Data lost: Restoring from snapshots?
It appears you have that user's shell set to "TrueNAS Console." I sure hope that isn't the new default, because it's frankly silly. Set it to something sensible (I like zsh) in the user settings (Credentials -> Local Users).
opensourceFTW
Thanks, I am in zsh now, what do I select?
Patrick M. Hausen
You type zfs list -t all and post the output, please.
chuck32
When looking at snapshots, what does it mean when it reference 2.59TB? That is around the same amount of music that I lost.
That is the amount of data the snapshot references.
I didn't scroll back, possibly this wasn't addressed yet. A snapshot itself does not have a size, it's just a record of which data blocks were used / written at creation. In this case, the chances are good that the snapshot you are seeing is exactly referencing all your music. The snapshot holds information about 2.59 TB written data.
opensourceFTW
I will type in zfs list -t all as soon as I can get the terminal screen, what should I choose?
Patrick M. Hausen
0 of course. Exit and give me that darn command prompt. What a moronic shell default setup. I tried zsh for 5 minutes and immediately switched back to bash when I found that the . command does not work as expected.
opensourceFTW
Terminal wont allow me to authenticate. I can login to SSH but that is it. I am logged into bash...
but it tells me that
-bash: zfs: command not found
what is going on?
Cannot authenticate in CLI
zfs does not work
bash command not found.
I am using scale and it is up to day.
Patrick M. Hausen
sudo su - before you enter other commands.
opensourceFTW
Finally.
root@truenas[~]# zfs list -t all
NAME        USED  AVAIL  REFER  MOUNTPOINT
Share        9.95T  8.08T   149K  /mnt/Share
Share@manual-2024-02-11_21-48        95.9K      -   139K  -
Share/.system        3.21G  8.08T  1.21G  legacy
Share/.system@manual-2024-02-11_21-48        1.20G      -  1.20G  -
Share/.system/configs-388408e95929461db941ccc50979f8fb                                                              14.3M  8.08T  14.3M  legacy
Share/.system/configs-388408e95929461db941ccc50979f8fb@manual-2024-02-11_21-48                0B      -  14.3M  -
Share/.system/configs-ae32c386e13840b2bf9c0083275e7941                                                             3.11M  8.08T  3.01M  legacy
Share/.system/configs-ae32c386e13840b2bf9c0083275e7941@manual-2024-02-11_21-48               107K      -  1.22M  -
Share/.system/cores        202K  1024M   128K  legacy
Share/.system/cores@manual-2024-02-11_21-48        74.6K      -   128K  -
Share/.system/ctdb_shared_vol        128K  8.08T   128K  legacy
Share/.system/ctdb_shared_vol@manual-2024-02-11_21-48                                                               0B      -   128K  -
Share/.system/glusterd        202K  8.08T   128K  legacy
Share/.system/glusterd@manual-2024-02-11_21-48        74.6K      -   128K  -
Share/.system/netdata-388408e95929461db941ccc50979f8fb                                                            250M  8.08T   250M  legacy
Share/.system/netdata-388408e95929461db941ccc50979f8fb@manual-2024-02-11_21-48               0B      -   250M  -
Share/.system/netdata-ae32c386e13840b2bf9c0083275e7941                                                            504M  8.08T   249M  legacy
Share/.system/netdata-ae32c386e13840b2bf9c0083275e7941@manual-2024-02-11_21-48              255M      -   255M  -
Share/.system/rrd-388408e95929461db941ccc50979f8fb        39.6M  8.08T  39.6M  legacy
Share/.system/rrd-388408e95929461db941ccc50979f8fb@manual-2024-02-11_21-48                       0B      -  39.6M  -
Share/.system/rrd-ae32c386e13840b2bf9c0083275e7941        128K  8.08T   128K  legacy
Share/.system/rrd-ae32c386e13840b2bf9c0083275e7941@manual-2024-02-11_21-48                     0B      -   128K  -
Share/.system/samba4        2.21M  8.08T   570K  legacy
Share/.system/samba4@update--2023-08-19-16-11--13.0-U5.2                                                           256K      -   501K  -
