wurzeladministrator
- Jan 17, 2017
I have seen similar questions on this forum but no real solutions that worked for me so I decided to post a new one. Any help appreciated.
We are running Freenas 9.10.2-U1 on a Dell R530 with Broadcom Corporation NetXtreme BCM5720 NICs of which only one is connected to the LAN.
Interface name is bge0 and configured with a static IP in a /22 private network:
I have tried to setup jails and iohyve guests but I never get them to be able to connect to the LAN other than the host. DHCP requests from guests fail and when I setup static IPs I can ping the FreeNAS host IP but not the gateway or any other host on the LAN:
The freebsd jail was created from the WebUI, the iohyve guest is an Ubuntu with all the steps taken into consideration from the FreeNAS Doc (https://doc.freenas.org/9.10/jails.html#using-iohyve) and the iohyve github README (https://github.com/pr1ntf/iohyve)
Here is the ifconfig for the bridge and tap (iohyve) and epair (jail) devices. tap1 is from a second iohyve guest currently not running (same network problems)
When I run tcpdump on the host interface bge0, I see the arp requests from the guest but no replies:
How do I set up the bridge and NIC interfaces so that replies from LAN hosts actually reach the guestVMs / jails ?
Thanks,
Ben
root@freenashost# ifconfig bge0 bge0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=c0099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,VLAN_HWTSO,LINKSTATE> ether 18:66:da:85:bb:05 inet 10.6.0.25 netmask 0xfffffc00 broadcast 10.6.3.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active
root@freenashost# arp -a ? (10.6.0.1) at 54:75:d0:ba:54:f5 on bge0 expires in 822 seconds [ethernet] ? (10.6.0.25) at 18:66:da:85:bb:05 on bge0 permanent [ethernet] ? (10.6.0.26) at 00:a0:98:79:64:d0 on bge0 expires in 1064 seconds [ethernet] root@freenashost# ping 10.6.0.26 PING 10.6.0.26 (10.6.0.26): 56 data bytes 64 bytes from 10.6.0.26: icmp_seq=0 ttl=64 time=0.138 ms 64 bytes from 10.6.0.26: icmp_seq=1 ttl=64 time=0.086 ms ^C --- 10.6.0.26 ping statistics --- 2 packets transmitted, 2 packets received, 0.0% packet loss round-trip min/avg/max/stddev = 0.086/0.112/0.138/0.026 ms root@freenashost # ssh crasher@10.6.0.26 crasher@10.6.0.26's password: Welcome to Ubuntu 16.04.1 LTS (GNU/Linux 4.4.0-31-generic x86_64) * Documentation: https://help.ubuntu.com * Management: https://landscape.canonical.com * Support: https://ubuntu.com/advantage 0 packages can be updated. 0 updates are security updates. Last login: Fri Jan 20 07:17:10 2017 from 10.6.0.25 crasher@crashub:~$ ifconfig enp0s3 Link encap:Ethernet HWaddr 00:a0:98:79:64:d0 inet addr:10.6.0.26 Bcast:10.6.3.255 Mask:255.255.252.0 inet6 addr: fe80::2a0:98ff:fe79:64d0/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:45 errors:0 dropped:0 overruns:0 frame:0 TX packets:51 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:7288 (7.2 KB) TX bytes:7373 (7.3 KB) lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:160 errors:0 dropped:0 overruns:0 frame:0 TX packets:160 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1 RX bytes:11840 (11.8 KB) TX bytes:11840 (11.8 KB) crasher@crashub:~$ ping 10.6.0.25 PING 10.6.0.25 (10.6.0.25) 56(84) bytes of data. 64 bytes from 10.6.0.25: icmp_seq=1 ttl=64 time=0.067 ms 64 bytes from 10.6.0.25: icmp_seq=2 ttl=64 time=0.097 ms ^C --- 10.6.0.25 ping statistics --- 2 packets transmitted, 2 received, 0% packet loss, time 999ms rtt min/avg/max/mdev = 0.067/0.082/0.097/0.015 ms crasher@crashub:~$ ping 10.6.0.1 PING 10.6.0.1 (10.6.0.1) 56(84) bytes of data. From 10.6.0.26 icmp_seq=1 Destination Host Unreachable From 10.6.0.26 icmp_seq=2 Destination Host Unreachable From 10.6.0.26 icmp_seq=3 Destination Host Unreachable ^C --- 10.6.0.1 ping statistics --- 4 packets transmitted, 0 received, +3 errors, 100% packet loss, time 3012ms pipe 3 crasher@crashub:~$ arp -a ? (10.6.0.1) at <incomplete> on enp0s3 ? (10.6.0.25) at 18:66:da:85:bb:05 [ether] on enp0s3 crasher@crashub:~$
bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: iohyve-bridge ether 02:42:fa:be:08:00 inet 0.0.0.0 netmask 0xff000000 broadcast 255.255.255.255 nd6 options=1<PERFORMNUD> id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 8 priority 128 path cost 2000 member: tap1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 9 priority 128 path cost 2000000 member: tap2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 7 priority 128 path cost 2000000 member: bge0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 tap2: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: iohyve-crashub options=80000<LINKSTATE> ether 00:bd:ca:23:03:02 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect status: active Opened by PID 8058 tap1: flags=8902<BROADCAST,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: iohyve-crasharch options=80000<LINKSTATE> ether 00:bd:4b:47:13:01 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect status: no carrier epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 02:ff:20:00:08:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active
root@freenashost# tcpdump arp tcpdump: verbose output suppressed, use -v or -vv for full protocol decode listening on bge0, link-type EN10MB (Ethernet), capture size 65535 bytes 16:03:47.879511 ARP, Request who-has 10.6.0.1 tell 10.6.0.26, length 46 16:03:48.880417 ARP, Request who-has 10.6.0.1 tell 10.6.0.26, length 46
Thanks,
Ben
