I did that but sadly, no luck - still no video playback.I see the port got updated last week. I have modified the script to use latest version. Can you try it with that?
someone else noted not being able to play videos earlier in this thread.Wondering if it has anything to do with the 12.4 Release.
I changed the script to use 13.2
Can you try that?
Although at this point I'm assuming it might have something to do with your hardware, because I haven't seen that issue. I don't use PhotoPrism so that might be why, but I did do some testing while creating the script.
Are you inside the jail?Well shoot... following the guide and I am at this step:
Edit a file called /mnt/photos/options.yml:
micro /mnt/photos/options.yml
iocage console <jailname>?You can try to install photo prism using the script linked to in my signature.Well shoot... following the guide and I am at this step:
I'm in the editor and put all the info in:
# options.yml
AuthMode: public #[OPTIONAL]
AssetsPath: /var/db/photoprism/assets
StoragePath: /mnt/photos
OriginalsPath: /mnt/photos/originals
ImportPath: /mnt/photos/import
# The following lines are only needed if you set up the
# optional MariaDB server
DatabaseDriver: mysql
DatabaseName: photoprism
DatabaseServer: "127.0.0.1:3306"
DatabaseUser: photoprism
DatabasePassword: CHANGEME
But when I try to exit the editor I get:
"Parent dirs don't exist, enable 'mkparents' for auto creation"
Not sure what next... I'm sure it's simple!
Any guidance?
mkdir -p /mnt/photosGetting further... appears the mkdir for the photos and originals is getting me further..You can try to install photo prism using the script linked to in my signature.
Otherwise the command to create a directory would bemkdir -p /mnt/photos
You should set "/mnt/MyNas/iocage/jails/photos/root/photos" as destination on mount.Ugg... now when I try to scan Photos it says the Originals folder is empty.......... if I navigate to the originals folder via Sharing, it shows everything there.....
Destination for the mount points is /mnt/MyNas/iocage/jails/photos/root/photos/originals