Share/.system/samba4@update--2023-11-23-00-38--13.0-U5.3                                                           261K      -   533K  -
Share/.system/samba4@update--2023-12-15-23-42--13.0-U6                                                              272K      -   543K  -
Share/.system/samba4@update--2023-12-26-02-27--13.0-U6.1                                                           282K      -   554K  -
Share/.system/samba4@update--2024-02-02-04-33--SCALE-23.10.1                                                 213K      -   570K  -
Share/.system/samba4@manual-2024-02-11_21-48        213K      -   570K  -
Share/.system/services        139K  8.08T   128K  legacy
Share/.system/services@manual-2024-02-11_21-48        10.7K      -   128K  -
Share/.system/syslog-388408e95929461db941ccc50979f8fb                                                              1.83M  8.08T  1.83M  legacy
Share/.system/syslog-388408e95929461db941ccc50979f8fb@manual-2024-02-11_21-48                0B      -  1.83M  -
Share/.system/webui        128K  8.08T   128K  legacy
Share/.system/webui@manual-2024-02-11_21-48        0B      -   128K  -
Share/Plex        3.38T  8.08T  3.38T  /mnt/Share/Plex
Share/Plex@auto-2024-03-04_00-00        4.64G      -  3.38T  -
Share/Plex@auto-2024-03-05_00-00        453K      -  3.38T  -
Share/Plex@auto-2024-03-06_00-00        389K      -  3.38T  -
Share/Plex@auto-2024-03-07_00-00        155K      -  3.38T  -
Share/Storage        6.54T  8.08T   940G  /mnt/Share/Storage
Share/Storage@manual-2024-02-11_21-48        47.4G      -  6.05T  -
Share/Storage@auto-2024-02-22_00-00        58.3M      -  6.49T  -
Share/Storage@auto-2024-02-23_00-00        3.27M      -  6.49T  -
Share/Storage@auto-2024-02-24_00-00        165M      -  5.94T  -
Share/Storage@auto-2024-02-25_00-00        1.15M      -  3.63T  -
Share/Storage@auto-2024-02-26_00-00        213K      -  2.59T  -
Share/Storage@auto-2024-02-27_00-00        234K      -  2.59T  -
Share/Storage@auto-2024-02-28_00-00        384K      -  2.59T  -
Share/Storage@auto-2024-02-29_00-00        10.7K      -  2.59T  -
Share/Storage@auto-2024-03-01_00-00        0B      -  2.59T  -
Share/Storage@auto-2024-03-02_00-00        0B      -  2.59T  -
Share/Storage@auto-2024-03-03_00-00        245K      -  2.59T  -
Share/Storage@auto-2024-03-04_00-00        10.7K      -   940G  -
Share/Storage@auto-2024-03-05_00-00        10.7K      -   940G  -
Share/Storage@auto-2024-03-06_00-00        0B      -   940G  -
Share/Storage@auto-2024-03-07_00-00        0B      -   940G  -
Share/Storage-auto-2024-03-02_00-00-clone        10.7K  8.08T  2.59T  /mnt/Share/Storage auto-2024-03-02_00-00-clone
Share/Storage/Steam-Library        74.6K  8.08T  74.6K  -
Share/Storage/Steam-Library@manual-2024-02-11_21-48                                                              0B      -  74.6K  -
Share/iocage        16.4G  8.08T  8.65M  /mnt/Share/iocage
Share/iocage@manual-2024-02-11_21-48        10.7K      -  8.65M  -
Share/iocage/download        878M  8.08T   139K  /mnt/Share/iocage/download
Share/iocage/download@manual-2024-02-11_21-48        0B      -   139K  -
Share/iocage/download/13.1-RELEASE        434M  8.08T   434M  /mnt/Share/iocage/download/13.1-RELEASE
Share/iocage/download/13.1-RELEASE@manual-2024-02-11_21-48                                               0B      -   434M  -
Share/iocage/download/13.2-RELEASE        443M  8.08T   443M  /mnt/Share/iocage/download/13.2-RELEASE
Share/iocage/download/13.2-RELEASE@manual-2024-02-11_21-48                                               0B      -   443M  -
Share/iocage/images        128K  8.08T   128K  /mnt/Share/iocage/images
Share/iocage/images@manual-2024-02-11_21-48        0B      -   128K  -
Share/iocage/jails        12.1G  8.08T   128K  /mnt/Share/iocage/jails
Share/iocage/jails@manual-2024-02-11_21-48        0B      -   128K  -
Share/iocage/jails/clamav        2.25G  8.08T   416K  /mnt/Share/iocage/jails/clamav
Share/iocage/jails/clamav@ioc_update_13.1-RELEASE-p9_2023-10-08_18-05-34                                  341K      -   394K  -
