Aero-Graphics
- Jun 19, 2023
I've started having a weird error on one of the shared storage systems in my environment. If I try to import any pool from the GUI or API I get the following error:
It does not matter what pool I try to import, I will receive this error. If I create a new pool it will mount it just fine, but if I export it I will then get this error. The other shared storage system can import/export the pools without issue.
Any ideas where to look for this?
Rob
Error: Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 355, in run await self.future File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 391, in __run_body rv = await self.method(*([self] + args)) File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 981, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool.py", line 1458, in import_pool await self.middleware.call('pool.scrub.create', { File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1279, in call return await self._call( File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1236, in _call return await methodobj(*prepared_call.args) File "/usr/local/lib/python3.9/site-packages/middlewared/service.py", line 496, in create rv = await self.middleware._call( File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1236, in _call return await methodobj(*prepared_call.args) File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 981, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool.py", line 4162, in do_create verrors, data = await self.validate_data(data, 'pool_scrub_create') File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool.py", line 4108, in validate_data scrub_obj = await self.query(filters=[('pool', '=', pool_pk)]) File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 981, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/service.py", line 483, in query result = await self.middleware.call( File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1279, in call return await self._call( File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1236, in _call return await methodobj(*prepared_call.args) File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 981, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/datastore/read.py", line 164, in query result = await self._queryset_serialize( File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/datastore/read.py", line 214, in _queryset_serialize result.append(await self._serialize( File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/datastore/read.py", line 232, in _serialize data = await self.middleware.call(extend, data) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1279, in call return await self._call( File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1236, in _call return await methodobj(*prepared_call.args) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool.py", line 4078, in pool_scrub_extend data['pool'] = pool['id'] TypeError: 'NoneType' object is not subscriptable
Rob
