SOLVED Data for UPS is stale
SweetAndLow
Sweet'NASty
I have the CP1500PFCLCD and i'm also having the stale message.
Are we not supposed to add "MAXAGE 25" to auxiliary parameters in the gui?
You can't set it in the gui. There is no option to add values to the upsd.conf file.
STREBLO
Oh, right now it just edits a different config
Ahh, the gui changes ups.conf. Mybad.
trey22
Newbie trying hard here to learn. Does the CLI entry edit the upsd.conf file directly, or do I need to use an external editor (if so, which one and how)?
I opened up a shell and typed:
service nut stop
echo "MAXAGE 25">>/etc/local/nut/upsd.conf
service nut start
SweetAndLow
Sweet'NASty
service nut stop
service nut start
>> symbol redirects stdout to the file you specified and appends it to that file. No need for an editor.
trey22
Great, TYVM! It's been almost 20 minutes and "no data for UPS is stale" messages. They were popping up every couple of minutes before.
STREBLO
If we add an init script in the gui to write "echo "MAXAGE 25">>/etc/local/nut/upsd.conf" it can write to the boot disk right?
STREBLO
After changing the max age should you stop getting messages from your ups in the terminal saying the data is no longer sale? I'm not getting emails but in the little terminal that shows what's going on currently I keep seeing messages data for UPS is still check driver and then it says data is no longer stale. Will I continue to get these? My MAXAGE is set to 25.
STREBLO
I'm not sure why but I seem to be getting tons of emails still, I have maxage set to 30 and I'm still getting messages. I'm using the 1500 so I'm not sure if that's why. Is anyone using it as well and has solved this problem?
STREBLO
I just wanted to let everyone know that if they're having the same problem I was having we're changing the value didn't change anything I found out why it wasn't working for me.
I don't know if this was obvious for you guys but I didn't restart the ups daemon after changing it. Make sure to use the command upsd -c reload after changing your value. I've set it to change my max value and reload the demon in an init script.
upsd -c reload
dj_jazzn
I have been manually updating the uspd.conf file from the command line after every startup. Part of that method included stopping and restarting the service.
service nut stop
nano /etc/local/nut/upsd.conf (in editor add "MAXAGE 25" to last line of file and save)
service nut start
However, automating this with a script would be very nice (nicer still would be a proper fix for this issue).
Does this init script method work for you after reboots?
ethereal
i have a script
#!/bin/bash
echo "MAXAGE 30" >> /etc/local/nut/upsd.conf
service nut restart
exit 0
i run this as an init script and it works with reboots
STREBLO
service nut stop
service nut start
Sometimes, not very reliably.
enemy85
having the same problem here, again after long time it seemed to happen less frequently...
now trying with both the script and the "auto" value in the "port" field at ups service tab.
let's see what happens
SweetAndLow
Sweet'NASty
The auto value means nothing. The nut doc say that when using usbhid device the port value isn't even used. The maxage modification should fix it
enemy85
my script seems not to work...
I added the script (as a .sh file uploaded on my nas) and i set the pre-init script job, but looking at the upsd.conf file, i can't find the "maxage 30" line it shoud add...
#!/bin/bash
service nut restart
exit 0
I even tried to chaange the first line, as per another script i used to have...
#!/bin/sh
what am i doing wrong?
SweetAndLow
Sweet'NASty
What did you put in the gui to call the script, is the script executable? Can you run it yourself.
enemy85
what do you mean? Could you better explain your question?
SweetAndLow
Sweet'NASty
If you try to run the script from the command line does it work?
Can you give a screen shot of how you configured the gui with the pre- init script.
enemy85
probably found the problem...and your suggestion to make a test from command line make me find it...
the script filename had a space in it...now i eliminated it and it should works.
Thanks
enemy85
even with the script i got again the data stale problem.... :(
