VERY HIGH CPU after upgrade from FreeNAS 11.3
prophoto
/var/log/messages from midnight last night until reboot this morning.
Oct 29 00:00:00 freenas newsyslog[16658]: logfile turned over due to size>200K
Oct 29 00:00:00 freenas syslog-ng[2199]: Configuration reload request received, reloading configuration;
Oct 29 00:00:00 freenas syslog-ng[2199]: Configuration reload finished;
Oct 29 00:03:06 freenas kernel: Limiting closed port RST response from 1292 to 200 packets/sec
Oct 29 00:03:13 freenas kernel[2199]: Last message 'Limiting closed port' repeated 1 times, suppressed by syslog-ng on freenas.local
Oct 29 00:03:13 freenas kernel: Limiting closed port RST response from 1191 to 200 packets/sec
Oct 29 00:04:13 freenas kernel[2199]: Last message 'Limiting closed port' repeated 1 times, suppressed by syslog-ng on freenas.local
Oct 29 00:08:17 freenas kernel: Limiting closed port RST response from 773 to 200 packets/sec
Oct 29 00:08:24 freenas kernel[2199]: Last message 'Limiting closed port' repeated 1 times, suppressed by syslog-ng on freenas.local
Oct 29 00:08:24 freenas kernel: Limiting closed port RST response from 1303 to 200 packets/sec
Oct 29 00:09:23 freenas kernel[2199]: Last message 'Limiting closed port' repeated 1 times, suppressed by syslog-ng on freenas.local
Oct 29 00:14:11 freenas kernel: Limiting closed port RST response from 983 to 200 packets/sec
Oct 29 00:14:23 freenas kernel[2199]: Last message 'Limiting closed port' repeated 1 times, suppressed by syslog-ng on freenas.local
Oct 29 00:14:23 freenas kernel: Limiting closed port RST response from 1111 to 200 packets/sec
Oct 29 00:15:23 freenas kernel[2199]: Last message 'Limiting closed port' repeated 1 times, suppressed by syslog-ng on freenas.local
Oct 29 03:10:27 freenas 1 2020-10-29T03:10:27.987139-04:00 freenas.local collectd 2557 - - Traceback (most recent call last):
  File "/usr/local/lib/collectd_pyplugins/disktemp.py", line 62, in read
    with Client() as c:
  File "/usr/local/lib/python3.8/site-packages/middlewared/client/client.py", line 281, in __init__
    self._ws.connect()
  File "/usr/local/lib/python3.8/site-packages/middlewared/client/client.py", line 124, in connect
    rv = super(WSClient, self).connect()
  File "/usr/local/lib/python3.8/site-packages/ws4py/client/__init__.py", line 223, in connect
    bytes = self.sock.recv(128)
socket.timeout: timed out
Oct 29 04:00:27 freenas 1 2020-10-29T04:00:27.973605-04:00 freenas.local collectd 2557 - - Traceback (most recent call last):
    with Client() as c:
    self._ws.connect()
Oct 29 04:05:27 freenas 1 2020-10-29T04:05:27.984863-04:00 freenas.local collectd 2557 - - Traceback (most recent call last):
    with Client() as c:
    self._ws.connect()
Oct 29 04:15:27 freenas 1 2020-10-29T04:15:27.973144-04:00 freenas.local collectd 2557 - - Traceback (most recent call last):
    with Client() as c:
    self._ws.connect()
Oct 29 04:20:27 freenas 1 2020-10-29T04:20:27.972427-04:00 freenas.local collectd 2557 - - Traceback (most recent call last):
    with Client() as c:
    self._ws.connect()
Oct 29 04:40:27 freenas 1 2020-10-29T04:40:27.973518-04:00 freenas.local collectd 2557 - - Traceback (most recent call last):
    with Client() as c:
    self._ws.connect()
Oct 29 04:45:27 freenas 1 2020-10-29T04:45:27.972028-04:00 freenas.local collectd 2557 - - Traceback (most recent call last):
    with Client() as c:
    self._ws.connect()
Oct 29 05:15:27 freenas 1 2020-10-29T05:15:27.973943-04:00 freenas.local collectd 2557 - - Traceback (most recent call last):
    with Client() as c:
    self._ws.connect()
Oct 29 06:00:27 freenas 1 2020-10-29T06:00:27.973592-04:00 freenas.local collectd 2557 - - Traceback (most recent call last):
    with Client() as c:
    self._ws.connect()
Oct 29 06:05:27 freenas 1 2020-10-29T06:05:27.978758-04:00 freenas.local collectd 2557 - - Traceback (most recent call last):
    with Client() as c:
    self._ws.connect()
Oct 29 07:15:27 freenas 1 2020-10-29T07:15:27.971675-04:00 freenas.local collectd 2557 - - Traceback (most recent call last):
    with Client() as c:
    self._ws.connect()
