due to unknown reasons my TrueNAS scale pool lost a drive. I've replaced it and noticed that the system can't replace the drive. I left with the following status:
So as you can see the pool is not visible when tryig to list it - anyhow when i issue import command - i can see it.
I was trying to import it using
anyhow it shows the following error:
anyhow after issuing import with -f oprion the cmd freezes and the following errors are visible in logs:
Can you please offer me some hints how i could restore this storage?
thanks in advance!
BR,
MCC
admin@truenas:~$ sudo zpool import pool: storage id: 3743818536692763833 state: DEGRADED status: One or more devices were being resilvered. action: The pool can be imported despite missing or damaged devices. The fault tolerance of the pool may be compromised if imported. config: storage DEGRADED raidz1-0 DEGRADED 1dfff5e5-c3d7-4a66-a880-16a844bbd7a2 ONLINE 21141c85-a074-4a23-98ce-b0d9a3336ceb ONLINE ab95ebc6-2ed8-11ea-a963-fcaa142a1593 UNAVAIL 923db6a0-3207-11ea-b9f1-fcaa142a1593 ONLINE admin@truenas:~$ admin@truenas:~$ sudo zpool list NAME SIZE ALLOC FREE CKPOINT EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT boot-pool 14G 5.23G 8.77G - - 3% 37% 1.00x ONLINE - admin@truenas:~$
admin@truenas:~$ sudo zpool import -F -a -n
admin@truenas:~$ sudo zpool import -F -a -n cannot import 'storage': pool was previously in use from another system. Last accessed by freenas (hostid=32333165) at Wed Sep 6 16:59:54 2023 The pool can be imported, use 'zpool import -f' to import the pool. admin@truenas:~$
Sep 21 10:31:20 truenas zed[74925]: eid=15 class=data pool='storage' priority=0 err=52 flags=0x808081 bookmark=0:115249:0:3 Sep 21 10:31:20 truenas zed[74930]: eid=16 class=checksum pool='storage' vdev=923db6a0-3207-11ea-b9f1-fcaa142a1593 size=28672 offset=850561347584 priority=0 err=52 flags=0x100080 bookmark=0:115249:0:3 Sep 21 10:31:20 truenas zed[74937]: eid=18 class=checksum pool='storage' vdev=21141c85-a074-4a23-98ce-b0d9a3336ceb size=28672 offset=1805837819904 priority=0 err=52 flags=0x100080 bookmark=0:115249:0:3 Sep 21 10:31:20 truenas zed[74934]: eid=17 class=checksum pool='storage' vdev=21141c85-a074-4a23-98ce-b0d9a3336ceb size=28672 offset=850561347584 priority=0 err=52 flags=0x100080 bookmark=0:115249:0:3 Sep 21 10:31:20 truenas zed[74940]: eid=21 class=checksum pool='storage' vdev=21141c85-a074-4a23-98ce-b0d9a3336ceb size=28672 offset=973714276352 priority=0 err=52 flags=0x100080 bookmark=0:115249:0:3 Sep 21 10:31:20 truenas zed[74941]: eid=20 class=checksum pool='storage' vdev=923db6a0-3207-11ea-b9f1-fcaa142a1593 size=28672 offset=973714276352 priority=0 err=52 flags=0x100080 bookmark=0:115249:0:3 Sep 21 10:31:20 truenas zed[74942]: eid=19 class=checksum pool='storage' vdev=923db6a0-3207-11ea-b9f1-fcaa142a1593 size=28672 offset=1805837815808 priority=0 err=52 flags=0x100080 bookmark=0:115249:0:3 Sep 21 10:31:21 truenas zed[74950]: eid=22 class=data pool='storage' priority=0 err=52 flags=0x808081 bookmark=0:116307:0:2 