Transmission can't connect to trackers
Amsoil_Jim
Build FreeNAS-9.10.2-U3 (e1497f269)
Platform Intel(R) Atom(TM) CPU C2550 @ 2.40GHz
Memory 16327MB
IPv4 Default Gateway: 192.168.0.1
so everything was running fine until I had to get a new cable modem from my ISP and the new modem is also a wireless router, so I bridged my current router.
Port in transmission is set to 59595 and is open and tested-open
root@transmission_2:/ # ping google.com
ping: cannot resolve google.com: Host name lookup failure
root@transmission_2:/ # netstat -rn
netstat: no namelist
[root@freenas] ~# ping -c 4 www.google.com
PING www.google.com (172.217.8.164): 56 data bytes
64 bytes from 172.217.8.164: icmp_seq=0 ttl=55 time=34.470 ms
64 bytes from 172.217.8.164: icmp_seq=1 ttl=55 time=33.548 ms
64 bytes from 172.217.8.164: icmp_seq=2 ttl=55 time=34.034 ms
64 bytes from 172.217.8.164: icmp_seq=3 ttl=55 time=35.885 ms
--- www.google.com ping statistics ---
4 packets transmitted, 4 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 33.548/34.484/35.885/0.872 ms
[root@freenas] ~# ipconfig
CORRECT>ifconfig (y|n|e|a)? yes
igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=2400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6>
	ether d0:50:99:c0:6c:4c
	inet 192.168.0.159 netmask 0xffffff00 broadcast 192.168.0.255
	media: Ethernet autoselect (1000baseT <full-duplex>)
	status: active
igb1: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
	ether d0:50:99:c0:6c:4d
	status: no carrier
	options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
	inet6 ::1 prefixlen 128
	inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
	ether 02:da:5e:b6:44:00
	nd6 options=1<PERFORMNUD>
	member: epair3a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 8 priority 128 path cost 2000
	member: epair2a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 7 priority 128 path cost 2000
	member: epair1a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 6 priority 128 path cost 2000
	member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 5 priority 128 path cost 2000
	member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 1 priority 128 path cost 20000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=8<VLAN_MTU>
	ether 02:ff:60:00:05:0a
	status: active
epair1a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=8<VLAN_MTU>
	ether 02:ff:60:00:06:0a
	status: active
epair2a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=8<VLAN_MTU>
	ether 02:ff:60:00:07:0a
	status: active
epair3a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=8<VLAN_MTU>
	ether 02:ff:60:00:08:0a
	status: active
nojohnny101
If everything was working fine before, why not disable the DHCP and router functionality of the ISP modem and reassign duties to your previous router that is now in bridged mode?
Is this not an option? ISP modems are notoriously bad at anything other than passing internet through.
Amsoil_Jim
I'll have to try that, I was thinking the ISP modem had to be the one with dhcp enabled
As now I am noticing transmission is not the only one being effected. My plex server won't connect when accessing its GUI, the GUI loads but then says it can't connect to the server
Amsoil_Jim
Well I guess I was just super frustrated, freenas had nothing to do with everything not working.
I next day shipped a new cable modem only and everything works as it should.
I wil be taking the crap provided my ISP back to them and telling them to keep their junk.
Just an FYI I guessing that the issue was that my freenas and all jails have static IP addresses. Everything that was assigned an IP by the modem/router worked fine, everything with a static IP couldn't connect to the internet.
So this is SOLVED. With a new modem