Share/iocage/jails/clamav@ioc_update_13.1-RELEASE-p9_2023-11-22_08-04-20                                  362K      -   416K  -
Share/iocage/jails/clamav@ioc_update_13.1-RELEASE-p9_2023-11-28_19-00-44                                  352K      -   405K  -
Share/iocage/jails/clamav@ioc_update_13.1-RELEASE-p9_2023-12-15_17-16-38                                  330K      -   384K  -
Share/iocage/jails/clamav@manual-2024-02-11_21-48                                                        10.7K      -   416K  -
Share/iocage/jails/clamav/root        2.25G  8.08T  1.37G  /mnt/Share/iocage/jails/clamav/root
Share/iocage/jails/clamav/root@ioc_update_13.1-RELEASE-p9_2023-10-08_18-05-34                             218M      -  1.29G  -
Share/iocage/jails/clamav/root@ioc_update_13.1-RELEASE-p9_2023-11-22_08-04-20                             222M      -  1.32G  -
Share/iocage/jails/clamav/root@ioc_update_13.1-RELEASE-p9_2023-11-28_19-00-44                             228M      -  1.34G  -
Share/iocage/jails/clamav/root@ioc_update_13.1-RELEASE-p9_2023-12-15_17-16-38                             230M      -  1.35G  -
Share/iocage/jails/clamav/root@manual-2024-02-11_21-48                                                   10.7K      -  1.37G  -
Share/iocage/jails/jellfin        4.03G  8.08T  59.4M  /mnt/Share/iocage/jails/jellfin
Share/iocage/jails/jellfin@ioc_update_13.1-RELEASE-p9_2023-10-11_18-29-27                                   0B      -  59.3M  -
Share/iocage/jails/jellfin@ioc_plugin_update_2023-10-12                                                     0B      -  59.3M  -
Share/iocage/jails/jellfin@ioc_update_13.1-RELEASE-p9_2023-10-11_19-02-22                                85.2K      -   176K  -
Share/iocage/jails/jellfin@ioc_update_13.1-RELEASE-p9_2023-10-12_10-02-55                                85.2K      -   176K  -
Share/iocage/jails/jellfin@ioc_update_13.1-RELEASE-p9_2023-11-05_04-14-09                                 101K      -   176K  -
Share/iocage/jails/jellfin@ioc_update_13.1-RELEASE-p9_2023-11-13_18-29-52                                59.3M      -  59.4M  -
Share/iocage/jails/jellfin@manual-2024-02-11_21-48                                                       10.7K      -  59.4M  -
Share/iocage/jails/jellfin/root        3.85G  8.08T  2.60G  /mnt/Share/iocage/jails/jellfin/root
Share/iocage/jails/jellfin/root@ioc_update_13.1-RELEASE-p9_2023-10-11_18-29-27                              0B      -  2.79G  -
Share/iocage/jails/jellfin/root@ioc_plugin_update_2023-10-12                                                0B      -  2.79G  -
Share/iocage/jails/jellfin/root@ioc_update_13.1-RELEASE-p9_2023-10-11_19-02-22                            378K      -  2.79G  -
Share/iocage/jails/jellfin/root@ioc_update_13.1-RELEASE-p9_2023-10-12_10-02-55                           8.14M      -  2.79G  -
Share/iocage/jails/jellfin/root@ioc_update_13.1-RELEASE-p9_2023-11-05_04-14-09                           15.9M      -  2.84G  -
Share/iocage/jails/jellfin/root@ioc_update_13.1-RELEASE-p9_2023-11-13_18-29-52                            436M      -  2.59G  -
Share/iocage/jails/jellfin/root@manual-2024-02-11_21-48                                                  10.7K      -  2.60G  -
Share/iocage/jails/nextcloud        5.82G  8.08T   687K  /mnt/Share/iocage/jails/nextcloud
Share/iocage/jails/nextcloud@ioc_update_13.1-RELEASE-p9_2023-11-05_04-12-32                                 0B      -   677K  -
Share/iocage/jails/nextcloud@ioc_plugin_update_2023-11-05                                                   0B      -   677K  -
Share/iocage/jails/nextcloud@ioc_update_13.1-RELEASE-p9_2023-11-13_07-46-03                               112K      -   677K  -
Share/iocage/jails/nextcloud@manual-2024-02-11_21-48                                                     10.7K      -   687K  -
Share/iocage/jails/nextcloud/root        5.82G  8.08T  3.60G  /mnt/Share/iocage/jails/nextcloud/root
Share/iocage/jails/nextcloud/root@ioc_update_13.1-RELEASE-p9_2023-11-05_04-12-32                            0B      -  3.52G  -