Sep 21 10:31:21 truenas zed[74955]: eid=27 class=checksum pool='storage' vdev=923db6a0-3207-11ea-b9f1-fcaa142a1593 size=8192 offset=973946433536 priority=0 err=52 flags=0x100080 bookmark=0:116307:0:2 Sep 21 10:31:21 truenas zed[74959]: eid=26 class=checksum pool='storage' vdev=923db6a0-3207-11ea-b9f1-fcaa142a1593 size=8192 offset=1451735969792 priority=0 err=52 flags=0x100080 bookmark=0:116307:0:2 Sep 21 10:31:21 truenas zed[74961]: eid=23 class=checksum pool='storage' vdev=21141c85-a074-4a23-98ce-b0d9a3336ceb size=8192 offset=1456541413376 priority=0 err=52 flags=0x100080 bookmark=0:116307:0:2 Sep 21 10:31:21 truenas zed[74963]: eid=25 class=checksum pool='storage' vdev=21141c85-a074-4a23-98ce-b0d9a3336ceb size=8192 offset=1451735973888 priority=0 err=52 flags=0x100080 bookmark=0:116307:0:2 Sep 21 10:31:21 truenas zed[74962]: eid=24 class=checksum pool='storage' vdev=923db6a0-3207-11ea-b9f1-fcaa142a1593 size=8192 offset=1456541409280 priority=0 err=52 flags=0x100080 bookmark=0:116307:0:2 Sep 21 10:31:21 truenas zed[74964]: eid=28 class=checksum pool='storage' vdev=21141c85-a074-4a23-98ce-b0d9a3336ceb size=8192 offset=973946433536 priority=0 err=52 flags=0x100080 bookmark=0:116307:0:2 Sep 21 10:31:23 truenas kernel: WARNING: Pool 'storage' has encountered an uncorrectable I/O failure and has been suspended. Sep 21 10:31:23 truenas zed[74976]: eid=29 class=data pool='storage' priority=0 err=52 flags=0x808001 bookmark=0:119186:0:5 Sep 21 10:31:23 truenas zed[74977]: eid=30 class=io_failure pool='storage' Sep 21 10:31:23 truenas zed[74976]: eid=29 class=data pool='storage' priority=0 err=52 flags=0x808001 bookmark=0:119186:0:5 Sep 21 10:31:23 truenas zed[74977]: eid=30 class=io_failure pool='storage' Sep 21 10:35:19 truenas kernel: INFO: task middlewared (wo:53916 blocked for more than 120 seconds. Sep 21 10:35:19 truenas kernel: Tainted: P OE 6.1.42-production+truenas #2 Sep 21 10:35:19 truenas kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. Sep 21 10:35:19 truenas kernel: task:middlewared (wo state:D stack:0 pid:53916 ppid:1432 flags:0x00000002 Sep 21 10:35:19 truenas kernel: Call Trace: Sep 21 10:35:19 truenas kernel: <TASK> Sep 21 10:35:19 truenas kernel: __schedule+0x2ed/0x860 Sep 21 10:35:19 truenas kernel: schedule+0x5a/0xb0 Sep 21 10:35:19 truenas kernel: schedule_preempt_disabled+0x14/0x30 Sep 21 10:35:19 truenas kernel: __mutex_lock.constprop.0+0x3b4/0x700 Sep 21 10:35:19 truenas kernel: spa_open_common+0x65/0x440 [zfs] Sep 21 10:35:19 truenas kernel: spa_get_stats+0x4a/0x210 [zfs] Sep 21 10:35:19 truenas kernel: ? spl_kmem_alloc_impl+0x87/0xd0 [spl] Sep 21 10:35:19 truenas kernel: zfs_ioc_pool_stats+0x3c/0x90 [zfs] Sep 21 10:35:19 truenas kernel: zfsdev_ioctl_common+0x67c/0x770 [zfs] Sep 21 10:35:19 truenas kernel: ? __kmalloc_node+0xbf/0x150 Sep 21 10:35:19 truenas kernel: zfsdev_ioctl+0x4f/0xd0 [zfs] Sep 21 10:35:19 truenas kernel: __x64_sys_ioctl+0x8d/0xd0 Sep 21 10:35:19 truenas kernel: do_syscall_64+0x58/0xc0 Sep 21 10:35:19 truenas