I've tried several different methods to get it working, but I can't get my machine working with 9.3 beta. No matter what I do, the machine won't even POST with the USB flash drive plugged in. It hangs right after showing the CPU information.
No big deal since this system is temporary until I can upgrade to server hardware, but I thought I'd shoot you guys the info since you're testing:
- I first tried updating from FreeNAS-9.2.1.8-RELEASE-x64 to FreeNAS-9.3-BETA-aaa86f0-x64 through the web interface. It seemed to complete successfully, but it wouldn't POST after restart.
- I thought the flash drive had died, so I booted the ISO in vmware and installed it to a different flash drive. No POST.
- I verified the SHA on the ISO I had downloaded
- I used dd to wipe the start and end sectors of both drives before trying again. No POST with either.
If I don't attach a flash drive, it posts fine and gets me all the way to the "This is a NAS drive, system halted" message... so no problems with the hardware. I also reverted to 9.2.1.9 and it still works great [after I used dd].
System Info:
Gigabyte GA-EP45-UD3P v1.6 (Intel P45 + ICH10R chipsets)
http://www.gigabyte.com/products/product-page.aspx?pid=3137#sp
+ Core2Quad Q6600, 8gb DDR2 (non-ECC), 6x 3TB WD Red
Hope that helps. Let me know if I can give you any more info, or if you want a bug report. The hardware is probably uncommon now, so no offense taken if you guys don't want to look into it further either :P
System Info:
