Good Afternoon,
Sorry if this has been addressed before, but I couldn't find the answer when I did a search.
First time building a Freenas server and I've never used a Supermicro motherboard before. I'm putting my components together. However, I'm having a difficult time figuring out where some of the front panel wiring goes in the JF1 Header Pins of the motherboard.
The Fractal Node 804 has 4 pins (Power SW, Power LED+, Power LED- and HDD LED). Power SW is probably going to Pin 1 and 2. HDD LED is probably going to Pin 14. However, not sure where Power LED+ and Power LED- goes. I'm thinking the Power LED+ goes to Pin 16. However, where does Power LED- goes?
https://www.supermicro.com/manuals/motherboard/C236/MNL-1785.pdf
I would appreciate it if someone could answer this for me.
Thank you.
Thank you.