Share/iocage/jails/nextcloud/root@ioc_plugin_update_2023-11-05                                              0B      -  3.52G  -
Share/iocage/jails/nextcloud/root@ioc_update_13.1-RELEASE-p9_2023-11-13_07-46-03                          223M      -  3.33G  -
Share/iocage/jails/nextcloud/root@manual-2024-02-11_21-48                                                10.7K      -  3.60G  -
Share/iocage/log        165K  8.08T   155K  /mnt/Share/iocage/log
Share/iocage/log@manual-2024-02-11_21-48        10.7K      -   155K  -
Share/iocage/releases        3.46G  8.08T   139K  /mnt/Share/iocage/releases
Share/iocage/releases@manual-2024-02-11_21-48                                                               0B      -   139K  -
Share/iocage/releases/13.1-RELEASE        1.72G  8.08T   128K  /mnt/Share/iocage/releases/13.1-RELEASE
Share/iocage/releases/13.1-RELEASE@manual-2024-02-11_21-48                                                  0B      -   128K  -
Share/iocage/releases/13.1-RELEASE/root        1.72G  8.08T  1.72G  /mnt/Share/iocage/releases/13.1-RELEASE/root
Share/iocage/releases/13.1-RELEASE/root@manual-2024-02-11_21-48                                          10.7K      -  1.72G  -
Share/iocage/releases/13.2-RELEASE        1.74G  8.08T   128K  /mnt/Share/iocage/releases/13.2-RELEASE
Share/iocage/releases/13.2-RELEASE@manual-2024-02-11_21-48                                                  0B      -   128K  -
Share/iocage/releases/13.2-RELEASE/root        1.74G  8.08T  1.74G  /mnt/Share/iocage/releases/13.2-RELEASE/root
Share/iocage/releases/13.2-RELEASE/root@manual-2024-02-11_21-48                                          10.7K      -  1.74G  -
Share/iocage/templates        128K  8.08T   128K  /mnt/Share/iocage/templates
Share/iocage/templates@manual-2024-02-11_21-48                                                              0B      -   128K  -
Share/ix-applications        12.4G  8.08T   229K  /mnt/Share/ix-applications
Share/ix-applications@ix-applications-backup-system-update--2024-02-02_04:33:01                          90.6K      -   229K  -
Share/ix-applications@manual-2024-02-11_21-48                                                            90.6K      -   229K  -
Share/ix-applications/catalogs        105M  8.08T  53.4M  /mnt/Share/ix-applications/catalogs
Share/ix-applications/catalogs@manual-2024-02-11_21-48                                                   51.4M      -  51.4M  -
Share/ix-applications/default_volumes        128K  8.08T   128K  /mnt/Share/ix-applications/default_volumes
Share/ix-applications/default_volumes@ix-applications-backup-system-update--2024-02-02_04:33:01             0B      -   128K  -
Share/ix-applications/default_volumes@manual-2024-02-11_21-48                                               0B      -   128K  -
Share/ix-applications/k3s        10.8G  8.08T  8.91G  /mnt/Share/ix-applications/k3s
Share/ix-applications/k3s@ix-applications-backup-system-update--2024-02-02_04:33:01                       783M      -  1.70G  -
Share/ix-applications/k3s@manual-2024-02-11_21-48                                                        1.14G      -  5.79G  -
Share/ix-applications/k3s/kubelet        1.47M  8.08T   618K  legacy
Share/ix-applications/k3s/kubelet@manual-2024-02-11_21-48                                                 884K      -   927K  -
Share/ix-applications/releases        1.52G  8.08T   170K  /mnt/Share/ix-applications/releases
Share/ix-applications/releases@ix-applications-backup-system-update--2024-02-02_04:33:01                 95.9K      -   139K  -
Share/ix-applications/releases@manual-2024-02-11_21-48                                                    117K      -   160K  -
Share/ix-applications/releases/clamav        385M  8.08T   128K  /mnt/Share/ix-applications/releases/clamav
Share/ix-applications/releases/clamav@manual-2024-02-11_21-48                                               0B      -   128K  -
Share/ix-applications/releases/clamav/charts                                                              288K  8.08T   288K  /mnt/Share/ix-applications/releases/clamav/charts
