Long time reader, first time poster. I've been using FreeNAS for about 1.5 years now and would classify myself as a n00b+ when it comes to FreeBSD. I know enough to do basic filesystem and user work but after that Google DuckDuckGo is my friend.
I recently upgraded from FreeNAS 11.3 (latest patch, whichever number that was) to TrueNAS 12.0. Prior to the software upgrade, I upgraded to a Ryzen 5 2600 from an i5-3570K (16gb RAM in each, but DDR3-1600 vs DDR-2400). Everything went well with the hardware upgrade. It boots off a 500gb WD Blue SSD drive.
During the upgrade to TrueNAS, I ended up wiping my configuration and starting fresh, hoping it would solve this crashing problem. It did not. The pools listed below were kept intact with no issues importing them.
I have 3 pools: pool1 is 6x10TB in raidz1 with 5 datasets and about 40% usage, pool2 and pool3 are drives within a 4-drive USB enclosure used for redundant backups, with 81% and 60% usage respectively. I have two jails running that use very little resources. One is a Plex/Sonarr/Radarr/Jackett/NZBGet/NZBHyrda2/qbittorrent setup. qBittorrent has about 100 torrents running, but probably 10+ active at any one time. Plex does not have any streamers 95% of the time. The 2nd jail is currently for rsync only that executes once a day. I also have three SMB shares that are seldomly used (one for each pool). I have reset all my permissions for the shares to accommodate for the FreeNAS root user -> TrueNAS non-root SMB user change. Everything works fine when the box is up. I also have it hooked into UPS power Tripp Lite SMART1500LCDT. Currently it is only using the UPS power with the USB cable unhooked and the UPS service disabled. This was working fine on FreeNAS. Currently the only services running are: SSH, SMB, and SMART.
The dilemma is that the box freezes/crashes seemingly randomly. I figure qBittorrent is the highest resource user out of everything I'm running but even then the hardware should be able to handle it well. When opening up the Sonarr UI it spikes CPU usage but goes back to normal after it loads. I've tried running the system without the USB enclosure connected, but it does not change to the problem. Plex does not transcode when it is being used the once or twice a day (if at all). Right now its only hooked up to power and gigabit ethernet.
I do not know of any logs I can look at to see if I can diagnose a problem, I'd be happy to post those for help sleuthing. I feel like this is a stab in the dark/searching for a needle in a haystack situation so any help on first steps towards diagnosing are greatly appreciated!
