wildbill001
- Sep 13, 2022
I've been researching NAS for sometime and have decided on TrueNas. I've been searching the forums the last day or so and keep coming up with little to no info or info that is from 2015-2018. So if this hardware combo was discussed somewhere, please point me in the right direction.
This is a system that has been sitting on a shelf doing little to nothing. Here are the specs:
CPU: FX8120
RAM: 32gb DDR3 @1333
M.B. Gigabyte 990FXA-UD3 (6 SATA ports on board)
Power: Cooler Master (if it matters) 750W
boot drive: 120gb SSD
Seagate Barracuda, 2TB X 7
IOCrest SI-PEX40062 PCIE 4-SATA port card (if needed) (also have a SI-PEX40057 that I just found, unopened)
Intel Pro Dual-port Gigabit Ethernet (can't remember which model)
My questions are:
1) Do I need or should I have bigger supply if I run all 7 drives (plus SSD for total of 8)?
2) Will either of those expansion cards work ok with TrueNas
3) Anything to watch out for (other than letting the smoke out of the various components)?
Planning on running TrueNas Core (latest version)
TIA
Bill W
CPU: FX8120
My questions are:
TIA
Bill W