kernel: ? syscall_exit_to_user_mode+0x17/0x40 Sep 21 10:35:19 truenas kernel: ? syscall_exit_to_user_mode+0x17/0x40 Sep 21 10:35:19 truenas kernel: ? do_syscall_64+0x67/0xc0 Sep 21 10:35:19 truenas kernel: ? syscall_exit_to_user_mode+0x17/0x40 Sep 21 10:35:19 truenas kernel: ? do_syscall_64+0x67/0xc0 Sep 21 10:35:19 truenas kernel: ? syscall_exit_to_user_mode+0x17/0x40 Sep 21 10:35:19 truenas kernel: ? do_syscall_64+0x67/0xc0 Sep 21 10:35:19 truenas kernel: ? do_syscall_64+0x67/0xc0 Sep 21 10:35:19 truenas kernel: entry_SYSCALL_64_after_hwframe+0x63/0xcd Sep 21 10:35:19 truenas kernel: RIP: 0033:0x7ffa5a1d2afb Sep 21 10:35:19 truenas kernel: RSP: 002b:00007ffe0d773c50 EFLAGS: 00000246 ORIG_RAX: 0000000000000010 Sep 21 10:35:19 truenas kernel: RAX: ffffffffffffffda RBX: 0000000003c42290 RCX: 00007ffa5a1d2afb Sep 21 10:35:19 truenas kernel: RDX: 00007ffe0d773cd0 RSI: 0000000000005a05 RDI: 0000000000000019 Sep 21 10:35:19 truenas kernel: RBP: 00007ffe0d7772c0 R08: 00007ffa5a2a8430 R09: 00007ffa5a2a8430 Sep 21 10:35:19 truenas kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 00007ffe0d773cd0 Sep 21 10:35:19 truenas kernel: R13: 0000000003c42290 R14: 0000000004c83fc0 R15: 00007ffe0d7772d4 Sep 21 10:35:19 truenas kernel: </TASK> Sep 21 10:35:19 truenas kernel: INFO: task zpool:74731 blocked for more than 120 seconds. Sep 21 10:35:19 truenas kernel: Tainted: P OE 6.1.42-production+truenas #2 Sep 21 10:35:19 truenas kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. Sep 21 10:35:19 truenas kernel: task:zpool state:D stack:0 pid:74731 ppid:74730 flags:0x00004002 Sep 21 10:35:19 truenas kernel: Call Trace: Sep 21 10:35:19 truenas kernel: <TASK> Sep 21 10:35:19 truenas kernel: __schedule+0x2ed/0x860 Sep 21 10:35:19 truenas kernel: schedule+0x5a/0xb0 Sep 21 10:35:19 truenas kernel: io_schedule+0x42/0x70 Sep 21 10:35:19 truenas kernel: cv_wait_common+0xaa/0x130 [spl] Sep 21 10:35:19 truenas kernel: ? cpuusage_read+0x10/0x10 Sep 21 10:35:19 truenas kernel: txg_wait_synced_impl+0xc0/0x110 [zfs] Sep 21 10:35:19 truenas kernel: txg_wait_synced+0xc/0x40 [zfs] Sep 21 10:35:19 truenas kernel: spa_load_impl.constprop.0+0x281/0x3c0 [zfs] Sep 21 10:35:19 truenas kernel: spa_load+0x64/0x120 [zfs] Sep 21 10:35:19 truenas kernel: spa_load_best+0x54/0x250 [zfs] Sep 21 10:35:19 truenas kernel: spa_import+0x22d/0x680 [zfs] Sep 21 10:35:19 truenas kernel: zfs_ioc_pool_import+0x157/0x180 [zfs] Sep 21 10:35:19 truenas kernel: zfsdev_ioctl_common+0x67c/0x770 [zfs] Sep 21 10:35:19 truenas kernel: ? __kmalloc_node+0xbf/0x150 Sep 21 10:35:19 truenas kernel: zfsdev_ioctl+0x4f/0xd0 [zfs] Sep 21 10:35:19 truenas kernel: __x64_sys_ioctl+0x8d/0xd0 Sep 21 10:35:19 truenas kernel: do_syscall_64+0x58/0xc0 Sep 21 10:35:19 truenas kernel: ? __irq_exit_rcu+0x2d/0x130 Sep 21 10:35:19 truenas kernel: entry_SYSCALL_64_after_hwframe+0x63/0xcd Sep 21 10:35:19 truenas kernel: RIP: 0033:0x7f0674abeafb Sep 21 10:35:19 truenas kernel: RSP: 002b:00007ffeefec83f0 EFLAGS: 00000246 ORIG_RAX: 0000000000000010 