Share/ix-applications/releases/clamav/charts@manual-2024-02-11_21-48                                        0B      -   288K  -
Share/ix-applications/releases/clamav/volumes                                                             385M  8.08T   128K  /mnt/Share/ix-applications/releases/clamav/volumes
Share/ix-applications/releases/clamav/volumes@manual-2024-02-11_21-48                                       0B      -   128K  -
Share/ix-applications/releases/clamav/volumes/ix_volumes                                                  385M  8.08T   139K  /mnt/Share/ix-applications/releases/clamav/volumes/ix_volumes
Share/ix-applications/releases/clamav/volumes/ix_volumes@manual-2024-02-11_21-48                            0B      -   139K  -
Share/ix-applications/releases/clamav/volumes/ix_volumes/scan-dir                                         128K  8.08T   128K  /mnt/Share/ix-applications/releases/clamav/volumes/ix_volumes/scan-dir
Share/ix-applications/releases/clamav/volumes/ix_volumes/scan-dir@manual-2024-02-11_21-48                   0B      -   128K  -
Share/ix-applications/releases/clamav/volumes/ix_volumes/sig-db                                           384M  8.08T   274M  /mnt/Share/ix-applications/releases/clamav/volumes/ix_volumes/sig-db
Share/ix-applications/releases/clamav/volumes/ix_volumes/sig-db@manual-2024-02-11_21-48                   111M      -   274M  -
Share/ix-applications/releases/jellyfin        682K  8.08T   139K  /mnt/Share/ix-applications/releases/jellyfin
Share/ix-applications/releases/jellyfin/charts                                                            288K  8.08T   288K  /mnt/Share/ix-applications/releases/jellyfin/charts
Share/ix-applications/releases/jellyfin/volumes                                                           256K  8.08T   128K  /mnt/Share/ix-applications/releases/jellyfin/volumes
Share/ix-applications/releases/jellyfin/volumes/ix_volumes                                                128K  8.08T   128K  /mnt/Share/ix-applications/releases/jellyfin/volumes/ix_volumes
Share/ix-applications/releases/mealie        25.5M  8.08T   139K  /mnt/Share/ix-applications/releases/mealie
Share/ix-applications/releases/mealie@manual-2024-02-11_21-48                                               0B      -   139K  -
Share/ix-applications/releases/mealie/charts                                                              586K  8.08T   501K  /mnt/Share/ix-applications/releases/mealie/charts
Share/ix-applications/releases/mealie/charts@manual-2024-02-11_21-48                                     85.2K      -   320K  -
Share/ix-applications/releases/mealie/volumes                                                            24.7M  8.08T   128K  /mnt/Share/ix-applications/releases/mealie/volumes
Share/ix-applications/releases/mealie/volumes@manual-2024-02-11_21-48                                       0B      -   128K  -
Share/ix-applications/releases/mealie/volumes@2                                                             0B      -   128K  -
Share/ix-applications/releases/mealie/volumes/ix_volumes                                                 24.6M  8.08T   149K  /mnt/Share/ix-applications/releases/mealie/volumes/ix_volumes
Share/ix-applications/releases/mealie/volumes/ix_volumes@manual-2024-02-11_21-48                            0B      -   149K  -
Share/ix-applications/releases/mealie/volumes/ix_volumes@2                                                  0B      -   149K  -
Share/ix-applications/releases/mealie/volumes/ix_volumes/data                                            5.96M  8.08T  5.34M  /mnt/Share/ix-applications/releases/mealie/volumes/ix_volumes/data
Share/ix-applications/releases/mealie/volumes/ix_volumes/data@manual-2024-02-11_21-48                    85.2K      -  5.44M  -
Share/ix-applications/releases/mealie/volumes/ix_volumes/data@2                                          90.6K      -  5.45M  -
Share/ix-applications/releases/mealie/volumes/ix_volumes/pgBackup                                         304K  8.08T   218K  /mnt/Share/ix-applications/releases/mealie/volumes/ix_volumes/pgBackup
