D
dlavigne
Guest
Regarding the vulnerability: http://www.ixsystems.com/whats-new/how-to-fix-the-ipmi-remote-management-vulnerability/.
Since 2 days i've got the same problem...
http://forums.freenas.org/index.php?threads/freenas-upsmon-2381-poll-ups-failed-data-stale.22077/
Has anybody solved it?
do i have to worry about it or not?It sometimes starts after the system has been running a straight month...
@enemy85 Is there a follow up message in the log that reads "data is no longer stale"?
There is a difference in your message to most others. Normally I got "Data for UPS [ups] is stale - check driver" but is was followed up shortly after with "UPS [ups] data is no longer stale". BUT the originating process of my message was UPSD.
Your process delivering your data stale messages is originating from UPSMON, which is a little more concerning because it is tied to the shutdown timer of your UPS. For that reason maybe it is a concern. A UPS is useless if it's not going to notify your system that it is on batt. Do some reading here:
http://www.networkupstools.org/docs/man/upsmon.html
And here are the values in UPSMON.conf that affect the running process:
http://www.networkupstools.org/docs/man/upsmon.conf.html
Read up on the POLFREQ value.
Have you added pollinterval= values to your ups.conf aux in the UPS services tab to see if this solves it? How many times is the message repeated in your log, is it once in a while or repeatedly filling the log?
We need more info to help.
Jul 16 09:28:50 freenas upsd[2373]: Data for UPS [RIELLO_UPS] is stale - check driver Jul 16 09:28:53 freenas upsmon[2381]: Poll UPS [RIELLO_UPS] failed - Data stale Jul 16 09:28:53 freenas upsmon[2381]: Communications with UPS RIELLO_UPS lost Jul 16 09:28:58 freenas upsmon[2381]: Poll UPS [RIELLO_UPS] failed - Data stale Jul 16 09:29:33 freenas last message repeated 7 times Jul 16 09:31:38 freenas last message repeated 25 times Jul 16 09:33:49 freenas last message repeated 26 times Jul 16 09:33:49 freenas upsmon[2381]: UPS RIELLO_UPS is unavailable Jul 16 09:33:54 freenas upsmon[2381]: Poll UPS [RIELLO_UPS] failed - Data stale Jul 16 09:34:29 freenas last message repeated 7 times
[root@freenas /usr/local/etc/nut]# cat ups.conf
[RIELLO_UPS]
driver = riello_usb
port = /dev/ugen1.5
desc = "" [root@freenas /usr/local/etc/nut]# cat upsmon.conf FINALDELAY 300 MONITOR RIELLO_UPS 1 upsmon fixmepass master NOTIFYCMD "/usr/local/sbin/upssched" NOTIFYFLAG ONBATT SYSLOG+WALL+EXEC NOTIFYFLAG LOWBATT SYSLOG+WALL+EXEC NOTIFYFLAG ONLINE SYSLOG+WALL+EXEC NOTIFYFLAG COMMBAD SYSLOG+WALL+EXEC NOTIFYFLAG COMMOK SYSLOG+WALL+EXEC NOTIFYFLAG REPLBATT SYSLOG+WALL+EXEC NOTIFYFLAG NOCOMM SYSLOG+EXEC NOTIFYFLAG FSD SYSLOG+EXEC NOTIFYFLAG SHUTDOWN SYSLOG+EXEC SHUTDOWNCMD "/sbin/shutdown -p now"
upsc RIELLO_UPS
Jul 16 02:30:58 XXXX upsmon[2577]: Poll UPS [XXXX] failed - Data stale
Jul 16 02:31:03 XXXX upsmon[2577]: Communications with UPS XXXX established
Key question: Is there any entry later in the log that states "data is no longer stale". If not I would suggest you have an issue. Have you tried a different USB port? Also, have you used the upsc command in shell to see if Freenas is able to communicate with your UPS? Open the shell and use
Code:upsc RIELLO_UPS