Sep 21 10:35:19 truenas kernel: RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f0674abeafb Sep 21 10:35:19 truenas kernel: RDX: 00007ffeefec84b0 RSI: 0000000000005a02 RDI: 0000000000000003 Sep 21 10:35:19 truenas kernel: RBP: 00007ffeefecc3a0 R08: 00007f0674b94430 R09: 00007f0674b94430 Sep 21 10:35:19 truenas kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 00005578fa674dd0 Sep 21 10:35:19 truenas kernel: R13: 00007ffeefec84b0 R14: 00007f065c00a270 R15: 00005578fa7370a0 Sep 21 10:35:19 truenas kernel: </TASK> Sep 21 10:35:19 truenas kernel: INFO: task txg_sync:74913 blocked for more than 120 seconds. Sep 21 10:35:19 truenas kernel: Tainted: P OE 6.1.42-production+truenas #2 Sep 21 10:35:19 truenas kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. Sep 21 10:35:19 truenas kernel: task:txg_sync state:D stack:0 pid:74913 ppid:2 flags:0x00004000 Sep 21 10:35:19 truenas kernel: Call Trace: Sep 21 10:35:19 truenas kernel: <TASK> Sep 21 10:35:19 truenas kernel: __schedule+0x2ed/0x860 Sep 21 10:35:19 truenas kernel: schedule+0x5a/0xb0 Sep 21 10:35:19 truenas kernel: schedule_timeout+0x94/0x150 Sep 21 10:35:19 truenas kernel: ? __bpf_trace_tick_stop+0x10/0x10 Sep 21 10:35:19 truenas kernel: io_schedule_timeout+0x4c/0x80 Sep 21 10:35:19 truenas kernel: __cv_timedwait_common+0x12a/0x160 [spl] Sep 21 10:35:19 truenas kernel: ? cpuusage_read+0x10/0x10 Sep 21 10:35:19 truenas kernel: __cv_timedwait_io+0x15/0x20 [spl] Sep 21 10:35:19 truenas kernel: zio_wait+0x10b/0x220 [zfs] Sep 21 10:35:19 truenas kernel: dmu_buf_will_dirty_impl+0xb1/0x190 [zfs] Sep 21 10:35:19 truenas kernel: dmu_write_impl+0x3f/0xd0 [zfs] Sep 21 10:35:19 truenas kernel: dmu_write+0xb2/0x110 [zfs] Sep 21 10:35:19 truenas kernel: space_map_write_intro_debug+0xaf/0xe0 [zfs] Sep 21 10:35:19 truenas kernel: space_map_write_impl+0x54/0x250 [zfs] Sep 21 10:35:19 truenas kernel: ? list_head+0x9/0x30 [zfs] Sep 21 10:35:19 truenas kernel: ? dmu_buf_will_dirty_impl+0x11a/0x190 [zfs] Sep 21 10:35:19 truenas kernel: space_map_write+0x9a/0x190 [zfs] Sep 21 10:35:19 truenas kernel: metaslab_flush+0xed/0x320 [zfs] Sep 21 10:35:19 truenas kernel: ? spa_estimate_metaslabs_to_flush+0x108/0x130 [zfs] Sep 21 10:35:19 truenas kernel: spa_flush_metaslabs+0x14e/0x200 [zfs] Sep 21 10:35:19 truenas kernel: ? preempt_count_add+0x6a/0xa0 Sep 21 10:35:19 truenas kernel: spa_sync_iterate_to_convergence+0x157/0x200 [zfs] Sep 21 10:35:19 truenas kernel: spa_sync+0x306/0x5d0 [zfs] Sep 21 10:35:19 truenas kernel: txg_sync_thread+0x1e4/0x250 [zfs] Sep 21 10:35:19 truenas kernel: ? txg_dispatch_callbacks+0xf0/0xf0 [zfs] Sep 21 10:35:19 truenas kernel: ? sigorsets+0x10/0x10 [spl] Sep 21 10:35:19 truenas kernel: thread_generic_wrapper+0x57/0x70 [spl] Sep 21 10:35:19 truenas kernel: kthread+0xe6/0x110 Sep 21 10:35:19 truenas kernel: ? kthread_complete_and_exit+0x20/0x20 Sep 21 10:35:19 truenas kernel: ret_from_fork+0x1f/0x30 Sep 21 10:35:19 truenas kernel: </TASK> Sep 21 10:35:19 truenas kernel: INFO: task zpool:74987 