Very slow transfer speeds.
rodofrn
Hello guys, I recently realized that my PC transfer speed to my NAS is 10MB/s, it used to be 100MB/s. I have checked the cable and changed both tip connectors, and the speed remained the same. I have not changed any hardware in a long time. I have a "Supermicro Motherboard Micro ATX DDR3 1600 LGA 1150 Motherboards X10SLL-F-O" and have 2 ethernet cables going into it, in case one fails the other one takes over right? Here is the output of my ifconfig. Let me know any info you need, I will provide it very quickly. Thanks in advance.
root@freenas:~ # ifconfig
em0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=2098<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC>
		ether 0c:c4:7a:c5:16:49
		hwaddr 0c:c4:7a:c5:16:49
		inet 192.168.0.114 netmask 0xffffff00 broadcast 192.168.0.255
		media: Ethernet autoselect (1000baseT <full-duplex>)
		status: active
igb0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
		ether 0c:c4:7a:c5:16:48
		hwaddr 0c:c4:7a:c5:16:48
		inet 192.168.0.104 netmask 0xffffff00 broadcast 192.168.0.255
		status: active
		options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
		inet6 ::1 prefixlen 128
		inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
		groups: lo
		ether 02:40:58:77:2e:00
		nd6 options=1<PERFORMNUD>
		groups: bridge
		member: epair6a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 11 priority 128 path cost 2000
		member: epair5a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 10 priority 128 path cost 2000
		member: epair4a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 9 priority 128 path cost 2000
		member: epair3a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 8 priority 128 path cost 2000
		member: epair2a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 7 priority 128 path cost 2000
		member: epair1a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 6 priority 128 path cost 2000
		member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 5 priority 128 path cost 2000
		member: em0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 1 priority 128 path cost 20000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=8<VLAN_MTU>
		ether 02:24:50:00:05:0a
		hwaddr 02:24:50:00:05:0a
		status: active
		groups: epair
epair1a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=8<VLAN_MTU>
		ether 02:24:50:00:06:0a
		hwaddr 02:24:50:00:06:0a
		status: active
		groups: epair
epair2a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=8<VLAN_MTU>
		ether 02:24:50:00:07:0a
		hwaddr 02:24:50:00:07:0a
		status: active
		groups: epair
epair3a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=8<VLAN_MTU>
		ether 02:24:50:00:08:0a
		hwaddr 02:24:50:00:08:0a
		status: active
		groups: epair
epair4a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=8<VLAN_MTU>
		ether 02:24:50:00:09:0a
		hwaddr 02:24:50:00:09:0a
		status: active
		groups: epair
epair5a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=8<VLAN_MTU>
		ether 02:24:50:00:0a:0a
		hwaddr 02:24:50:00:0a:0a
		status: active
		groups: epair
epair6a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=8<VLAN_MTU>
		ether 02:24:50:00:0b:0a
		hwaddr 02:24:50:00:0b:0a
		status: active
		groups: epair
In general I think it is not best practice to have multiple IP addresses on the same network. Does disconnecting one of the NIC ports change anything? For what you are trying to achieve (redundancy, not link aggregation), I would recommend doing a LAG configured in failover mode.
Chris Moore
Chris Moore
rodofrn
@Elliot Dierksen Thanks for answering, I disconnected one of the cables and nothing changed, same 10mbps speed.
@Chris Moore Thanks for answering, what should I do then?
I used to be able to reach 100mbps transfer speed, but not anymore.
What are you using to test the speed? If it is CIFS, you should (temporarily) set up FTP or something else to see if it is unique to CIFS. Have you tested from a different workstation? If not, can you?
rodofrn
OK so, I no longer have 2 cables going into the machine, only 1.
I am simply going into the workstation and transferring a file over CIFS.
I did, it is the same speed. :/
Just went to my gf mac, and voila, 100mbps.
What is wrong with my workstation? I reinstalled the EXACT (found MB model, website to check NIC details, download NIC drivers) drivers for the onboard NIC. Same speed. I don't think its the cable?!!? What else can I do?
Thanks all for keeping up with this post!
Is it a managed or un-managed switch? If it is the former, are speed and duplex both set to auto? Same question on the NIC in your workstation. I have nothing to base this on but gut feel, but I wonder if one side or the other has duplex forced to full.
kdragon75
Did you test or swap the cable to be sure? 1gb uses more actual wires than 100mb. Also check the link speed on your workstation.
Good point. If the Mac in question is wired, try switching cables and switch ports. If the problem follows the port/cable, that gives you a direction. Same thing if the problem follows the workstation. Again, my gut leans towards something with duplex forced to full.
[Network guy rant]
Short of a bridging loop, forcing duplex is usually the WORST thing you can to do a network. What a lot of people don't realize is that when a device has duplex forced, that means it does not respond to a duplex negotiation request. If no response is received to a duplex negotiation request, that device is required to assume half duplex. That means that any time both sides start to talk, the half duplex side will abort. This causes absolutely abysmal performance. You can actually tell very easily in a managed switch by looking at the interface stats. The full duplex side will see lots of runts (packets too short) and CRC errors. The half duplex side will see TONS of collisions, and particularly late collisions. I have a mental block as to whether it is 2 or 3 maximum repeaters in a segment (hubs for those of you that aren't old like me), but there is a maximum for that and a maximum cable length. Because of these limits, there is a maximum amount of time that any device on a network should be able to see that a device has the wire and they should not talk. A late collision is a collision that occurs after this time has expired and every device should know that the wire is occupied. Late collisions are ALWAYS bad! Phew, sorry. Guess I got a little carried away.
[/Network guy rant]
rodofrn
Now that you ask...it does say this on the monitoring page. My workstation is "PORT 1".
The cable was hanging from the port in the switch. Meaning it wasn't all the way connected properly.
Glad you found the answer. I forget where I heard it but I always keep in mind that "Inside every big problem is a little problem dying to get out". :smile:
