I would check your php socket is still listening at '/var/run/php-fpm.sock' with the command "sockstat"I'm a Chinese boy, I can't speak English very well.
I recently ran a PKG upgrade,Unable to open owncloud web page. 502 error occurred.
run service nginx restart ,service php-fpm restart ,Test run OK.
Re installed according to the material, but also failed, can not open the web page, how can I restore the owncloud service?
The nginx version :nginx-1.12.0_3,2
No, I never ended up pursuing that further.@Joshua Parker Ruehlig did you ever find a way to upgrade the PHP version in the nextcloud plugin instead of us less knowledgable members having to create a jail and install Nextcloud.
Bummer.No, I never ended up pursuing that further.
Security & setup warnings It's important for the security and performance of your instance that everything is configured correctly. To help you with that we are doing some automatic checks. Please see the Tips & Ticks section and the documentation for more information.
Technical information ===================== The following list covers which files have failed the integrity check. Please read the previous linked documentation to learn more about the errors and how to fix them. Results ======= - ownbackup - EXCEPTION - OC\IntegrityCheck\Exceptions\InvalidSignatureException - Certificate is not valid. Raw output ========== Array ( [ownbackup] => Array ( [EXCEPTION] => Array ( [class] => OC\IntegrityCheck\Exceptions\InvalidSignatureException [message] => Certificate is not valid. ) ) )
I upgraded the NC12 and do not have any issues/warnings.Has anyone tried upgrading to Nextcloud 12.0?
I have tried on a brand new jail install following this post as well has replicating my jails and datasets to another PC then upgrading, while both solutions work, I am getting a "Code integrity check" message from Nextcloud which points to "ownbackup".
Under the Admin page, I have the following messages:
Code:Security & setup warnings It's important for the security and performance of your instance that everything is configured correctly. To help you with that we are doing some automatic checks. Please see the Tips & Ticks section and the documentation for more information.
- Some files have not passed the integrity check. Further information on how to resolve this issue can be found in our documentation. (List of invalid files… / Rescan…)
- The "X-Frame-Options" HTTP header is not configured to equal to "SAMEORIGIN". This is a potential security or privacy risk and we recommend adjusting this setting.
Please double check the installation guides ↗, and check for any errors or warnings in the log.
- The PHP Opcache is not properly configured. For better performance we recommend ↗ to use following settings in the php.ini: opcache.enable=1 opcache.enable_cli=1 opcache.interned_strings_buffer=8 opcache.max_accelerated_files=10000 opcache.memory_consumption=128 opcache.save_comments=1 opcache.revalidate_freq=1
The following are the details regarding the "Code integrity check" message:
Code:Technical information ===================== The following list covers which files have failed the integrity check. Please read the previous linked documentation to learn more about the errors and how to fix them. Results ======= - ownbackup - EXCEPTION - OC\IntegrityCheck\Exceptions\InvalidSignatureException - Certificate is not valid. Raw output ========== Array ( [ownbackup] => Array ( [EXCEPTION] => Array ( [class] => OC\IntegrityCheck\Exceptions\InvalidSignatureException [message] => Certificate is not valid. ) ) )
For the opcache issues, I wasn't successful resolving the issue, when I tried to work on it a few weeks back.
Even after updating php.ini and restarting the jail, I would still have the exact same error messages.
There are reference in the Installation document about mutliple instance of php.ini where the update needs to be done.
Any idea?
Any idea?
strange. Could someone try the following?I ran into the same issues, and also followed the solutions posted to correct it (modifying php.ini) but still had the same errors.
<?php phpinfo(); ?>
Ownbackup is one of the app listed in Nextcloud. It's main purpose is to handle backing up of the database. I removed it then installed it again, and message is no longer present.I upgraded the NC12 and do not have any issues/warnings.
Is ownbackup an app you installed?
I have no specific info about "opcache" except the credits.strange. Could someone try the following?
* move index.php to index-back.php
* create index.php with the following contents
Code:<?php phpinfo(); ?>
* browse to nextcloud and see what the page says about opcache
does 'pkg info' show that php70-opcache is installed?I have no specific info about "opcache" except the credits.
I just installed the pakage you referenced:does 'pkg info' show that php70-opcache is installed?