blocked for more than 120 seconds. Sep 21 10:35:19 truenas kernel: Tainted: P OE 6.1.42-production+truenas #2 Sep 21 10:35:19 truenas kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. Sep 21 10:35:19 truenas kernel: task:zpool state:D stack:0 pid:74987 ppid:74986 flags:0x00000002 Sep 21 10:35:19 truenas kernel: Call Trace: Sep 21 10:35:19 truenas kernel: <TASK> Sep 21 10:35:19 truenas kernel: __schedule+0x2ed/0x860 Sep 21 10:35:19 truenas kernel: schedule+0x5a/0xb0 Sep 21 10:35:19 truenas kernel: schedule_preempt_disabled+0x14/0x30 Sep 21 10:35:19 truenas kernel: __mutex_lock.constprop.0+0x3b4/0x700 Sep 21 10:35:19 truenas kernel: ? release_pages+0x168/0x4e0 Sep 21 10:35:19 truenas kernel: spa_open_common+0x65/0x440 [zfs] Sep 21 10:35:19 truenas kernel: spa_get_stats+0x4a/0x210 [zfs] Sep 21 10:35:19 truenas kernel: ? spl_kmem_alloc_impl+0x87/0xd0 [spl] Sep 21 10:35:19 truenas kernel: zfs_ioc_pool_stats+0x3c/0x90 [zfs] Sep 21 10:35:19 truenas kernel: zfsdev_ioctl_common+0x67c/0x770 [zfs] Sep 21 10:35:19 truenas kernel: ? __kmalloc_node+0xbf/0x150 Sep 21 10:35:19 truenas kernel: zfsdev_ioctl+0x4f/0xd0 [zfs] Sep 21 10:35:19 truenas kernel: __x64_sys_ioctl+0x8d/0xd0 Sep 21 10:35:19 truenas kernel: do_syscall_64+0x58/0xc0 Sep 21 10:35:19 truenas kernel: ? exc_page_fault+0x70/0x170 Sep 21 10:35:19 truenas kernel: entry_SYSCALL_64_after_hwframe+0x63/0xcd Sep 21 10:35:19 truenas kernel: RIP: 0033:0x7f15e739bafb Sep 21 10:35:19 truenas kernel: RSP: 002b:00007ffeba2a6b40 EFLAGS: 00000246 ORIG_RAX: 0000000000000010 Sep 21 10:35:19 truenas kernel: RAX: ffffffffffffffda RBX: 00005556a3485e50 RCX: 00007f15e739bafb Sep 21 10:35:19 truenas kernel: RDX: 00007ffeba2a6bc0 RSI: 0000000000005a05 RDI: 0000000000000004 Sep 21 10:35:19 truenas kernel: RBP: 00007ffeba2aa1b0 R08: 00005556a3485690 R09: 00007f15e7470d10 Sep 21 10:35:19 truenas kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 00007ffeba2a6bc0 Sep 21 10:35:19 truenas kernel: R13: 00005556a3485e50 R14: 00005556a347b2c0 R15: 00007ffeba2aa1c4 Sep 21 10:35:19 truenas kernel: </TASK> Sep 21 10:37:20 truenas kernel: INFO: task middlewared (wo:53916 blocked for more than 241 seconds. Sep 21 10:37:20 truenas kernel: Tainted: P OE 6.1.42-production+truenas #2 Sep 21 10:37:20 truenas kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. Sep 21 10:37:20 truenas kernel: task:middlewared (wo state:D stack:0 pid:53916 ppid:1432 flags:0x00000002 Sep 21 10:37:20 truenas kernel: Call Trace: Sep 21 10:37:20 truenas kernel: <TASK> Sep 21 10:37:20 truenas kernel: __schedule+0x2ed/0x860 Sep 21 10:37:20 truenas kernel: schedule+0x5a/0xb0 Sep 21 10:37:20 truenas kernel: schedule_preempt_disabled+0x14/0x30 Sep 21 10:37:20 truenas kernel: __mutex_lock.constprop.0+0x3b4/0x700 Sep 21 10:37:20 truenas kernel: spa_open_common+0x65/0x440 [zfs] Sep 21 10:37:20 truenas kernel: spa_get_stats+0x4a/0x210 [zfs] Sep 21 10:37:20 truenas kernel: ? spl_kmem_alloc_impl+0x87/0xd0 [spl] Sep 21 10:37:20 truenas kernel: zfs_ioc_pool_stats+0x3c/0x90 [zfs] Sep 21 10:37:20 truenas kernel: zfsdev_ioctl_common+0x67c/0x770 [zfs] Sep 21 10:37:20 truenas kernel: ? __kmalloc_node+0xbf/0x150 Sep 21 10:37:20 truenas kernel: zfsdev_ioctl+0x4f/0xd0 [zfs] Sep 21 10:37:20 truenas kernel: __x64_sys_ioctl+0x8d/0xd0 Sep 21 10:37:20 truenas kernel: do_syscall_64+0x58/0xc0 Sep 21 10:37:20 truenas kernel: ? syscall_exit_to_user_mode+0x17/0x40 Sep 21 10:37:20 truenas kernel: ? syscall_exit_to_user_mode+0x17/0x40 Sep 21 10:37:20 truenas kernel: ? do_syscall_64+0x67/0xc0 Sep 21 10:37:20 truenas kernel: ? syscall_exit_to_user_mode+0x17/0x40 Sep 21 10:37:20 truenas kernel: ? do_syscall_64+0x67/0xc0 Sep 21 10:37:20 truenas kernel: ? syscall_exit_to_user_mode+0x17/0x40 Sep 21 10:37:20 truenas kernel: ? do_syscall_64+0x67/0xc0 Sep 21 10:37:20 truenas kernel: ? do_syscall_64+0x67/0xc0 Sep 21 10:37:20 truenas kernel: entry_SYSCALL_64_after_hwframe+0x63/0xcd Sep 21 10:37:20 truenas kernel: RIP: 0033:0x7ffa5a1d2afb Sep 21 10:37:20 truenas kernel: RSP: 002b:00007ffe0d773c50 EFLAGS: 00000246 ORIG_RAX: 0000000000000010 Sep 21 10:37:20 truenas kernel: RAX: ffffffffffffffda RBX: 0000000003c42290 RCX: 00007ffa5a1d2afb Sep 21 10:37:20 truenas kernel: RDX: 00007ffe0d773cd0 RSI: 0000000000005a05 RDI: 0000000000000019 Sep 21 10:37:20 truenas kernel: RBP: 00007ffe0d7772c0 R08: 00007ffa5a2a8430 R09: 00007ffa5a2a8430 Sep 21 10:37:20 truenas kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 00007ffe0d773cd0 Sep 21 10:37:20 truenas kernel: R13: 0000000003c42290 R14: 0000000004c83fc0 R15: 00007ffe0d7772d4 Sep 21 10:37:20 truenas kernel: </TASK> Sep 21 10:37:20 truenas kernel: INFO: task zpool:74731 blocked for more than 241 seconds. Sep 21 10:37:20 truenas kernel: Tainted: P OE 6.1.42-production+truenas #2 Sep 21 10:37:20 truenas kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. Sep 21 10:37:20 truenas kernel: task:zpool state:D stack:0 pid:74731 ppid:74730 flags:0x00004002 Sep 21 10:37:20 truenas kernel: Call Trace: Sep 21 10:37:20 truenas kernel: <TASK> Sep 21 10:37:20 truenas kernel: __schedule+0x2ed/0x860 Sep 21 10:37:20 truenas kernel: schedule+0x5a/0xb0 Sep 21 10:37:20 truenas kernel: io_schedule+0x42/0x70 Sep 21 10:37:20 truenas kernel: cv_wait_common+0xaa/0x130 [spl] Sep 21 10:37:20 truenas kernel: ? cpuusage_read+0x10/0x10 Sep 21 10:37:20 truenas kernel: txg_wait_synced_impl+0xc0/0x110 [zfs] Sep 21 10:37:20 truenas kernel: txg_wait_synced+0xc/0x40 [zfs] Sep 21 10:37:20 truenas kernel: spa_load_impl.constprop.0+0x281/0x3c0 [zfs] Sep 21 10:37:20 truenas kernel: spa_load+0x64/0x120 [zfs] Sep 21 10:37:20 truenas kernel: spa_load_best+0x54/0x250 [zfs] Sep 21 10:37:20 truenas kernel: spa_import+0x22d/0x680 [zfs] Sep 21 10:37:20 truenas kernel: zfs_ioc_pool_import+0x157/0x180 [zfs] Sep 21 10:37:20 truenas kernel: zfsdev_ioctl_common+0x67c/0x770 [zfs] Sep 21 10:37:20 truenas kernel: ? __kmalloc_node+0xbf/0x150 Sep 21 10:37:20 truenas kernel: zfsdev_ioctl+0x4f/0xd0 [zfs] Sep 21 10:37:20 truenas kernel: __x64_sys_ioctl+0x8d/0xd0 Sep 21 