pchatzilabrou
- Jan 30, 2024
Hello everyone,
I am testing TrueNAS Core But i have an issue i am trying to solve and i would like your help !
I am trying to create a dataset which it's name is in Greek. But when i am pressing submit i am getting this error:
I did some research on internet and most of the people are changing the decoder in locale via shell. Is it safe? Is there any other way to be able to create datasets using greek language?
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.9/concurrent/futures/process.py", line 246, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 111, in main_worker
res = MIDDLEWARE._run(*call_args)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 45, in _run
return self._call(name, serviceobj, methodobj, args, job=job)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 39, in _call
return methodobj(*params)
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 985, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 755, in do_create
pool.create(data['name'], params, fstype=getattr(libzfs.DatasetType, data['type']), sparse_vol=sparse)
File "libzfs.pyx", line 402, in libzfs.ZFS.__exit__
File "libzfs.pyx", line 2903, in libzfs.ZFSPool.create
File "libzfs.pyx", line 497, in libzfs.ZFS.get_error
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xce in position 19: invalid continuation byte
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 139, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1240, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/service.py", line 496, in create
rv = await self.middleware._call(
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 981, in nf
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool.py", line 3136, in do_create
await self.middleware.call('zfs.dataset.create', {
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1283, in call
return await self._call(
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1248, in _call
return await self._call_worker(name, *prepared_call.args)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1254, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1173, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1156, in run_in_executor