Oct 29 08:05:27 freenas 1 2020-10-29T08:05:27.971223-04:00 freenas.local collectd 2557 - - Traceback (most recent call last):
    with Client() as c:
    self._ws.connect()
Oct 29 08:22:28 freenas syslog-ng[36007]: syslog-ng starting up; version='3.25.1'
Oct 29 08:22:28 freenas kernel: pid 2199 (syslog-ng), jid 0, uid 0: exited on signal 6 (core dumped)
Oct 29 08:25:57 freenas syslog-ng[36007]: syslog-ng shutting down; version='3.25.1'
Oct 29 08:25:57 freenas 1 2020-10-29T08:25:57.237341-04:00 freenas.local ntpd 2444 - - ntpd exiting on signal 15 (Terminated)
Oct 29 08:25:57 freenas 1 2020-10-29T08:25:57.235429-04:00 freenas.local init 1 - - timeout expired for /etc/rc.shutdown: Interrupted system call; going to single user mode
Oct 29 08:29:03 freenas syslog-ng[2187]: syslog-ng starting up; version='3.25.1'
Oct 29 08:29:03 freenas ---<<BOOT>>---
HoneyBadger
actually does care
Administrator
Looks like disktemp.py issue referenced here:
I don't see a definitive bug to roll it all up on Jira but submitting a ticket with debug/dump will no doubt help.
Do you see disk temps in your console? Strange that it works for hours and then falls over.
prophoto
Are there instructions somewhere to do a dump? Not sure if these reporting pages are normal or not, never paid much attention to them in 11.3.
HoneyBadger
actually does care
Administrator
The reporting pages are having issues in TN12, changing your theme in Preferences is sometimes needed to refresh them.
But it looks as if you're getting temp data. Do all of your disks have results if you choose Devices - Select All? I have one device in my test box here that doesn't do SMART (SATA NVRAM card) so it's disabled there, but my boot DOM and SAS drives all report their temperature correctly.
prophoto
3/6 show null, the rest have values.
AirborneTrooper
plex, sonarr, radarr, sabnzbd, transmission, tautulli, homebridge. I don't believe it to be anything from the jails though. I can still access my apps when the GUI is stuck on connecting. It's something with python3.8: middlewared and /sbin/systctl -a
HoneyBadger
actually does care
Administrator
Strange that sysctl -a is what fills top but yet if you run the same command interactively from a shell it doesn't stall out.
I'm afraid I'm not sure what's going on. I don't have this issue, I'm trying to make my test system misbehave in a similar way so that I can try to figure out what's breaking (or at least submit a debug to iX and give them another data point.)
-Mael-
OK, so ruled out one of the possible causes of those symptoms... SNMP causing high CPU in a python3.8 process.
Is there a known bug in SNMP? I ask because I do have it enabled to support monitoring. I notice my CPU utilization jumps by about 8% on my Intel Xeon E5-1650 v3 when it's enabled. It not causing me problems, but that seems like a lot of CPU usage for SNMP.
-Mael-
I just applied the SNMP fix mentioned in this thread and it has lowered my CPU utilization considerably (load average was 1 before and now averages around .3). It also fixed my problem of zabbix not being able to query the ZFS stats. If you're going to try this fix, make sure you stop SNMP before editing the file.
AirborneTrooper
What are the steps to
If you change snmp-agent.py line 32 to "kstat.zfs.misc.arcstats" it'll avoid the (presently unneeded) problem dbufs sysctl and work as it did before.
AirborneTrooper
Found it, I did this
nano /usr/local/bin/snmp-agent.py
Let's see if GUI is still up tomorrow morning or not.
scoger
I have this same sysctl -a issue as well. Quickly after boot of a TrueNAS-12.0-RELEASE system, the system gets bogged down with what appear to be tuck sysctl -a processes. I do not have SNMP turned on. This appears to be gathering stats for reporting, but the calls are either backing up or hanging in some fashion.
/bin/sh -c /sbin/sysctl -a 2>/dev/null | grep -E "hw.realmem|hw.physmem|vm.stats.vm.v_page_count|vm.stats.vm.v_wire_count|vm.stats.vm.v_active_count|vm.stats.vm.v_inactive_count|vm.stats.vm.v_cache_count|vm.stats.vm.v_free_count|vm.stats.vm.v_page_size"
Can get the system back into shape with a
killall -9 sysctl
