help with failed disk swap
jcizzo
i received the drive error yadda yadda..
i clicked on the failing drive, chose "offline", swapped in the new drive (after ensuring it was clear of partitions with diskpart because wiping wouldn't do it),
and i get the following error:
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 355, in run
await self.future
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 391, in __run_body
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 981, in nf
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool_/replace_disk.py", line 78, in replace
await self.middleware.call('pool.format_disks', job, disks)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1283, in call
return await self._call(
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1240, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool_/format_disks.py", line 28, in format_disks
await asyncio_map(format_disk, disks.items(), limit=16)
File "/usr/local/lib/python3.9/site-packages/middlewared/utils/asyncio_.py", line 16, in asyncio_map
return await asyncio.gather(*futures)
File "/usr/local/lib/python3.9/site-packages/middlewared/utils/asyncio_.py", line 13, in func
return await real_func(arg)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool_/format_disks.py", line 24, in format_disk
await self.middleware.call('disk.format', disk, swapgb if config['create_swap'] else 0, False)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1251, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1156, in run_in_executor
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/disk_/format.py", line 21, in format
raise CallError(f'Failed to wipe disk {disk}: {job.error}')
middlewared.service_exception.CallError: [EFAULT] Failed to wipe disk da3: [Errno 6] Device not configured
what gives?
jcizzo
i restarted the nas and it was able to do it properly and now the drive is rebuilding.. but i shouldn't have to do it.. in the log up top it mentions something about swap space.
i disabled swap on the drives and followed instructions on how to direct freebsd to use an nvme for swap.
my boot/os drives are sata ssds (mirrored) and i installed a 500Gig nvme drive that i had laying around (unused) for use as a swap drive.. yes, total overkill but that's besides the point.
i dunno if my swap drive is being used or not, i'm not savvy enough to figure that out.. but could that be the problem?
Davvo
Failed to wipe disk da3: [Errno 6] Device not configured should be key here.