Share/ix-applications/releases/mealie/volumes/ix_volumes/pgBackup@manual-2024-02-11_21-48                   0B      -   128K  -
Share/ix-applications/releases/mealie/volumes/ix_volumes/pgBackup@2                                         0B      -   128K  -
Share/ix-applications/releases/mealie/volumes/ix_volumes/pgData                                          18.2M  8.08T  16.8M  /mnt/Share/ix-applications/releases/mealie/volumes/ix_volumes/pgData
Share/ix-applications/releases/mealie/volumes/ix_volumes/pgData@manual-2024-02-11_21-48                   293K      -  16.3M  -
Share/ix-applications/releases/mealie/volumes/ix_volumes/pgData@2                                         293K      -  16.3M  -
Share/ix-applications/releases/nextcloud        929M  8.08T   139K  /mnt/Share/ix-applications/releases/nextcloud
Share/ix-applications/releases/nextcloud@manual-2024-02-11_21-48                                            0B      -   139K  -
Share/ix-applications/releases/nextcloud/charts                                                           490K  8.08T   490K  /mnt/Share/ix-applications/releases/nextcloud/charts
Share/ix-applications/releases/nextcloud/charts@manual-2024-02-11_21-48                                     0B      -   490K  -
Share/ix-applications/releases/nextcloud/volumes                                                          928M  8.08T   128K  /mnt/Share/ix-applications/releases/nextcloud/volumes
Share/ix-applications/releases/nextcloud/volumes@1                                                          0B      -   128K  -
Share/ix-applications/releases/nextcloud/volumes@manual-2024-02-11_21-48                                    0B      -   128K  -
Share/ix-applications/releases/nextcloud/volumes/ix_volumes                                               928M  8.08T   149K  /mnt/Share/ix-applications/releases/nextcloud/volumes/ix_volumes
Share/ix-applications/releases/nextcloud/volumes/ix_volumes@1                                               0B      -   149K  -
Share/ix-applications/releases/nextcloud/volumes/ix_volumes@manual-2024-02-11_21-48                         0B      -   149K  -
Share/ix-applications/releases/nextcloud/volumes/ix_volumes/ix-nextcloud_data                             908M  8.08T   505M  /mnt/Share/ix-applications/releases/nextcloud/volumes/ix_volumes/ix-nextcloud_data
Share/ix-applications/releases/nextcloud/volumes/ix_volumes/ix-nextcloud_data@1                           402M      -   439M  -
Share/ix-applications/releases/nextcloud/volumes/ix_volumes/ix-nextcloud_data@manual-2024-02-11_21-48     176K      -   505M  -
Share/ix-applications/releases/nextcloud/volumes/ix_volumes/ix-postgres_backups                           282K  8.08T   197K  /mnt/Share/ix-applications/releases/nextcloud/volumes/ix_volumes/ix-postgres_backups
Share/ix-applications/releases/nextcloud/volumes/ix_volumes/ix-postgres_backups@1                        85.2K      -   128K  -
Share/ix-applications/releases/nextcloud/volumes/ix_volumes/ix-postgres_backups@manual-2024-02-11_21-48     0B      -   197K  -
Share/ix-applications/releases/nextcloud/volumes/ix_volumes/ix-postgres_data                             20.1M  8.08T  17.1M  /mnt/Share/ix-applications/releases/nextcloud/volumes/ix_volumes/ix-postgres_data
Share/ix-applications/releases/nextcloud/volumes/ix_volumes/ix-postgres_data@1                           1.84M      -  15.1M  -
Share/ix-applications/releases/nextcloud/volumes/ix_volumes/ix-postgres_data@manual-2024-02-11_21-48     1.14M      -  16.8M  -
Share/ix-applications/releases/pihole        216M  8.08T   139K  /mnt/Share/ix-applications/releases/pihole
Share/ix-applications/releases/pihole/charts                                                              298K  8.08T   298K  /mnt/Share/ix-applications/releases/pihole/charts
Share/ix-applications/releases/pihole/volumes                                                             215M  8.08T   128K  /mnt/Share/ix-applications/releases/pihole/volumes
