I am trying to install 9.3 and Release iso on a Dell R730. There is no cdrom drive on this machine, so I have to either use the virtual CD/DVD via iDRAC, or dd the iso to a USB drive and boot from there.
Using both methods, and using multiple Beta iso I have downloaded from the last two days, and also the RELEASE iso just now, I ran into this problem:
"Trying to mount root from cd9660:/dev/iso9660/FreeNAS_INSTALL []...
mounroot: waiting for device /dev/iso9660/FreeNAS_INSTALL ...
It times out after awhile and give me the mountroot promt. But I can't type anything into it.
I guess the virtual CD comes up as a different device name. But when using USB drive, it stills try to mount cd. Is there a device name I could try to modify at the grub prompt, and anything else I should try?
Thanks,
ling
Thanks,
ling
