Just so you know... I am not immune to failure.
Chris Moore
I hope this can be a learning experience for everyone.
I got home from work last night to find this waiting for me:
TrueNAS @ Emily-NAS.home
New alerts:
* Device: /dev/da8 [SAT], Self-Test Log error count increased from 0 to 1.
Current alerts:
* Device: /dev/da8 [SAT], 872 Currently unreadable (pending) sectors.
* Device: /dev/da8 [SAT], 92 Offline uncorrectable sectors.
The drive in question is a 6TB WD Gold. Here is the output of the SMART report:
root@Emily-NAS:~/scripts # smartctl -x /dev/da8
smartctl 7.1 2019-12-30 r5022 [FreeBSD 12.2-RELEASE-p2 amd64] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Gold
Device Model:     WDC WD6002FRYZ-01WD5B0
Serial Number:    xxxxxxxx
LU WWN Device Id: 5 000cca 255e8ef91
Firmware Version: 01.01M02
User Capacity:    6,001,175,126,016 bytes [6.00 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Dec 24 02:02:46 2020 CST
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Disabled
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
Self-test execution status:      ( 121) The previous self-test completed having
                                        the read element of the test failed.
data collection:                (  113) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 813) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     PO-R--   100   100   016    -    0
  2 Throughput_Performance  P-S---   137   137   054    -    104
  3 Spin_Up_Time            POS---   132   132   024    -    501 (Average 498)
  4 Start_Stop_Count        -O--C-   100   100   000    -    18
  5 Reallocated_Sector_Ct   PO--CK   100   100   005    -    0
  7 Seek_Error_Rate         PO-R--   100   100   067    -    0
  8 Seek_Time_Performance   P-S---   128   128   020    -    18
  9 Power_On_Hours          -O--C-   097   097   000    -    21258
10 Spin_Retry_Count        PO--C-   100   100   060    -    0
12 Power_Cycle_Count       -O--CK   100   100   000    -    18
192 Power-Off_Retract_Count -O--CK   089   089   000    -    13724
193 Load_Cycle_Count        -O--C-   089   089   000    -    13724
194 Temperature_Celsius     -O----   157   157   000    -    38 (Min/Max 23/50)
196 Reallocated_Event_Count -O--CK   100   100   000    -    0
197 Current_Pending_Sector  -O---K   100   100   000    -    872
198 Offline_Uncorrectable   ---R--   100   100   000    -    92
199 UDMA_CRC_Error_Count    -O-R--   200   200   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      1  Comprehensive SMART error log
0x03       GPL     R/O      1  Ext. Comprehensive SMART error log
0x04       GPL,SL  R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x08       GPL     R/O      2  Power Conditions log
0x09           SL  R/W      1  Selective self-test log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x12       GPL     R/O      1  SATA NCQ Non-Data log
0x15       GPL,SL  R/W      1  Rebuild Assist log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x24       GPL     R/O    256  Current Device Internal Status Data log
0x25       GPL     R/O    256  Saved Device Internal Status Data log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Short offline       Completed: read failure       90%     21257         201727992
# 2  Short offline       Completed: read failure       90%     21256         201727992
# 3  Short offline       Completed: read failure       90%     21255         201727992
# 4  Extended offline    Completed without error       00%     21201         -
# 5  Short offline       Completed without error       00%     21040         -
# 6  Short offline       Completed without error       00%     21016         -
# 7  Extended offline    Interrupted (host reset)      10%     21000         -
# 8  Short offline       Completed without error       00%     20920         -
# 9  Extended offline    Completed without error       00%     20893         -
#10  Short offline       Completed without error       00%     20872         -
#11  Short offline       Completed without error       00%     20848         -
#12  Short offline       Completed without error       00%     20825         -
#13  Short offline       Completed without error       00%     20800         -
#14  Extended offline    Completed without error       00%     20773         -
#15  Short offline       Completed without error       00%     20752         -
#16  Extended offline    Completed without error       00%     20725         -
#17  Short offline       Completed without error       00%     20704         -
#18  Short offline       Completed without error       00%     20680         -
#19  Short offline       Completed without error       00%     20656         -
SCT Status Version:                  3
SCT Version (vendor specific):       256 (0x0100)
Device State:                        Active (0)
Current Temperature:                    38 Celsius
Power Cycle Min/Max Temperature:     33/42 Celsius
Lifetime    Min/Max Temperature:     23/50 Celsius
Under/Over Temperature Limit Count:   0/0
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/60 Celsius
Min/Max Temperature Limit:           -40/70 Celsius
Temperature History Size (Index):    128 (72)
Index    Estimated Time   Temperature Celsius
  73    2020-12-23 23:55    39  ********************
...    ..( 10 skipped).    ..  ********************
