I downloaded FreeNAS 11 .iso, and tried to run it in VMware Player 14.1.0, using Manjaro linux.
The host machine is a Ryzen 1700x with the Asus Prime x370-PRO motherboard. 32 Gigs of ram
This has a Intel NIC
The host machine has the ethernet listed as
The VMware Player is looking for eth0, not lo, or enp38s0 , and I don't see how to configure it to use the existing NIC.
AND Are the two errors I get when attempting to change or add the ethernet host whether in bridge, Host only, or NAT.
I have tried all of the options that are in the vm for configuring it, and I don't see a promiscuous mode. I am trying to test out my understanding of FreeNAS so that when my parts arrive, I can go ahead and start running it . (testing memory, cpu, board, disks.) The Ram and CPU are used so I want to test them asap.
Does anyone know how to bypass this holdback?
Do I have to rename my NIC as eth0 in manjaro linux in order for VMware to see it?
26:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03) Subsystem: ASUSTeK Computer Inc. I211 Gigabit Network Connection Flags: bus master, fast devsel, latency 0, IRQ 24 Memory at f7500000 (32-bit, non-prefetchable) [size=128K] I/O ports at e000 Memory at f7520000 (32-bit, non-prefetchable) [size=16K] Capabilities: <access denied> Kernel driver in use: igb Kernel modules: igb
ifconfig enp38s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.254.11 netmask 255.255.255.0 broadcast 192.168.254.255 inet6 fe80::changedit0:f42e prefixlen 64 scopeid 0x20<link> ether 60:changedittoo:7f txqueuelen 1000 (Ethernet) RX packets 6234948 bytes 8512807623 (7.9 GiB) RX errors 0 dropped 182 overruns 0 frame 0 TX packets 4910187 bytes 455486447 (434.3 MiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device memory 0xf7500000-f751ffff lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 6961 bytes 583999 (570.3 KiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 6961 bytes 583999 (570.3 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
Could not connect 'Ethernet0' to virtual network '/dev/vmnet1'. More information can be found in the vmware.log file. Failed to connect virtual device 'Ethernet0'.
Error toggling removable device: Failed to connect virtual device 'ethernet0'.
