Michael Sparks
- Apr 23, 2014
root@owncloud:/ # ls -l /var/run/php-fpm.sock srw-rw---- 1 root wheel 0 Oct 14 16:38 /var/run/php-fpm.sock
root@owncloud:/ # sockstat | grep php www php-fpm 97681 0 stream /var/run/php-fpm.sock www php-fpm 97680 0 stream /var/run/php-fpm.sock root php-fpm 97679 8 stream -> ?? root php-fpm 97679 10 stream -> ?? root php-fpm 97679 11 stream /var/run/php-fpm.sock
you didn't uncomment the prescribed lines in the php-fpm.confCode:root@owncloud:/ # ls -l /var/run/php-fpm.sock srw-rw---- 1 root wheel 0 Oct 14 16:38 /var/run/php-fpm.sock
did you uncomment out the other 3 lines as specified?Not sure what that means, but I did replace the relevant lines mentioned in the install instructions into my php-fpm.conf:
I did just notice that there was missing a ";" in front of listen = /var/run/php-fpm.sock however after making that change i still am getting the same result
Is there a way to 'select all' so I can post of php-fpm.conf so you can see it?
- listen = /var/run/php-fpm.sock
no you didn't. you need to read very carefullyyes, copied straight from my php-fpm.conf
;listen = /var/run/php-fpm.sock
;listen.owner = www
;listen.group = www
;env[PATH] = /usr/local/bin:/usr/bin:/bin
The lines you show above are commented out by leading ;'s unlike the instructions.I am not sure what you mean? I have replaced the 4 lines as mentioned in the installation instructions in the php-fpm.conf, I just rechecked and they are the exact same as in the instructions.
service php-fpm restart
No problem. Glad you got through it and hope it work well for you.Wow, great. So before you mentioned that I had actually tired that but it produced the same result because I didnt "service php-fpm restart" I would personally like to thank you for being patient and offering your help. I would also glady donate to you for the help you have provided along with the guide, just let me know how I can. Thank you!
If you reboot the config should be overwritten by the one on the read only partitionCan anyone post there nignx.conf for freenas, I apparently was modifying the wrong nginx when attempting to setup ssl on owncloud's nginx.conf and now I lost web access to frenas.... wow
# FreeNAS nginx configuration file
user www www;
worker_processes 1;
events {
worker_connections 1024;
http {
include mime.types;
default_type application/octet-stream;
# reserve 1MB under the name 'proxied' to track uploads
upload_progress proxied 1m;
sendfile on;
#tcp_nopush on;
client_max_body_size 512mb;
#keepalive_timeout 0;
keepalive_timeout 65;
#gzip on;
#upload_store /var/tmp/firmware;
client_body_temp_path /var/tmp/firmware;
server {
server_name localhost;
listen 192.168.12.168:80 default_server ssl spdy;
listen 80;
ssl_certificate "";
ssl_certificate_key "";
ssl_dhparam /data/dhparam.pem;
ssl_session_timeout 120m;
ssl_session_cache shared:ssl:16m;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_prefer_server_ciphers on;
ssl_ciphers EECDH+ECDSA+AESGCM:EECDH+aRSA+AESGCM:EECDH+ECDSA+SHA256:EDH+
add_header Strict-Transport-Security max-age=31536000;
## TODO: OCSP Stapling
#ssl_stapling on;
#ssl_stapling_verify on;
#resolver ;
#ssl_trusted_certificate ;
location / {
include fastcgi_params;
fastcgi_pass 127.0.0.1:9042;
fastcgi_pass_header Authorization;
fastcgi_intercept_errors off;
fastcgi_read_timeout 600m;
#fastcgi_temp_path /var/tmp/firmware;
fastcgi_param HTTPS $https;
# track uploads in the 'proxied' zone
# remember connections for 30s after they finished
track_uploads proxied 30s;
location /progress {
# report uploads tracked in the 'proxied' zone
report_uploads proxied;
location /dojango {
alias /usr/local/www/freenasUI/dojango;
location /static {
alias /usr/local/www/freenasUI/static;
location /reporting/graphs {
alias /var/db/graphs;
location /dojango/dojo-media/release/1.10.1 {
alias /usr/local/www/dojo;
location /docs {
alias /usr/local/www/data/docs;
#error_page 404 /404.html;
# redirect server error pages to the static page /50x.html
error_page 500 502 503 504 /50x.html;
location = /50x.html {
root /usr/local/www/nginx-dist;
#include plugins.conf;
server {
listen 192.168.12.168:443;
listen 443;
return 307 https://$host:443$request_uri;
I seem to have fixed it haha I changed
Code:'trusted_domains' => array ( 0 => '192.168.1.52', ),
to
Code:'trusted_domains' => array ( 0 => '<mydomain>.com', ),
at the top of config.php, worked on my phone with wifi off. Not sure if it's the right way to do it, but it worked haha
/usr/local/www/owncloud/config/config.phpWhat file do I need to edit to make the the changes? You mentioned config.php is that the php-fpm.conf? I could not find the trusted domains line there. Thanks for the help.
Here's a link if you use paypal. Thanks!
root@cloud:/usr/local/etc/nginx # su www $ php /usr/local/www/owncloud/occ upgrade ownCloud or one of the apps require upgrade - only a limited number of commands are available Checked database schema update Checked database schema update for apps Updated database
awesome thanks!Oh, cool! A beer was just sent to you with great pleasure! :) We thank you, Sir!
