28 ********* 298 2019-09-22 11:16 29 ********** 299 2019-09-22 11:17 29 ********** 300 2019-09-22 11:18 30 *********** 301 2019-09-22 11:19 30 *********** 302 2019-09-22 11:20 31 ************ ... ..( 5 skipped). .. ************ 308 2019-09-22 11:26 31 ************ 309 2019-09-22 11:27 32 ************* ... ..( 2 skipped). .. ************* 312 2019-09-22 11:30 32 ************* 313 2019-09-22 11:31 33 ************** ... ..( 2 skipped). .. ************** 316 2019-09-22 11:34 33 ************** 317 2019-09-22 11:35 34 *************** ... ..( 4 skipped). .. *************** 322 2019-09-22 11:40 34 *************** 323 2019-09-22 11:41 35 **************** ... ..( 6 skipped). .. **************** 330 2019-09-22 11:48 35 **************** 331 2019-09-22 11:49 36 ***************** ... ..( 12 skipped). .. ***************** 344 2019-09-22 12:02 36 ***************** 345 2019-09-22 12:03 37 ****************** ... ..( 27 skipped). .. ****************** 373 2019-09-22 12:31 37 ****************** 374 2019-09-22 12:32 38 ******************* ... ..(114 skipped). .. ******************* 11 2019-09-22 14:27 38 ******************* SCT Error Recovery Control: Read: 70 (7.0 seconds) Write: 70 (7.0 seconds) Device Statistics (GP Log 0x04) Page Offset Size Value Flags Description 0x01 ===== = = === == General Statistics (rev 2) == 0x01 0x008 4 540 --- Lifetime Power-On Resets 0x01 0x010 4 15500 --- Power-on Hours 0x01 0x018 6 43405333039 --- Logical Sectors Written 0x01 0x020 6 826831796 --- Number of Write Commands 0x01 0x028 6 75064862725 --- Logical Sectors Read 0x01 0x030 6 581313517 --- Number of Read Commands 0x03 ===== = = === == Rotating Media Statistics (rev 1) == 0x03 0x008 4 14454 --- Spindle Motor Power-on Hours 0x03 0x010 4 14414 --- Head Flying Hours 0x03 0x018 4 759 --- Head Load Events 0x03 0x020 4 0 --- Number of Reallocated Logical Sectors 0x03 0x028 4 355 --- Read Recovery Attempts 0x03 0x030 4 0 --- Number of Mechanical Start Failures 0x04 ===== = = === == General Errors Statistics (rev 1) == 0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors 0x04 0x010 4 196611 --- Resets Between Cmd Acceptance and Completion 0x05 ===== = = === == Temperature Statistics (rev 1) == 0x05 0x008 1 37 --- Current Temperature 0x05 0x010 1 36 --- Average Short Term Temperature 0x05 0x018 1 36 --- Average Long Term Temperature 0x05 0x020 1 44 --- Highest Temperature 0x05 0x028 1 21 --- Lowest Temperature 0x05 0x030 1 42 --- Highest Average Short Term Temperature 0x05 0x038 1 26 --- Lowest Average Short Term Temperature 0x05 0x040 1 36 --- Highest Average Long Term Temperature 0x05 0x048 1 27 --- Lowest Average Long Term Temperature 0x05 0x050 4 0 --- Time in Over-Temperature 0x05 0x058 1 60 --- Specified Maximum Operating Temperature 0x05 0x060 4 0 --- Time in Under-Temperature 0x05 0x068 1 0 --- Specified Minimum Operating Temperature 0x06 ===== = = === == Transport Statistics (rev 1) == 0x06 0x008 4 2059 --- Number of Hardware Resets 0x06 0x010 4 447791 --- Number of ASR Events 0x06 0x018 4 0 --- Number of Interface CRC Errors |||_ C monitored condition met ||__ D supports DSN |___ N normalized value Pending Defects log (GP Log 0x0c) supported [please try: '-l defects'] SATA Phy Event Counters (GP Log 0x11) ID Size Value Description 0x0001 2 0 Command failed due to ICRC error 0x0002 2 0 R_ERR response for data FIS 0x0003 2 0 R_ERR response for device-to-host data FIS 0x0004 2 0 R_ERR response for host-to-device data FIS 0x0005 2 0 R_ERR response for non-data FIS 0x0006 2 0 R_ERR response for device-to-host non-data FIS 0x0007 2 0 R_ERR response for host-to-device non-data FIS 0x0008 2 0 Device-to-host non-data FIS retries 0x0009 2 2 Transition from drive PhyRdy to drive PhyNRdy 0x000a 2 3 Device-to-host register FISes sent due to a COMRESET 0x000b 2 0 CRC errors within host-to-device FIS 0x000f 2 0 R_ERR response for host-to-device data FIS, CRC 0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC 0x8000 4 25013 Vendor specific
