I can't tell if your having line wrapping issues or if that's just how your editor is displaying the long line. But I'd check that long line is all on a single line.
YEIII..! there we goo..!!!! finally, lol I did not realize i had to take out the ";" because i didnt know it was like the "#" from other parts of the editing...:( Thanks mate for all your help...
GREAT GUIDES MATE, I followed the movies and tv shows downloading, and this one, both fairly easy to setup, with some hiccups on my part tho...THANK YOU VERY MUCH...!!! have a great rest of the night.
Not sure what's wrong. you never got to the part where you enter your admin user/password? If not it's something with your nginx or php-fpm configuration.
not sure, I just knew how to do that from experience.
same as hosting anything else, port forward, probably need to setup Dynamic DNS.
You probably want to setup HTTPS too
I'll try the upgrade again the next time I have a pause from work. We're in the midst of a big project now, and I'm working long weeks. I think there will be a pause in a couple of weeks and I'll try then.
and then just simply do the dynamic dns and port forwarding to make the cloud remotely accessible, or do i still have to do https? I am open to suggestions..! Thanks again.
Hi joshua, I posted in another section on the forums and got some help on setting up a "real" SSL for the owncloud, i forwaded the ports, created the dns, but now when I go to the address, i get a blank page (instead of the owncloud GUI), I think it has to do with a config in the files you said to change in the guide. do you have any idea what it could be??? here is the post if you wanna read it.\https://forums.freenas.org/index.php?threads/need-help-setting-up-owncloud-with-ssl.42862/
