bklyngaucho
- Jan 24, 2022
Looks to be the case, but it should drop here: https://download.truenas.com/TrueNAS-SCALE-Bluefin/22.12.2/
Yup, it's up now.Looks to be the case, but it should drop here: https://download.truenas.com/TrueNAS-SCALE-Bluefin/22.12.2/
Ah, so only available for an upgrade because I do not see it on the download page. I'll have to wait until I get home to play.
I seem to be in the same boat.Hi all,
Just upgraded to 22.12.2 all went fine
apps started without an issue but now all my apps have updates available so tried to upgrade my apps but i keep getting the following error
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/job.py", line 426, in run await self.future File "/usr/lib/python3/dist-packages/middlewared/job.py", line 461, in __run_body rv = await self.method(*([self] + args)) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1318, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1186, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/upgrade.py", line 115, in upgrade await self.upgrade_chart_release(job, release, options) File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/upgrade.py", line 265, in upgrade_chart_release config, context = await self.middleware.call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1386, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1335, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/chart_release.py", line 338, in normalise_and_validate_values dict_obj = await self.middleware.call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1386, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1335, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/validation.py", line 53, in validate_values verrors.check() File "/usr/lib/python3/dist-packages/middlewared/service_exception.py", line 70, in check raise self middlewared.service_exception.ValidationErrors: [EINVAL] values.scaleGPU: Not a list
Filip
Worth starting a new thread to focus on this issue.I seem to be in the same boat.
Just noticed this is all on Truecharts-stable apps and not a problem with Official-Charts apps. I'll hold off to see if the issue resolves itself in the next few days or so. For now, all official apps are working flawlessly.Worth starting a new thread to focus on this issue.
Please list the Apps and origin that have the issue.
Does a reboot solve the issue (not that that is acceptable, but just useful to know)?
Please post a link to the new thread.
thanks.. its still not good that TrueCharts Apps are having issues.. I assume its OK if people don't update?Just noticed this is all on Truecharts-stable apps and not a problem with Official-Charts apps. I'll hold off to see if the issue resolves itself in the next few days or so. For now, all official apps are working flawlessly.
Just gave a double check to see they are running fine as is currently on the previous versions. At least on the apps that I have running. (Some Arr apps, qbit, and MC Java Server)thanks.. its still not good that TrueCharts Apps are having issues.. I assume its OK if people don't update?
One of my NAS is still on 12.1 and it has the same issue. This bug is restricted to TrueCharts and nothing to do with Scale itself.thanks.. its still not good that TrueCharts Apps are having issues.. I assume its OK if people don't update?
I created a store about thisWorth starting a new thread to focus on this issue.
It's not a bug.One of my NAS is still on 12.1 and it has the same issue. This bug is restricted to TrueCharts and nothing to do with Scale itself.
FYI - I can no longer do a 'Launch Docker Image'.
I get the 'Please wait' dialog forever.
I can install applications, edit applications, delete applications, etc. Just not launch a docker image.