10:37:20 truenas kernel: do_syscall_64+0x58/0xc0 Sep 21 10:37:20 truenas kernel: ? __irq_exit_rcu+0x2d/0x130 Sep 21 10:37:20 truenas kernel: entry_SYSCALL_64_after_hwframe+0x63/0xcd Sep 21 10:37:20 truenas kernel: RIP: 0033:0x7f0674abeafb Sep 21 10:37:20 truenas kernel: RSP: 002b:00007ffeefec83f0 EFLAGS: 00000246 ORIG_RAX: 0000000000000010 Sep 21 10:37:20 truenas kernel: RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f0674abeafb Sep 21 10:37:20 truenas kernel: RDX: 00007ffeefec84b0 RSI: 0000000000005a02 RDI: 0000000000000003 Sep 21 10:37:20 truenas kernel: RBP: 00007ffeefecc3a0 R08: 00007f0674b94430 R09: 00007f0674b94430 Sep 21 10:37:20 truenas kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 00005578fa674dd0 Sep 21 10:37:20 truenas kernel: R13: 00007ffeefec84b0 R14: 00007f065c00a270 R15: 00005578fa7370a0 Sep 21 10:37:20 truenas kernel: </TASK> Sep 21 10:37:20 truenas kernel: INFO: task zpool:74987 blocked for more than 241 seconds. Sep 21 10:37:20 truenas kernel: Tainted: P OE 6.1.42-production+truenas #2 Sep 21 10:37:20 truenas kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. Sep 21 10:37:20 truenas kernel: task:zpool state:D stack:0 pid:74987 ppid:74986 flags:0x00000002 Sep 21 10:37:20 truenas kernel: Call Trace: Sep 21 10:37:20 truenas kernel: <TASK> Sep 21 10:37:20 truenas kernel: __schedule+0x2ed/0x860 Sep 21 10:37:20 truenas kernel: schedule+0x5a/0xb0 Sep 21 10:37:20 truenas kernel: schedule_preempt_disabled+0x14/0x30 Sep 21 10:37:20 truenas kernel: __mutex_lock.constprop.0+0x3b4/0x700 Sep 21 10:37:20 truenas kernel: ? release_pages+0x168/0x4e0 Sep 21 10:37:20 truenas kernel: spa_open_common+0x65/0x440 [zfs] Sep 21 10:37:20 truenas kernel: spa_get_stats+0x4a/0x210 [zfs] Sep 21 10:37:20 truenas kernel: ? spl_kmem_alloc_impl+0x87/0xd0 [spl] Sep 21 10:37:20 truenas kernel: zfs_ioc_pool_stats+0x3c/0x90 [zfs] Sep 21 10:37:20 truenas kernel: zfsdev_ioctl_common+0x67c/0x770 [zfs] Sep 21 10:37:20 truenas kernel: ? __kmalloc_node+0xbf/0x150 Sep 21 10:37:20 truenas kernel: zfsdev_ioctl+0x4f/0xd0 [zfs] Sep 21 10:37:20 truenas kernel: __x64_sys_ioctl+0x8d/0xd0 Sep 21 10:37:20 truenas kernel: do_syscall_64+0x58/0xc0 Sep 21 10:37:20 truenas kernel: ? exc_page_fault+0x70/0x170 Sep 21 10:37:20 truenas kernel: entry_SYSCALL_64_after_hwframe+0x63/0xcd Sep 21 10:37:20 truenas kernel: RIP: 0033:0x7f15e739bafb Sep 21 10:37:20 truenas kernel: RSP: 002b:00007ffeba2a6b40 EFLAGS: 00000246 ORIG_RAX: 0000000000000010 Sep 21 10:37:20 truenas kernel: RAX: ffffffffffffffda RBX: 00005556a3485e50 RCX: 00007f15e739bafb Sep 21 10:37:20 truenas kernel: RDX: 00007ffeba2a6bc0 RSI: 0000000000005a05 RDI: 0000000000000004 Sep 21 10:37:20 truenas kernel: RBP: 00007ffeba2aa1b0 R08: 00005556a3485690 R09: 00007f15e7470d10 Sep 21 10:37:20 truenas kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 00007ffeba2a6bc0 Sep 21 10:37:20 truenas kernel: R13: 00005556a3485e50 R14: 00005556a347b2c0 R15: 00007ffeba2aa1c4 Sep 21 10:37:20 truenas kernel: </TASK>
thanks in advance!
BR,
MCC