Share/ix-applications/releases/pihole/volumes/ix_volumes                                                  215M  8.08T   128K  /mnt/Share/ix-applications/releases/pihole/volumes/ix_volumes
Share/ix-applications/releases/pihole/volumes/ix_volumes/config                                           215M  8.08T   215M  /mnt/Share/ix-applications/releases/pihole/volumes/ix_volumes/config
Share/ix-applications/releases/pihole/volumes/ix_volumes/dnsmasq                                          160K  8.08T   160K  /mnt/Share/ix-applications/releases/pihole/volumes/ix_volumes/dnsmasq
Share/ix-applications/releases/plex        725K  8.08T   139K  /mnt/Share/ix-applications/releases/plex
Share/ix-applications/releases/plex/charts        330K  8.08T   330K  /mnt/Share/ix-applications/releases/plex/charts
Share/ix-applications/releases/plex/volumes                                                               256K  8.08T   128K  /mnt/Share/ix-applications/releases/plex/volumes
Share/ix-applications/releases/plex/volumes/ix_volumes                                                    128K  8.08T   128K  /mnt/Share/ix-applications/releases/plex/volumes/ix_volumes
Share/newNAS        128K  8.08T   128K  /mnt/Share/newNAS
boot-pool        4.86G   224G    96K  none
boot-pool/ROOT        4.80G   224G    96K  none
boot-pool/ROOT/23.10.1        2.35G   224G  2.34G  legacy
boot-pool/ROOT/23.10.1@2024-01-01-18:20:35                                                               8.29M      -  2.33G  -
boot-pool/ROOT/23.10.1.3        2.45G   224G  2.41G  legacy
boot-pool/ROOT/23.10.1.3@2024-02-12-05:29:39                                                             39.7M      -  2.36G  -
boot-pool/ROOT/Backup        8K   224G  2.36G  /
boot-pool/ROOT/Initial-Install        8K   224G  2.33G  /
boot-pool/grub        8.22M   224G  8.22M  legacy
Patrick M. Hausen
Now please put CODE tags around that output so the table is actually readable. Thank you.
Like so:
here goes your code
Davvo
Maybe I missed something, but wouldn't a screenshot of the snapshots tab of the WebUI have been more intuitive for the skill level of the opener?
Is he using SMB? In that's so, it's likely he's using Shadow Copies as well, which would make the recovery operation even easier without the need of exploring SCALE's new quirks.
Davvo
Then you are bound to restore a snapshot from TN, either from Shell or WebUI.
chuck32
Or you could clone to new dataset, create a share and then copy it to your original share if you don't want to restore blindly.
chuck32
I assume the screen in #25 stems from OP changing the shell, I never switched from the default zsh and therefore haven't seen that screen. If that's what you mean by moronic default setup. I can't comment on the latter, hasn't caused me problems so far but I assume I don't do as much in the shell as you ;)
@opensourceFTW glad you could solve your issue, the discussion about your shell troubles derailed this thread a little bit ;)
Patrick M. Hausen
I mean any setup that produces a menu like that on first login. Because in many possible cases one enables SSH and wants to submit remote commands over that channel. With Ansible or similar tools. So if I set a shell for a user in whatever system's UI I expect to be able to execute ssh <user>@<system> do something.
Having the shell capture the login and presenting a menu is what I consider moronic.
chuck32
That's what I meant. I'm pretty sure OP messed around in the shell settings prior to this thread. On a fresh installation you will never see that menu (at least I didn't).
And from looking at it I'm pretty sure this is a one time thing.
Or you mean like in general that the shell could require a setup like that even after messing around and not making reconfiguration optional / require user input. In that case yes, if you don't ever want the shell to capture your login like that I agree.
opensourceFTW
This is first time I have ran into this. I know for next time but at least this might help others that have the same problem.
Now the problem, why did my music disappear from TrueNAS scale?
