Phil Williams
- Feb 1, 2023
So I've got my TrueNas box running and burned in so now is time to make sure the hardware is running as expected. I see my drives running at about 33-35 degrees which is a little high for me. I have 6x WD Pro drives in a Fractal Define R6 case and there are two fans (120mm I believe) that shipped with the case at the front blowing air across. The image below shows the fan direction for each fan.
Now there aren't enough bays to checkerboard the drives so I've split them into two groups of three to take advantage of each fan. My feeling is that the fans are not up to the job. They are super quiet but I think I might need something with more oomph.
Any recommendations? I appreciate the fact the more powerful the fan then the louder it will be but I'd like to keep noise to a minimum if I can.
