chitownburgerboy
- Nov 10, 2023
I was running freenas 11.3 for a few years hadn’t touched it at all, but my system went offline and wouldn’t boot. I discovered that removing one of the drives resolved the issue, so I decided while I’m at it, I should upgrade things. I formatted the problem drive, reinserted it, and freenas booted back up. I then deleted the pool associated with the problem drive and then I manually upgraded to truenas core 13. Now I’m trying to make a new pool, and I get the error “[EFAULT] Failed to mount dataset: Mount point or dataset is busy”. I tried removing the drive that caused issues, putting in a clean drive, rebooting, and I still see the error. Any help would be greatly appreciated.
Expanding the error I see -
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 858, in mount
dataset.mount()
File "libzfs.pyx", line 402, in libzfs.ZFS.__exit__
dataset.mount()
File "libzfs.pyx", line 3698, in libzfs.ZFSDataset.mount
libzfs.ZFSException: mountpoint or dataset is busy
File "/usr/local/lib/python3.9/concurrent/futures/process.py", line 246, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 111, in main_worker
res = MIDDLEWARE._run(*call_args)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 45, in _run
return self._call(name, serviceobj, methodobj, args, job=job)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 39, in _call
return methodobj(*params)
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 985, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 861, in mount
raise CallError(f'Failed to mount dataset: {e}')
middlewared.service_exception.CallError: [EFAULT] Failed to mount dataset: mountpoint or dataset is busy
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 355, in run
await self.future
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 391, in __run_body
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 981, in nf
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool.py", line 735, in do_create
raise e
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool.py", line 704, in do_create
await self.middleware.call('zfs.dataset.mount', data['name'])
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1283, in call
return await self._call(
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1248, in _call
return await self._call_worker(name, *prepared_call.args)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1254, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1173, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1156, in run_in_executor
