I just started putting my system together and I am confused when it comes to the front panel. I've built dozens on PCs but this is my first time with a Supermicro mobo. As you can see here: http://www.supermicro.com/QuickRefs/motherboard/C220/MNL-1428-QRG.pdf
Front Panel Control (JF1) lays out how to connect the front panel pins. I have a power switch + and -, and power LED and HDD LED that also both have a + and - connector. All these show 1 pin connections.
Am I just reading this wrong, and I should, for example, connect my power LED to pins 15 and 16, where positive would go to pin 16?