  84    2020-12-24 00:06    39  ********************
  85    2020-12-24 00:07    38  *******************
...    ..(  2 skipped).    ..  *******************
  88    2020-12-24 00:10    38  *******************
  89    2020-12-24 00:11    39  ********************
100    2020-12-24 00:22    39  ********************
101    2020-12-24 00:23    38  *******************
104    2020-12-24 00:26    38  *******************
105    2020-12-24 00:27    39  ********************
116    2020-12-24 00:38    39  ********************
117    2020-12-24 00:39    38  *******************
120    2020-12-24 00:42    38  *******************
121    2020-12-24 00:43    39  ********************
...    ..(  9 skipped).    ..  ********************
   3    2020-12-24 00:53    39  ********************
   4    2020-12-24 00:54    38  *******************
...    ..(  4 skipped).    ..  *******************
   9    2020-12-24 00:59    38  *******************
  10    2020-12-24 01:00    39  ********************
...    ..(  8 skipped).    ..  ********************
  19    2020-12-24 01:09    39  ********************
  20    2020-12-24 01:10    38  *******************
  25    2020-12-24 01:15    38  *******************
  26    2020-12-24 01:16    39  ********************
  36    2020-12-24 01:26    39  ********************
  37    2020-12-24 01:27    38  *******************
  40    2020-12-24 01:30    38  *******************
  41    2020-12-24 01:31    39  ********************
  52    2020-12-24 01:42    39  ********************
  53    2020-12-24 01:43    38  *******************
...    ..(  3 skipped).    ..  *******************
  57    2020-12-24 01:47    38  *******************
  58    2020-12-24 01:48    39  ********************
  68    2020-12-24 01:58    39  ********************
  69    2020-12-24 01:59    38  *******************
  72    2020-12-24 02:02    38  *******************
SCT Error Recovery Control:
           Read: Disabled
          Write: Disabled
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 2) ==
0x01  0x008  4              18  ---  Lifetime Power-On Resets
0x01  0x018  6     95709559001  ---  Logical Sectors Written
0x01  0x020  6       576804347  ---  Number of Write Commands
0x01  0x028  6    170622385595  ---  Logical Sectors Read
0x01  0x030  6       756275089  ---  Number of Read Commands
0x01  0x038  6     76529512400  ---  Date and Time TimeStamp
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4           17358  ---  Spindle Motor Power-on Hours
0x03  0x010  4           17358  ---  Head Flying Hours
0x03  0x018  4           13724  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4          210428  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4               0  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              38  ---  Current Temperature
0x05  0x010  1              38  N--  Average Short Term Temperature
0x05  0x018  1              37  N--  Average Long Term Temperature
0x05  0x020  1              50  ---  Highest Temperature
0x05  0x028  1              23  ---  Lowest Temperature
0x05  0x030  1              48  N--  Highest Average Short Term Temperature
0x05  0x038  1              25  N--  Lowest Average Short Term Temperature
0x05  0x040  1              47  N--  Highest Average Long Term Temperature
0x05  0x048  1              25  N--  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              60  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               0  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4               4  ---  Number of Hardware Resets
0x06  0x010  4               0  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0002  2            0  R_ERR response for data FIS
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0005  2            0  R_ERR response for non-data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
0x0008  2            0  Device-to-host non-data FIS retries
0x0009  2            4  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2            5  Device-to-host register FISes sent due to a COMRESET
0x000b  2            0  CRC errors within host-to-device FIS
0x000d  2            0  Non-CRC errors within host-to-device FIS
It should still be in warranty, so I will send it in. The problem... I failed to follow my own advice. I don't have a spare on hand for this drive.
joeschmuck
Old Man
We all make mistakes, we are only human. Well that is what they say to make a person feel good. You should feel like crap for not having an extra drive on hand, I mean you have a pallet of hard drives in the garage, right? LOL Just kidding of course. Tis' the season to laugh. I do not have a spare drive, if I come across a failure then I will just turn off my machine until a replacement comes in the mail. I also really like the advance replacement that some companies offer so I don't have to send a drive in for RMA until after I have a replacement in hand. It means giving them my credit card in advance but I get a return box and return label for free.
Best of luck to you.
Chris Moore
LOL
I have a couple boxes with drives in them, but not this size. I have 250GB, 500GB, 750GB, 1TB, 2TB, 4TB, I even found an 80GB, but no 6TB drives.
I thought I had them, but no...
Really, this is what is on my dining table right now:
That is a good idea. I wasn't thinking that way because I normally keep a spare. Thanks.