Zend OPcache Opcode Caching Up and Running Optimization Enabled SHM Cache Enabled File Cache Disabled Startup OK Shared memory model mmap Cache hits 0 Cache misses 1 Used memory 9132816 Free memory 57976048 Wasted memory 0 Interned Strings Used memory 278848 Interned Strings Free memory 3915456 Cached scripts 1 Cached keys 1 Max keys 3907 OOM restarts 0 Hash keys restarts 0 Manual restarts 0 Directive Local Value Master Value opcache.blacklist_filename no value no value opcache.consistency_checks 0 0 opcache.dups_fix Off Off opcache.enable On On opcache.enable_cli Off Off opcache.enable_file_override Off Off opcache.error_log no value no value opcache.fast_shutdown 0 0 opcache.file_cache no value no value opcache.file_cache_consistency_checks 1 1 opcache.file_cache_only 0 0 opcache.file_update_protection 2 2 opcache.force_restart_timeout 180 180 opcache.huge_code_pages Off Off opcache.inherited_hack On On opcache.interned_strings_buffer 4 4 opcache.lockfile_path /tmp /tmp opcache.log_verbosity_level 1 1 opcache.max_accelerated_files 2000 2000 opcache.max_file_size 0 0 opcache.max_wasted_percentage 5 5 opcache.memory_consumption 64 64 opcache.optimization_level 0x7FFFBFFF 0x7FFFBFFF opcache.preferred_memory_model no value no value opcache.protect_memory 0 0 opcache.restrict_api no value no value opcache.revalidate_freq 2 2 opcache.revalidate_path Off Off opcache.save_comments 1 1 opcache.use_cwd On On opcache.validate_permission Off Off opcache.validate_root Off Off opcache.validate_timestamps On On
Can you restart php-fpm, and move back the index.php file.I just installed the pakage you referenced:
Here is the output after install.
Code:Zend OPcache Opcode Caching Up and Running Optimization Enabled SHM Cache Enabled File Cache Disabled Startup OK Shared memory model mmap Cache hits 0 Cache misses 1 Used memory 9132816 Free memory 57976048 Wasted memory 0 Interned Strings Used memory 278848 Interned Strings Free memory 3915456 Cached scripts 1 Cached keys 1 Max keys 3907 OOM restarts 0 Hash keys restarts 0 Manual restarts 0 Directive Local Value Master Value opcache.blacklist_filename no value no value opcache.consistency_checks 0 0 opcache.dups_fix Off Off opcache.enable On On opcache.enable_cli Off Off opcache.enable_file_override Off Off opcache.error_log no value no value opcache.fast_shutdown 0 0 opcache.file_cache no value no value opcache.file_cache_consistency_checks 1 1 opcache.file_cache_only 0 0 opcache.file_update_protection 2 2 opcache.force_restart_timeout 180 180 opcache.huge_code_pages Off Off opcache.inherited_hack On On opcache.interned_strings_buffer 4 4 opcache.lockfile_path /tmp /tmp opcache.log_verbosity_level 1 1 opcache.max_accelerated_files 2000 2000 opcache.max_file_size 0 0 opcache.max_wasted_percentage 5 5 opcache.memory_consumption 64 64 opcache.optimization_level 0x7FFFBFFF 0x7FFFBFFF opcache.preferred_memory_model no value no value opcache.protect_memory 0 0 opcache.restrict_api no value no value opcache.revalidate_freq 2 2 opcache.revalidate_path Off Off opcache.save_comments 1 1 opcache.use_cwd On On opcache.validate_permission Off Off opcache.validate_root Off Off opcache.validate_timestamps On On
 nano /usr/local/etc/php.iniopcache.enable=1 opcache.enable_cli=1 opcache.interned_strings_buffer=8 opcache.max_accelerated_files=10000 opcache.memory_consumption=128 opcache.save_comments=1 opcache.revalidate_freq=1
check the css/js section of the nginx.conf, I updated itIt is getting better.
After installing php70-opcache, php71-opcache, I have been able to update the php.ini file with:
I have uncommented and updated the values based on Nextcloud recommendations:
Code:opcache.enable=1 opcache.enable_cli=1 opcache.interned_strings_buffer=8 opcache.max_accelerated_files=10000 opcache.memory_consumption=128 opcache.save_comments=1 opcache.revalidate_freq=1
I now need to address the following message:
Code:Security & setup warnings It's important for the security and performance of your instance that everything is configured correctly. To help you with that we are doing some automatic checks. Please see the Tips & Ticks section and the documentation for more information.Please double check the installation guides ↗, and check for any errors or warnings in the log.
No luck there.check the css/js section of the nginx.conf, I updated it
It should not be in you nginx config. See here...No luck there.
I couldn't find the
add_header X-Frame-Options "SAMEORIGIN";
in the nginx.conf file. Maybe the file has not been updated on the forum yet.
It does however appear in mine.
My nginx.conf file is a bit more complexe than yours. I will have to go through it again in more details.
